    Fix Windows 10 Update Issues
    Are you working from home?
HP Printers - Printing with Wi-Fi Direct
This document is for HP printers with Wi-Fi Direct wireless printing.
Wi-Fi Direct is a connection option available with most HP wireless printers released in 2014 and later. Use Wi-Fi Direct if connecting through a local Wi-Fi network is not an option or for guest printing.
Read the section for your device type for steps to connect and print using Wi-Fi Direct.
Read commonly asked questions about using Wi-Fi Direct and to resolve issues.
