HP PCs - How to Solve the Problem of Converting GPT to MBR
The error message Windows cannot be installed to this disk. The selected disk is of the GPT partition style displays.
Figure : Windows cannot be installed to this disk. The selected disk is of the GPT partition style
Image: Windows cannot be installed to this disk. The selected disk is of the GPT partition style
The computer cannot boot from GPT unless the system board supports the EFI.
Only Windows 7 64-bit and Windows Vista 64-bit on UEFI based systems support GPT.
Select one of the options below to install Windows OS or to concert the hard disk drive to MBR and follow the steps for that section.
Command prompt
Follow these steps if the Windows cannot be installed message displays while installing Windows OS and get this error message or if the customer wants to concert the hard disk drive to MBR through the Command prompt.
  1. Insert the installation DVD or CD, and then turn on the computer.
  2. Click Install but do not follow through.
  3. Press Shift + F10, and then click Open command window here.
    The command prompt opens.
    Figure : Open command window here
    Image: Open command window here
  4. In the command prompt, type diskpart, and then press Enter.
  5. Type list disk, and then select the disk that you want to convert.
  6. Type select disk 0, replace 0 with the disk number you want to convert.
    Figure : diskpart
    Image: diskpart
  7. Type convert mbr, and then type quit.
  8. Continue with the installation.
Deleting partitions
Follow these steps to delete all partitions drive options.
  2. Continue until the Install Windows screen displays.
  3. Click Drive options.
    Figure : Drive options
    IMage: Drive options
  4. Select a partition, and then click Delete. Do this for all listed partitions.
    You must type Enter after every command.
    Figure : Delete partitions
    Image: Delete partitions
  5. Click New to create a new partition.
    Figure : Create a new partition
    Image: Create a new partition
  6. Continue with the installation.
