HP Elitebook 840 G2 Notebook PC Product Specifications
Product image
HP EliteBook 840 G2 Notebook PC
Product features
Feature
Processor
  • 5th Generation Intel Core i5-5200U 2.2 GHz (max turbo frequency 2.7-GHz), 3 MB L3 cache, 15W
  • 5th Generation Intel Core i5-5300U 2.3 GHz (max turbo frequency 2.9-GHz), 3 MB L3 Cache, 15W
  • 5th Generation Intel Core i7-5500U 2.4 GHz (max turbo frequency 3.0-GHz), 4 MB L3 Cache, 15W
  • 5th Generation Intel Core i7-5600U 2.6 GHz (max turbo frequency 3.2-GHz), 4 MB L3 Cache, 15W
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel® architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel® 64 architecture. Processors will not operate (including 32-bit operation) without an Intel® 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Not available with Intel iAMT (*Not available with vPro)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Chipset integrated with processor
Graphics
  • Integrated: Intel HD* Graphics 5500
  • Discrete: AMD Radeon R7 M260X, with 1 GB dedicated DDR5 video memory**
*HD content required to view HD images.
**AMD Dynamic Switchable Graphics technology requires an Intel processor, plus an AMD Radeon discrete graphics configuration and is not available on FreeDOS and Linux OS. With AMD Dynamic Switchable Graphics technology, full enablement of all discrete graphics video and display features may not be supported on all systems (e.g. OpenGL applications will run on the integrated GPU or the APU as the case may be).
Internal:
Non touch
  • 14.0" diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
  • 14.0" diagonal LED-backlit HD anti-glare SVA flat (1366 x 768) with camera
  • 14.0" diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900)
  • 14.0" diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900) with camera
  • 14.0" diagonal LED-backlit FHD anti-glare UWA slim (1920 x 1080)
  • 14.0" diagonal LED-backlit FHD anti-glare UWA slim (1920 x 1080) with camera
Touch
  • 14.0" diagonal LED-backlit FHD UWA slim (1920 x 1080) with camera
  • Touch panel has chemically-strengthened Corning Gorilla Glass 3 top cover
External:
Up to 32-bit per pixel color depth
VGA:
Port supports resolutions up to 1920 x 1200 external resolution at 75 Hz
DisplayPort
Supports resolutions up to 3840 x 2160 at 60Hz. Supports Multi-Stream Transport (MST) where three displays can be daisy chained with digital displays through DisplayPort Only. The full resolution of each display will be limited as you reach 3 displays due to the bandwidth limitations with a maximum resolution of:
  • 2560 x 1600 at 60 Hz for 2 displays
  • 1920 x 1200 at 60 Hz for 3 displays
Number of Displays supported
3 With Optional* 2013 UltraSlim Docking Station
*Sold separately
Storage and drives
Primary storage bay:
Solid State Drive*
  • 320 GB 7200 rpm SATA Hard Drive
  • 500 GB 7200 rpm SATA Hard Drive
  • 500 GB 7200 rpm Self-Encrypting Drive
  • 500 GB 5400 rpm Self Encrypting Drive (FIPS-140-2)
  • 1 TB 5400 rpm SATA Hard Drive
Solid State Drive*
  • 120 GB M.2 Solid State Drive
  • 128 GB SATA-3 Solid State Drive
  • 180 GB SATA-3 Solid State Drive
  • 180 GB SATA-3 Self-Encrypting Drive
  • 240 GB SATA-3 Solid State Drive
  • 256 GB SATA-3 Solid State Drive
  • 256 GB SATA-3 Self-Encrypting Drive
  • 256 GB M.2 PCIe Solid State Drive
  • 512 GB SATA-3 Solid State Drive
HP 3D DriveGuard (Windows only)
HP 3D DriveGuard mitigates the risk of hard drive failures, safeguarding your data when you are on the go by sensing sudden movement and protecting the hard drive. The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 30 GB (for Windows 8) of system disk is reserved for the system recovery software.
Flash cache
  • 32 GB M.2 (NGFF)
  • Optional 32 GB M.2 flash cache module support for Intel Smart Response Technology installed in the factory.
Available only with standard non-SED hard drive and non-solid state drives.
