    Windows 11 Upgrade Guide
HP DeskJet 2130, 2300 Printers - First Time Printer Setup
This document is for Deskjet 2130, 2132, 2134, 2136, 2320, 2330, 2331, 2332, 2333, DeskJet Ink Advantage 2134, 2135, 2136, 2138, 2335, 2336, 2337, 2374, 2375,2376 All-in-One printers.
To set up your printer for the first time, remove all package materials, connect the power cord, install the ink cartridges, and then load paper in the main input tray.
If you are looking for the printer software, go to http://123.hp.com/DJ2130.
Step 1: Unpack the printer from the box
Remove the printer from the box, and then remove all tape, stickers, and package materials from the printer.
The contents might vary by country/region. See the printer package for a list of items shipped in the box.
  2. Remove all tape and package materials from the outside of the printer.
  3. Lower the output tray, reach inside the printer, and then grasp the handle and lower the ink cartridge access door to open it.
    Figure : Open the ink cartridge access door
    Image: Open the ink cartridge access door
  4. Remove all tape and package materials from inside the printer.
    Figure : Remove the tape and package materials
    Image: Remove the tape and package materials
  5. Close the ink cartridge access door.
    Figure : Close the ink cartridge access door
    Image: Close the ink cartridge access door
  6. Make sure you remove all hardware and materials from the box before discarding or recycling the box and package materials.
Step 2: Connect the power cord and then turn on the printer
Plug the printer into a power source to turn on the printer.
Do not connect a USB cable at this time. The connection to the computer is set during the driver and software installation.
    Figure : Connect the power cord
    Image: Connect the power cord
  2. Press the Power button to turn on the printer.
Install the HP ink cartridges that shipped in the box with your printer.
  1. Grasp the handle and lower the ink cartridge access door to open it.
    The carriage moves to the center of the printer.
  3. Remove one of the ink cartridges from its package. Be careful to only touch the black plastic on the ink cartridge.
    Figure : Remove the ink cartridge from its package
    Image: Remove the ink cartridge from its package
  4. Remove the plastic tape.
    Figure : Remove the plastic tape
    Image: Remove the plastic tape
  5. Hold the ink cartridge by its sides with the nozzles toward the printer, and then insert the ink cartridge into its proper slot.
    • Insert the black ink cartridge into the right slot.
    • Insert the tri-color ink cartridge into the left slot.
  6. Slide the new ink cartridge at a slight upward angle into the empty slot, and then gently push up on the ink cartridge until it snaps into place.
    Figure : Snap the ink cartridge into place
    Image: Snap the ink  cartridge into place
  7. Repeat these steps to install the other ink cartridge.
  8. Close the ink cartridge access door.
Load plain, U.S. letter or A4 paper in the input tray after you install the ink cartridges.
  1. Raise the input tray.
    Figure : Raise the input tray
    Image: Raise the input tray
  2. Remove any paper from the input tray that is different than the type of paper you want to load, and then slide the paper width guide as far as possible to the left.
    Figure : Slide the paper width guide to the left
    Image: Slide the paper width guide to the left
  3. Load a stack of U.S. letter, A4, or legal size paper into the input tray with the short edge forward and the printside facing closest to you. Push the stack into the tray until it stops.
    Figure : Load the paper into the input tray
    Image: Load the paper into the input tray
  4. Slide the paper width guide to the right until it rests at the edge of the paper.
    Figure : Slide the paper width guide to the right
    Image: Slide the paper width guide to the right.
  5. Lower the output tray and pull out the output tray extender.
    Figure : Lower the output tray and pull out the output tray extender
    Image: Lower the output tray and pull out the output tray extender.
Step 5: Align the ink cartridges
Aligning the ink cartridges is necessary to achieve the best print quality.
  1. After loading the paper, the printer automatically prints an alignment page.
    The printer only prints an alignment page automatically when new ink cartridges are installed.
  2. Lift the scanner lid.
  3. Place the alignment page with the print side down on the scanner glass, and then position it according to the engraved guides around the glass.
    Figure : Place the alignment page on the scanner glass
    Image: Place the alignment page on the scanner glass
  4. Close the scanner lid.
  5. Press the Start Copy Black button () or the Start Copy Color button () on the control panel of the printer.
    The printer aligns the ink cartridges.
Download the latest version of the printing software from the following HP website: http://123.hp.com/DJ2130.
