Control Panel Features for HP Color LaserJet Pro M252dw and M252n Printers
This document is for the HP Color LaserJet Pro M252dw and M252n printers.
The printer control panel includes multiple buttons to run the printer and a display to select print options.
2-line control-panel buttons (M252n model)
Review the following list to learn more about the printer control panel buttons.
Figure : Example of the 2-line control panel (M252n model)
Image: 2-line control panel (M252n model)
The following list describes the different functions of the control panel buttons.
1. 2-line control panel display
The display provides access to menus and printer information.
2. OK button
Press the OK button for the following actions:
  • Open the control panel menus
  • Select a menu item
  • Clear error messages
  • Start a print job
3. Left arrow ()
Use the arrow buttons to navigate through the menus or to increase or decrease a numeric value.
4. Right arrow ()
5. Back button ()
The button returns to the previous screen or menu.
6. Cancel button ()
The button cancels a print job or exits the control panel menus.
Touchscreen control panel buttons and icons M252dw model)
Review the following list to learn more about the printer control panel buttons and icons.
Figure : Example of the touchscreen control panel (M252dw model)
Image: Touchscreen control panel (M252dw model)
The following list describes the different functions of the control panel buttons and icons:
1. Back button ()
The button returns to the previous screen or menu. The button lights up when the feature is available.
2. Home button ()
The button returns the control panel display to the Home screen, which is the screen that displays when you first turn on the printer. The button lights up when the feature is available.
3. Help button ()
The button opens the Help menu for the current operation. The button lights up when the feature is available.
4. Color touchscreen display
The display provides access to menus, help animations, and printer information.
5. Home page screen indicator
Indicates which Home screen the control panel is currently displaying.
During many processes, a Cancel button displays on the touchscreen.
Touchscreen control panel display menus (M252dw model)
Touch the control panel display to select print options from a menu. Swipe your finger across the display to scroll through the menus.
The features that display on the Home screen can vary, depending on your printer configuration.
Figure : Example of the Home screen menus
Image: Home screen view
The following list describes the print options:
1. Reset button
Touch this button to reset any settings to the default settings.
2. Connection Information icon ( / )
Touch this icon to open the Connection Information menu, which provides network information. The icon displays as either a wired network icon () or a wireless network icon (), depending on your connection type.
3. Product status
This screen displays information about the current status of the printer.
4. USB icon ()
Touch this icon to open the USB Flash Drive menu.
5. Supplies icon ()
Touch this icon to check the status of your printer's toner cartridges.
6. Apps icon ()
Touch this icon to open select Web Services features.
7. Setup icon ()
Touch this icon to change printer preferences and use tools to perform maintenance tasks.
