    Apache Log4j Update
HP EliteBook Folio 1020 G1 Notebook PC - Overview
Product Description
Product Features
Feature
Processor
Intel Core M-5Y51 1.1 GHz (max turbo frequency 2.6 GHz), 4 MB L3 Cache, 4.5W (Kit)
Intel Core M-5Y71 1.2 GHz (max turbo frequency 2.9 GHz), 4 MB L3 Cache, 4.5W
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Integrated with processor
Graphics
Integrated: Intel HD Graphics 5300
Internal:
  • Touch: 12.5-in diagonal eDP, UltraSlim, QHD UWVA (2560x1440) 340nts (Not available on Ubuntu)
  • Non touch: 12.5-in diagonal eDP ,UltraSlim, FHD UWVA, anti-glare (1920 x 1080) 300nts
DisplayPort: Supports resolutions up to 2560 x 1440
Number of displays supported: 3 with the HP Ultraslim Docking Station or the DP hub.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Solid State Drive (SSD)*:
  • 128 GB SATA III
  • 180 GB SATA III
  • 256 GB SATA III
  • 512 GB SATA III
Self encrypting drive:
  • 180 GB SATA III Self Encrypting Drive Opal 2
  • 256 GB SATA III Self-Encrypting Drive Opal 2
* For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 7) and up to 36 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Internal component upgrades to memory are not available after factory configuration.
Memory
Standard:
  • LPDDR3 SDRAM 1600 MHz
  • Supports Dual Channel Memory
Standard memory:
4 GB soldered down
Maximum:
8 GB soldered down
Networking / communications
Wireless:
Support for WLAN featuring support for the latest industry standards.
Wireless LAN and integrated Bluetooth are also available both are factory configurable only.
WLAN:
  • Intel 802.11 a/b/g/n (2x2) with Bluetooth v4.0 Combo*
  • Intel 802.11 (2x2) AC with Bluetooth v4.0 Combo* , **
*Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited.
**The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Audio / multimedia
Audio:
  • HD Audio with DTS Studio Sound
  • Two integrated stereo speakers
  • Integrated dual- array microphone
Webcam:
720p HD* webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280x720 resolution
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
*HD content required to view HD images.
Keyboards / pointing devices / buttons and function keys
Keyboard
Spill-resistant with drain
Backlit
DuraKeys
Function Keys provide easy access to the following features:
  • F1 - Blank
  • F2 – Forcepad on/off
  • F3 - Sleep
  • F4 - Display Switching
  • F5 - Mute
  • F6 - Volume Down
  • F7 - Volume Up
  • F8 - Mic Mute
  • F9 - Brightness Down
  • F10 - Brightness Up
  • F11 - Backlight Toggle
  • F12 - Wireless On/Off
ForcePad
A pressure-sensing ForcePad that eliminates the need for repetitive motion and makes navigation easier
ForcePad
Glass with chemical etched surface
Taps enabled as default
Gestures enabled by default - 2 Finger Scrolling, 2 Finger Zoom (Pinch)
Software and security
Preinstalled software with Windows Operating System
  • Security software:
    HP BIOSphere1
    Absolute Date Protect (Windows 8.1 only)2
    HP Sure Start
    HP DriveLock | HP Automatic Drive Lock
    HP BIOS Protection3
    HP Disk Sanitizer4
    HP SpareKey5
    BIOS Update via Network
    Master Boot Record Security
    Power On Authentication
    Pre-Boot Security
    Secure Erase6
    Hybrid Boot (Windows 8.1 only)
    Measure Boot (Windows 8.1 only)
    Secure Boot (Windows 8.1 only)
    Absolute Persistence Module7
  • HP client security software suite
    HP Client Security Manager (Windows only)
    HP Device Access Manager
    HP File Sanitizer12
    HP Drive Encryption17
  • Multimedia
    Cyberlink Power DVD, BD
    Cyberlink YouCam BE (Windows 7 only)
  • Communication
    HP Wireless Hotspot (Windows 8.1 only)10
    Intel Wireless Display (WiDi) Software for Windows11
    Intel My WiFi and Wireless Drivers
    Lync optimized
  • HP value add software
    Getting Started with Windows 8
    HP 3D DriveGuard (Windows required)
    HP ePrint Driver (HP Exclusive)13
    HP Hotkey
    HP PageLift
