    Looking for Site Help?
HP LaserJet Enterprise M604, M605, M606 - 13.Ax.FF paper tray jams
Issue:
This document applies to the following printers only:
  • HP LaserJet Enterprise M604
  • HP LaserJet Enterprise M605
  • HP LaserJet Enterprise M606
A 13.Ax.FF paper jam error usually occurs when the printer is turned on with a paper jam, or a torn piece of paper remains in the printer blocking a sensor. The X indicates which paper tray is affected.
Solution
The paper might have torn when a jam was removed.
Step one: Check for jammed paper
Clear any jammed paper from the printer. For instructions, refer to one of the following documents:
If paper is not visible, look inside the printer behind the tray.
Step two: Clear the paper path
A small piece of torn paper or debris might block the paper path. The procedure to clear the paper path is referred to as flossing.
Video of clearing the paper path.
Step three: Contact HP
If a jam message persists, contact HP technical support to perform additional troubleshooting steps.
Country: Flag Bulgaria
