HP Z440 Workstation Specifications
Product image
HP Z440 Workstation
Product features
Feature
Intel® C612 Chipset
Graphics
  • NVIDIA NVS 310 512MB Graphics
  • NVIDIA NVS 315 1GB Graphics
  • NVIDIA NVS 510 2GB Graphics
Graphics Cable Adapters
  • HP DisplayPort to Dual Link DVI Adapter
  • HP DisplayPort To DVI-D Adapter
  • HP DisplayPort To DVI-D Adapter (2-Pack)
  • HP DisplayPort To DVI-D Adapter (4-Pack)
  • HP DisplayPort To DVI-D Adapter (6-Pack)
  • HP DisplayPort To VGA Adapter
  • HP DisplayPort To VGA Adapter 2nd
Storage/Hard drives
SAS Hard Drives for HP Workstations:
  • 600GB SAS 15K rpm 6Gb/s 3.5" HDD
  • 300GB SAS 15K rpm 6Gb/s 3.5" HDD
  • HP 1.2TB SAS 10K SFF HDD
  • HP 600GB SAS 10K SFF HDD
  • HP 300GB SAS 10K SFF HDD
*For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB of system disk is reserved for system recovery software.
Up to (4) 3.5-inch 15K rpm SAS drives: 300, 600 GB; 2.4 TB max
Up to (4) 2.5-inch 10K rpm SAS drives: 300, 600 GB, 1.2 TB; 4.8 TB max
SAS controller add-in card required
3rd and 4th SFF SAS HDDs will be automatically installed into a single 2:1 5.25" external bay adapter
Removable Boot Drive option
SATA Hard Drives:
  • 500GB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 1TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 2.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 3.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 500GB SATA 7.2K SED SFF HDD
Up to (4) 3.5-inch 7200 rpm SATA drives: 500 GB, 1.0, 2.0, 3.0, 4.0* TB; 16.0 TB max
Up to (1) 2.5-inch SATA Self-Encrypting Drive (SED): 500 GB Opal 1
*4TB drive planned to be available late 2014
SATA Solid State Drives:
  • HP 128GB SATA 6Gb/s SSD
  • HP 256GB SATA 6Gb/s SSD
  • HP 512GB SATA 6Gb/s SSD
  • HP 1TB SATA 6Gb/s SSD
  • HP 256GB SATA 6Gb/s SED SSD
  • Intel Pro 1500 180GB SATA SSD
  • Samsung Enterprise 240GB SATA SSD
  • Samsung Enterprise 480GB SATA SSD
Up to (4) 2.5-inch 6Gb/s SATA Solid State Drives: 128, 256, 512 GB, 1 TB; 4.0 TB max
Up to (1) 2.5-inch 6Gb/s SATA Self-Encrypting Solid State Drive (SED SSD): 256 GB Opal 2
Up to (4) 2.5-inch Intel Pro 1500 6Gb/s SATA Solid State Drive: 180 GB; 720 GB max
Up to (4) 2.5-inch Samsung Enterprise 6Gb/s SATA Solid State Drives: 240, 480 GB; 1.9 TB max
3rd and 4th SSDs will be automatically installed into a single 2:1 5.25" external bay adapter
PCIe Solid State Drives:
  • HP Z Turbo Drive 512GB SSD
  • HP Z Turbo Drive 256GB SSD
Up to (2) PCI Express Solid State Drives: 256, 512 GB; 1.0 TB max
PCIe SSDs are not available with SAS controller and/or HDDs
Hard Drive Controllers
  • Integrated SATA 6.0 Gb/s Controller
  • RAID 0 Configuration – Striped Array
  • RAID 0 Data Configuration -- Boot/OS Drive + 2 Drive Striped Array
  • RAID 1 Configuration – Mirrored Array
  • RAID 10 Configuration - Striped/Mirrored Array
  • LSI 9217-4i4e 8-port SAS 6Gb/s RAID Card
SATA hardware RAID is supported on Linux systems that have support for the Intel RSTe technology.