    HP Recovery Manager (Windows 7 only)
    HP Support Assistant
    HP Recovery Disc Creator (Windows 7 only)
    UEFI System Diagnostics W8
  • Manageability
    HP Driver Packs15
    HP SoftPaq Download Manager (SDM)
    HP System Software Manager (SSM)15
    HP BIOS Config Utility (BCU)15
    HP Client Catalog / HP CIK for Microsoft SCCM15
    LANDESK Management16
  • 3rd party
    Adobe Flash Player (Commercial)
    Foxit PhantomPDF Express for HP8
    Bing Search
    Buy Office
  • Security
    TPM Embedded Security Chip 1.2/2.014
    Security lock slot
    Fingerprint Reader
1HP BIOSphere features may vary depending on the PC platform & configuration.
2Absolute Data Protect software is preloaded, subscription required. Absolute Data Protect agent is shipped turned off, and must be activated by customers. Service may be limited, check with Absolute for availability outside the U.S. The optional subscription service of Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. If Data Delete is utilized, the Recovery Guarantee payment is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either create a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
3HP BIOS Protection requires a HPTools partition for automatic recovery.
4For the use cases outlined in the DOD 5220.22-M Supplement. Does not support solid state drives and requires Windows.
5Requires initial user set up.
6For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
7BIOS Absolute Persistence module is shipped turned off, and will be activated when customers purchase and activate a subscription. Service may be limited. Check with Absolute for availability outside the U.S. The optional subscription service of Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. If Data Delete is utilized, the Recovery Guarantee payment is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either create a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
8Read only.
10The HP Wireless Hotspot application requires an active internet connection and separately purchased data plan. While HP wireless hotspot is active, on-device applications will continue to work and will use the same data plan as the wireless hotspot. Wireless hotspot data usage may incur additional charges. Check with your service provider for plan details. Requires Windows 8.1 or HP Connection Manager for Windows 7.
11Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, TV or computer monitor with an integrated or external Wi-Di receiver. External Wi-Di receivers connect to the projector, TV or computer monitor via a standard HDMI cable, also sold separately.
12Managed devices must be connected to the management server. Location based functionality requires active LANdesk maintenance service. Wipe functionality performs a "Windows 8 Reset" and requires Windows 8. Lock performs a Windows "Lock Computer."
13Requires an Internet connection to HP web-enabled printer and HP ePrint account registration.
14Firmware TPM is version 2.0. Hardware TPM is v1.2, which is a subset of the TPM 2.0 specification version v0.89 as implemented by Intel Platform Trust Technology (PTT).
15Not preinstalled, however available on manageability website.
16LANDesk is an optional feature sold separately. Managed devices must be connected to the management server. Location based functionality requires active LANdesk maintenance service. Wipe functionality performs a "Windows 8 Reset" and requires Windows 8. Lock performs a Windows "Lock Computer."
17Data is protected prior to Drive Encryption login. Turning the PC off or into hibernate logs out of Drive Encryption and prevents data access. Requires Windows.
Power
Power supply:
  • 45-W Smart AC adapter
  • 45W AC adapter 2 prong (Japan only)
  • 65-W Smart EM AC adapter
  • 65-W Slim Smart AC adapter
  • Power cord included is 1 m (3.2 ft) long
  • Optional power cord 1.8 m long (sold separately.)
Primary battery:
HP 4-Cell (36 Whr) polymer long life battery
Battery life:
Up to 9 hours
