HP Pro Slate 10 EE G1 - Overview
Product Description
Product Overview
Feature
Weight and dimensions
0.855 kg (1.88 lb)
Dimensions (W x D x H)
280 x 182 x 14.4 mm (11.02 x 7.16 x 0.56 in)
Weight and system dimensions may fluctuate due to configuration and manufacturing variances
Ports / slots
Ports
DC-in jack - 1
Micro USB 2.0 (type-D connector)* - 1
3.5 mm headphone jack** - 1
MicroSD card slot***
*Micro HDMI to HDMI cables sold separately
** Headphones are sold separately
*** Card sold separately
Android 4.4.4 (Kit Kat)
Processor
Intel Atom Quad Core Processor Z3735G with Intel HD Graphics (1.33 GHz, up to 1.83 GHz using Intel Burst Technology, 2 MB cache, 4 cores)
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Intel's numbering is not a measurement of higher performance.
Graphics
Intel HD Graphics (integrated)
Type: 10.1diagonal (1280 x 800) WXGA IPS Anti-glare Ultra-Slim w/ LED backlight
Touchscreen: 10 point touch capacitive digitizer
Aspect ratio: 16:10
Auto rotate: Selectable
Screen material: Chemically strengthened Soda Lime Glass
Diagonal size: 10.1 in
Viewing angles: 90°
Refresh rate: 60 Hz
Brightness: 350 nits (typical)
Color depth: 16.7M colors (RGB 6-bits) data driver with Hi-FRC
Stylus (optional)
2.2 mm tip Passive Stylus support, Back cover with integrated stylus garage
Product may be ordered without stylus.
Internal storage device
16 or 32 GB embedded Multi Media Card NAND flash 5.0 MicroSD card slot supporting up to 32 GB* Micro-SIM Slot (only available on Wireless WAN SKUs)**
For storage drive, GB = 1 billion bytes. Optional Micro-Secure Digital (SD) card sold separately. Actual formatted capacity is less. Up to 5 GB of system disk is reserved for system recovery software.
*Card sold separately
** Optional feature
Memory configurations
1 GB DDR3L - 1600 MHz (select configurations)
2 GB DDR3L - 1600 MHz (select configurations)
Networking / communications
Wi-Fi* and Bluetooth combo:
802.11a/b/g/n (2x2) Wi-Fi and Bluetooth 4.0 LE combo (Miracast supported)1,2
Broadband Wireless (WWAN):
HP hs3110 HSPA+ Mobile Broadband3 with GPS support
Other wireless features:
Near Field Communications (NFC)4
1Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
2Miracast technology only works with other Miracast ready devices. High definition (HD) content is required to view high-definition images.
3Mobile Broadband is an optional feature and requires factory configuration. Use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all regions.
4NFC only required for Google EDU configurations. Lower specification cameras available, Stylus is Optional, 3G is Optional. Configurations vary by region.
Audio / multimedia
Audio
DTS Sound+
Mono speaker - 1
Integrated microphone - 1
3.5 mm headphone jack* (4-pole headsets and CTIA type headsets supported)
Cameras**
  • Premium option:
    Front: 2MP front-facing camera with webcam indicator LED
    Back: 5MP rear-facing camera, auto-focus
  • Standard:
    Front: 1.26MP front-facing camera with webcam indicator LED
    Back: 2MP rear-facing camera
** Configurations vary
Sensors
Accelerometer and e-compass
In the box
  • HP Pro Slate 10 EE G1
  • AC charger with integrated cable
  • Quick Start Guide
Software Overview
Feature
  • Search
  • Gmail
  • Contact Sync
  • Calendar Sync
  • Hangouts / Talk
  • Chrome
  • "Docs/Drive"
  • Google+
  • Maps
  • Street view
  • YouTube
  • Google Play Store
  • Google Play Games
  • Google Play Books
  • Google Play Movies
  • Google Play Newsstand
  • Google Play Music
  • Play services
  • Widevine
  • Config updater
  • FaceLock
  • Camera / Gallery
  • HP Media Player
HP school pack software
  • Absolute Computrace Data Protection Basic (1 Year License)
  • Avast Mobile Security
  • HP Classroom Manager
  • PASCO / SparkVUE
  • OverDrive
  • Oxford University Press
  • HP MyRoom
  • HP Life
  • Hibernia Engine / HP MOOC
  • HP Registration