The Linux kernel, with built-in software RAID, provides excellent functionality and performance. It is a good alternative to hardware-based RAID. Please visit Hardware Support Matrix for Linux for RAID capabilities with Linux.
All drives must be identical in type and capacity.
RAID arrays greater than 2 TB are fully supported.
1 Requires hard drives with identical speed, capacity, and interface. Specific user-configured hardware SAS RAID configurations are supported on this Linux system. For details, please visit Hardware Support Matrix for Linux.
2 Specific user-configured hardware SAS RAID configurations are supported on this Linux system.
IS: Striping of 2 or more HDDs into a single logical volume
IM: Mirroring of 2 HDDs into a single logical volume
IME: Mirroring of 3 or more HDDs into a single logical volume.
Memory
4GB DDR4-2133 ECC Registered RAM
8GB DDR4-2133 ECC Registered RAM
16GB DDR4-2133 ECC Registered RAM
For details on the supported memory configurations on the HP Z440 Workstation, please refer to the System Technical Specifications - System Board section of this document.
Each processor supports up to 4 channels of DDR4 memory. To realize full performance at least 1 DIMM must be inserted into each channel.
The CPUs determine the speed at which the memory is clocked. If an 1866MHz capable CPU is used in the system, the maximum speed the memory will run at is 1866MHz, regardless of the specified speed of the memory.
1 ONLY registered DDR4 DIMMs are supported. DDR3 DIMMs ARE NOT SUPPORTED.
2 Configurations of greater than 4x memory DIMMs require the HP Z440 Memory Cooling Solution, which is available both CTO (J2R51AV) and AMO (J2R52AA).
Networking/Communications
Integrated Intel I218LM PCIe GbE Controller
Intel Ethernet I210-T1 PCIe NIC
HP X520 10GbE Dual Port Adapter
HP 10GbE SFP+ SR Transceiver
HP 361T PCIe Dual Port Gigabit NIC
Intel 7260 802.11 a/b/g/n PCIe WLAN NIC
"Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
*Wireless access point and internet service required. Availability of public wireless access points limited.
Audio/Multimedia
Integrated Realtek HD ALC221 Audio
Input Devices
Keyboard:
  • HP PS/2 Keyboard
  • HP USB Keyboard
  • HP USB Smart Card Keyboard
  • HP Wireless Keyboard and Mouse
Mice:
  • HP PS/2 Mouse
  • HP USB Optical Mouse
  • HP USB 1000dpi Laser Mouse
  • HP USB Optical 3-Button 2.9M OEM Mouse
  • HP SpaceMouse Pro USB 3D Input Device
  • HP SpacePilot Pro 3D USB Intelligent Controller
Power specifications
Specification
Power Supply
  • 700W 90% Efficient, Custom PSU
    (Wide-Ranging, Active PFC)
  • 525W 85% Efficient, Custom PSU
Operating Voltage Range
90–269 VAC
Rated voltage range
  • 100 - 240 VAC
  • 118 VAC
Rated line frequency
  • 50–60 Hz
  • 400 Hz
Operating line frequency range
  • 47–66 Hz
  • 393–407 Hz
Rated input current
  • 100-240V @ 9.5A
  • 100-240V @ 9.5A
Heat Dissipation
(Configuration and software dependent)
700W
  • Typical: 1648 btu/hr (415 kg-cal/hr)
  • Maximum: 2746 btu/hr (692 kg-cal/hr)
525W
  • Typical: 1311 btu/hr (330 kg-cal/hr)
  • Maximum: 2185 btu/hr (551 kg-cal/hr)
Power Supply Fan
92x25 mm variable speed
ENERGY STAR Qualified (Configuration dependent)
Yes
Power supply fan
80 PLUS® Compliant
925W
  • Yes, 90% Efficient
  • The Z640 925W power supply efficiency report can be found at this link: TBD
525W
  • Yes, 85% Efficient
  • The Z440 525W power supply efficiency report can be found at this link: TBD
FEMP Standby Power Compliant @115V
(<2W in S5 – Power Off)
Yes
