HP ProDisplay P242va 24-inch Monitor - Overview
Product Description
Product Features
Feature
Model
K7X32AA
Type
24 in VA with LED backlight
Panel active area (W × H)
53.13 x 29.88 cm (20.91 x 11.76 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical
Brightness
250 nits (cd/m2)
Contrast ratio (typical)
1000:1 Static
5,000,000:1 Dynamic (DCR)
Response time (typical)
8 ms gray to gray
Performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Pixel pitch
0.27675 (H) x 0.27675 (V) mm
Pixels per inch (PPI)
92
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