Memory
Standard:
  • DDR3L SDRAM (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 4 GB Total System Memory (4 GB x 1)
  • 8 GB Total System Memory (4 GB x 2)
    (Not available with Windows 7 Professional 32)
  • 8 GB Total System Memory (8 GB x 1)
  • 16 GB Total System Memory (8 GB x 2)
Maximum:
Upgradeable to 16 GB with optional 8 GB SODIMMs in slots 1 and 2*
Dual-channel:
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
* Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resource requirements.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking and Communications
Wireless
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Broadband Wireless (WWAN)*
  • HP lt4112 LTE/HSPA+ Qualcomm Gobi 4G Module
  • HP lt4211 LTE/EV-DO/HSPA+ Qualcomm Gobi 4G Module**
  • HP hs3110 HSPA+ Mobile Broadband Module
*WWAN is an optional feature sold separately or as an add on feature. WWAN connection requires wireless data service contract, network support, and is not available in all areas. Contact service provider to determine the coverage area and availability. Connection speeds will vary due to location, environment, network conditions, and other factors.
**4G LTE WWAN is an optional feature, not available on all products, in all regions and requires separately purchased service contract. Check with service provider for coverage and availability. Connection speeds will vary due to location, environment, network conditions, and other factors.
Wireless LAN (WLAN)*
  • Intel Dual Band Wireless-AC 7265 802.11 ac (2X2) Wi-Fi + Bluetooth
  • Intel Dual Band Wireless-7265AN 802.11 a/b/g/n (2X2) Wi-Fi + Bluetooth
  • Intel Dual Band Wireless-AC 3160 802.11 ac (1x1) Wi-Fi + Bluetooth
*Wireless access point and Internet service is required and is not included.
Availability of public wireless access points limited.
Communications
Intel I218LM Gigabit* Network Connection (10/100/1000 NIC)
*The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Optional Near Field Communication (NFC)
Audio
  • HD Audio with DTS Studio Sound
  • 2 Integrated stereo speakers
  • Integrated dual-microphone array; located in the display
  • Function keys for microphone mute, volume up, volume down
  • Stereo headphone/line out
  • Stereo microphone/line in
Optional* 720p HD** webcam
  • HD format (widescreen)
  • Supports videoconferencing (non-HD) and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
  • Skype-ready***
*Sold separately
**HD content required to view HD images
***Internet access required
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and includes an all-metal keyboard deck for greater rigidity, as well as HP DuraKeys. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. Backlit keyboard available as an option.
Pointing devices
Touchpad with scroll zone, on/off button with LED indicator, two-way scroll, two pick buttons.
Buttons and function keys
Separate discrete buttons provide easy access to WLAN on/off and speaker mute. Function keys provide control of features including: standby mode, display brightness, external display, microphone mute, volume down, and volume up.
System
Stand-alone power requirements (AC power)
Nominal operating
19.5 V
Average operating power
Windows 7 (64-bit): Integrated graphics: 4.75 W
Windows 8.1 (64-bit): Integrated graphics: 4.26 W
Max operating power:
  • Discrete: < 90 W
  • UMA: < 65W
Temperature
Operating
  • Not writing optical): 0° to 35° C (32° to 95° F)
  • Writing optical: 5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC compliance: Yes
  • ENERGY STAR: Select models
  • EPEAT: Registered Gold in United States
  • ICES: Yes
  • Australia/NZ A-Tick compliance: Yes
  • CCC: Yes
  • Japan VCCI compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
For accessibility information on HP products, please visit: http://www.hp.com/accessibility.
HDD
Networking / Communications
For storage drives, GB = 1 billion bytes. TN = 1 trillion bytes. Actual formatted capacity is less. Upt o 16Gb (for Windows 7) and up to 30GB (for Windows 8) of system disk is reserved for system recovery software.
Audio/Multimedia - DTS sound
Implementation: Realtek ALC3228 HD
Function key volume controls: Volume up, volume down, and mute
Full duplex: Yes
Microphone in: Stereo
Headphone/line out: Stereo
Integrated microphone: Yes, dual digital microphone array
Audio output quality
Frequency response: 20 Hz – 20 kHz
Signal to noise ratio: > 85 dB
Total harmonic distortion: 0.01%
Noise Floor: –110 dB
Play/Record sampling rate(s): 8 kHz – 48kHz
DAC: 16, 20, or 24-bit
ADC: 16 or 20-bit
Internal stereo speakers
Power rating: 2 W
Impedance: 4 Ohms
Power
Physical specifications
Dimensions (W x D x H)
Touch
33.9 x 23.7 x 2.26 (13.35 x 9.33 x 0.89 in) (at front)
Non-touch
33.9 x 23.7 x 2.1 (13.35 x 9.33 x 0.83 in) (at front)
Weights
Touch
Starting at 1.71 kg (3.76 lbs)
Non-touch
Starting at 1.55 kg (3.40 lbs)
Weight will vary by configuration.