EuP Compliant @ 230V
(<0.5W in S5 - Power Off)
Yes
CECP Compliant @ 220V
(<4W in S3 - Suspend to RAM)
Yes; Configuration dependent
Power Consumption in sleep mode
(as defined by ENERGY STAR) – Suspend to RAM (S3) (Instantly Available PC)
<15w
Built-in Self-Test LED
Yes
Surge Tolerant Full Ranging Power Supply
(withstands power surges up to 2000V)
Yes
Graphics specifications
Specification
Form factor
Low Profile:
  • 2.7 inches (H) x 5.7 inches (L), Half-Height
142 grams
Graphics controller
NVIDIA NVS 310
GPU: GF119-825
Connectors
2x DisplayPort
Bus type
PCI Express x16, 2.0 compliant
Memory
  • Size: 512MB DDR3
  • Clock: 875Mhz
Connectors
2 x DisplayPort
Maximum Resolution
Up to 2560 x 1600 (digital display) per display
Image Quality Features
The following video formats are supported:
  • MPEG2
  • MPEG4 Part 2 Advanced Simple Profile
  • H.264 SVC codec support
  • Support for 3D Blu Ray
  • VC1
  • DivX version 3.11 and later
  • MVC
A full range of video resolutions are supported including 1080p, 1080i, 720p, 480p and 480i. The NVS 310 GPU provides hardware acceleration for the computationally intensive parts of video processing, as well as provides improved video playback speeds via faster decode and transcode.
Display Output
Up to 2 displays in the following configurations:
DisplayPort output:
  • Drives two DisplayPort enabled digital display at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected natively using the 2 DisplayPort connectors on the NVS 310 graphics card
  • Supports 2 monitors up to resolution of 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort 1.2 multi stream topology technology.
DVI-D output:
  • Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors
  • Drives two digital display at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors
HDMI output:
  • NVS 310 is capable of driving two high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors
VGA display output:
  • Drives two analog display at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptor
Shading Architecture
Shader Model 5.0
Supported Graphics APIs
DX11, OpenGL 4.1
Available Graphics Drivers
Windows 8
Genuine Windows 7 Professional (64-bit and 32-bit)
Microsoft Windows XP Professional (64-bit and 32-bit)
Red Hat Enterprise Linux(RHEL)
SUSE Linux Enterprise Desktop 11 (64-bit and 32-bit)
HP qualified drivers may be preloaded or the latest HP qualified drivers are available from the HP Software and Drivers.
SUSE Linux Enterprise drivers may also be obtained from NVIDIA website.
1 The thermal solution used on this card is an active fan heatsink.
2 Factory configured NVS 310 graphics card have no cable adpaters included. Adapters must be ordered separately.
3 Option kit NVS 310 includes 2 DP to DVI-D cable adapters.
NVIDIA NVS 315 1GB Graphics (for HP Workstations)
Specification
Form factor
Low Profile:
  • 2.713 inches in height × 5.7 inches in length
  • Weight: ~ 142 grams
Graphics controller
NVIDIA NVS 315 (using GF119-825 GPU)
Number of Cores: 48 CUDA cores
Max. Power: 19.3W
Cooling Solution: Active fan heatsink
Bus Type
Memory
  • Size: 1GB DDR3
  • Clock: 875Mhz
  • Memory Bandwidth: 14GB/s
Connectors
DMS-59 output
Cables included:
  • For CTO: DMS-59 to DVI cable
  • For AMO: DMS-59 to DVI cable and DMS-59 to VGA cable
Maximum Resolution
Maximum number of displays supported: 2
Maximum Resolution Support:
  • DMS-59 to VGA: 2048 x 1536 @ 85Hz
  • DMS-59 to DVI: 1980 x 1200 @ 60Hz
  • DMS-59 to DP: 2560 x 1600 @ 60Hz
See Display Output section.
