Sprout by HP - HPLandingShell has stopped working, Sprout applications unavailable
The following message appears when starting the Sprout by HP:
This occurs after uninstalling the Sprout Platform software. The Sprout by HP can still be used as a normal all-in-one computer but no Sprout related software or hardware can be used.
Use Windows 8 Recovery Manager to restore Sprout functionality on your Sprout by HP:
  1. From the Start screen, type recovery to open the Search charm, and then click Recovery Manager in the search results.
    If prompted for an administrator password or confirmation, type the password or provide confirmation.
    or
    If prompted by User Account Control to allow the program to make changes to the computer, click Yes.
  2. In Recovery Manager under I need help immediately, click Software Program Reinstallation.
    Figure : Recovery Manager
    Recovery Manager with Software Program Reinstallation selected
  3. On the Software Program Reinstallation screen, click Next.
    Figure : Software Program Reinstallation
    Software Program Reinstallation with Next selected
  4. Select Sprout Complete under Factory installed programs, then click Next.
    Figure : Factory installed programs
  5. Wait while Recovery Manager reinstalls the program.
  6. When the Reinstallation complete is displayed, select Yes to restart the computer, then click Finish.
  7. The computer restarts and the Sprout Applications and hardware are functional on your Sprout by HP.