Ports
  • DisplayPort 1.2: One
  • USB 3.0 Charging Port: One
  • USB 3.0 Port: Three
  • RJ-45 (Ethernet): One
  • Side Docking connector: One
  • Secondary battery connector: One
  • Headphone/Microphone Combo: One
  • AC Port: One
  • Media Card Reader
  • Supports SD, SDHC, SDXC
Software/OS
Preinstalled software with Windows operating system
Feature
BIOS
  • HP BIOSphere1
  • HP Sure Start
  • HP DriveLock | HP Automatic DriveLock
  • HP BIOS Protection2
  • HP Disk Sanitizer3
  • HP SpareKey4
  • BIOS Update via Network
  • Master Boot Record Security
  • Power On Authentication
  • Pre-Boot Security
  • Secure Erase5
  • Hybrid Boot
  • Measured Boot
  • Secure Boot
  • Absolute Persistence Module6
MultiMedia
  • Cyberlink Power DVD
  • CyberLink YouCam BE
Communications
  • HP Connection Manager with support for HP Mobile Connect (Windows 7 only)7
  • HP GPS and Location8
  • HP Mobile Connect (Windows 8 only)7
  • HP Wireless Hotspot9 (Windows 8 only)
  • Intel WiDi Software10
  • HP Roaming Alert
  • Intel My WiFi and Wireless Drivers
HP Value Add Software
  • Getting Started with Windows 8
  • HP 3D DriveGuard (Windows required)
  • HP ePrint Driver (HP Exclusive)11
  • HP Hotkey Support
  • HP PageLift
  • HP Recovery Manager (Windows 7 only)
  • HP Support Assistant
  • HP Recovery Disc Creator (Windows 7 only)
  • UEFI System Diagnostics W8
3rd party
  • Adobe Flash Player (Commercial)
  • Foxit PhantomPDF Express for HP
  • Bing Search
  • Skype12
  • Buy Office
Manageability
  • HP Driver Packs*
  • HP SoftPaq Download Manager (SDM)
  • HP System Software Manager (SSM)13
  • HP BIOS Config Utility (BCU)13
  • HP Client Catalog / HP CIK for Microsoft SCCM13
  • LANDESK Management*
For more information on HP Client Management Solutions refer to: http://www.hp.com/go/clientmanagement.
Standard Security Features
  • HP Client Security Manager (Windows only)
  • HP Device Access Manager
  • HP Drive Encryption14
  • HP File Sanitizer15
  • Microsoft Security Essentials (Windows 7 only)16
  • TPM Embedded Security Chip 2.0
  • Security lock slot
  • Fingerprint Reader
  • Integrated Smart Card Reader
  • Microsoft Defender (Windows 8.1 only)
For more information on HP Client Security Software Suite, refer to http://www.hp.com/go/clientsecurity.
1. Available only on business PCs with HP BIOS.
2. May require a manual recovery step if all copies of BIOS are compromised or deleted.
3. For the use cases outlined in the DOD 5220.22-M Supplement.Does not support solid state drives.
4. Requires initial user set up.
5. For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
6. Absolute agent is shipped turned off, and will be activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. For full details visit: http://www.absolute.com/company/legal/agreements/computrace-agreement. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
7. HP Mobile Connect is only available on selective devices with wwan. For geographical availability refer to www.hp.com/go/mobileconnect.
8. GPS access requires an unobstructed path to multiple satellites. Performance may be affected if/when used inside of buildings, bridges or heavily congested metropolitan areas. Requires separately purchased GPS navigation software available from multiple GPS applications.
9. The wireless hotspot application requires an active internet connection that is shared with the connecting devices. Wireless hotspot data usage may incur additional charges. Check with your service provider for plan details.
10. Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, tv or computer monitor with an integrated or external Wi-Di receiver. External Wi-Di receivers connect to the projector, tv or computer monitor via a standard HDMI cable, also sold separately.
11. Requires an Internet connection to HP web-enabled printer and HP ePrint account registration (for a list of eligible printers, supported documents and image types and other HP ePrint details, see www.hp.com/go/businessmobileprinting.
12. Skype is not offered in China.
13Not preinstalled.
14. Requires Windows. Data is protected prior to Drive Encryption login. Turning the PC off or into hibernate logs out of Drive Encryption and prevents data access.
15. For the use cases outlined in the DOD 5220.22-M Supplement. Supports standard Hard Drives. Initial setup required.
16. Opt in and internet connection required for updates.
Security
