    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
    Fix Windows 10 Update Issues
HP Printers - Google Cloud Print Compatible Printers
This document is for HP network-connected printers with an active Internet connection.
Confirm that your HP printer supports Google Cloud Print. To register and set up your printer to use the Google Cloud, go to Connecting and Using Google Cloud Print.
To quickly locate your printer model, click or scroll to the section for your printer model, and then hold down the CTRL and F keys. In the search box that displays, type the printer model number (example: 8612) and press Enter to find your printer.
