    Fix Windows 10 Update Issues
HP Color LaserJet Enterprise M553 - Replace the toner cartridges
The following information provides details about the toner cartridges for the product, and it includes instructions to replace them.
Toner-cartridge information
This product indicates when the toner-cartridge level is low and very low. The actual toner cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges or check cartridge compatibility for the product, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
The product uses four colors and has a different toner cartridge for each color: yellow (Y), magenta (M), cyan (C), and black (K). The toner cartridges are inside the front door.
Item
Part number
HP 508A Black Original LaserJet Toner Cartridge
CF360A
HP 508X High Yield Black Original LaserJet Toner Cartridge
CF360X
HP 508A Cyan Original LaserJet Toner Cartridge
CF361A
HP 508X High Yield Cyan Original LaserJet Toner Cartridge
CF361X
HP 508A Yellow Original LaserJet Toner Cartridge
CF362A
HP 508X High Yield Yellow Original LaserJet Toner Cartridge
CF362X
HP 508A Magenta Original LaserJet Toner Cartridge
CF363A
HP 508X High Yield Magenta Original LaserJet Toner Cartridge
CF363X
High-yield toner cartridges contain more toner than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
Do not remove the toner cartridge from its package until it is time to replace it.
To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the product for an extended period of time.
The following illustration shows the toner-cartridge components.
    Figure : Toner-cartridge components
  1. Handle
  2. Imaging drum
  3. Protective shield
  4. Memory chip
If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
Information about recycling used toner cartridges is in the toner-cartridge box.
Remove and replace the cartridges
  1. Open the front door.
    Figure : Open the door
  2. Grasp the handle of the used toner cartridge and pull out to remove it.
    Figure : Remove the toner cartridge
  3. Remove the new toner cartridge from its protective shell by tearing off the plastic strip and opening the package. Save all packaging for recycling the used toner cartridge.
    Figure : New toner cartridge
  4. Hold both ends of the toner cartridge and rock it 5-6 times.
    Figure : Shake the toner cartridge
  5. Remove the protective shield from the toner cartridge.
    Figure : Remove the protective shield
  6. Support the toner cartridge underneath with one hand while holding the cartridge handle with the other. Align the toner cartridge with its slot on the shelf, and then insert the toner cartridge into the product.
    Avoid touching the green imaging drum. Fingerprints on the imaging drum can cause print defects.
    Figure : Install the toner cartridge
  7. Close the front door.
    Figure : Close the door
  8. Pack the used toner cartridge and the protective shield into the box that the new cartridge came in.
    In the U.S. and Canada, a pre-paid shipping label is included in the box. In other countries/regions, go to www.hp.com/recycle to print a pre-paid shipping label.
    Adhere the pre-paid shipping label to the box, and return the used cartridge to HP for recycling.
    Figure : Recycle the used cartridge