  • MPEG2
  • VC1
A full range of video resolutions are supported including 1080p, 1080i, 720p, 480p and 480i. The NVS 315 GPU provides hardware acceleration for the computationally intensive parts of video processing, as well as provides improved video playback speeds via faster decode and transcode.
Display Output
Up to 2 displays using one of the following DMS-59 cables:
  • DMS-59 to DVI
  • DMS-59 to VGA
  • DMS-59 to DP
DisplayPort output:
  • Drives two DisplayPort enabled digital displays at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected via the DMS-59 to DP adapter.
DVI-D output:
  • Drives two digital displays at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DMS-59 to DVI-D single-link cable adaptor
VGA display output:
  • Drives two analog displays at resolutions up to 2048 × 1536 at 85 Hz using DMS-59 to VGA cable adaptor.
Shader Model 5.0
DX11, OpenGL 4.3
Windows 8
Red Hat Enterprise Linux (RHEL)
2 Factory configured NVS 310 graphics card have no cable adapters included. Adapters must be ordered separately.
3 Option kit graphics card includes DMS-59 to DVI and DMS-59 to VGA cables (one each).
Specification
Form factor
Low Profile, 2.713 inches × 6.3 inches, single slot
Graphics controller
  • NVS 510 GPU
  • Core Clock: 797 MHz
  • Memory Clock: 891 MHz
  • CUDA Cores: 192
Connectors
  • Four mini-DisplayPort
  • Four mini-DisplayPort-to-DisplayPort adapters included
  • (DisplayPort to DVI-D, DisplayPort to VGA, DisplayPort to HDMI, and DisplayPort to Dual-Link DVI adapters available as separate accessories)
Memory
2GB DDR3
Bus type
PCI Express x16, Generation 2.0
Maximum Resolution
Mini-DisplayPort connectors support ultra-high-resolution panels (up to 3840 x 2160 @ 60Hz)
This card supports up to four displays. For Windows XP, only 2 active displays are supported.
10-bit internal display processing, including hardware support for 10-bit scan-out
Display Output
DisplayPort with Multi-Stream Technology (MST) and High Bit Rate 2 (HBR2) support.
Digital Display Support
  • DisplayPort Output
    • Drives four DisplayPort enabled digital display at resolutions up to 3840 × 2160 at 60 Hz with reduced blanking, when connected natively using the 4 DisplayPort connectors on the NVS 510 graphics card.
    • DisplayPort Multi-Stream Topology (MST) Technology: Supports various combinations of display resolutions and number of displays when using DisplayPort multi stream topology technology - up to a maximum of 4 monitors at a resolution of 1920 × 1200 at 60 Hz with reduced blanking.
  • DVI-D Output
    • Drives four digital displays at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors.
    • Drives four digital displays at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors.
  • HDMI Output
    The NVS 510 graphics board is capable of driving four high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors.
Analog Display Support
VGA display output:
  • Drives four analog displays at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors.
Full Microsoft DirectX 11, Shader Model 5.0 support
Full OpenGL 4.3 support
Red Hat Enterprise Linux(RHEL) 6 Desktop/Workstation
Heatsink cooler design is active.
Specification
Form factor
Graphics controller
  • NVS 510 GPU
  • CUDA Cores: 192
Connectors
Memory
2GB DDR3
Bus type
Maximum Resolution
Display Output
DisplayPort Output
  • DisplayPort Multi-Stream Topology (MST) Technology: Supports various combinations of display resolutions and number of displays when using DisplayPort multi stream topology technology – up to a maximum of 4 monitors at a resolution of 1920 × 1200 at 60 Hz with reduced blanking.
DVI-D Output
HDMI Output
  • The NVS 510 graphics board is capable of driving four high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors.
VGA display output
  • Full Microsoft DirectX 11, Shader Model 5.0 support
  • Full OpenGL 4.3 support
  • Genuine Windows 7 Professional (64-bit and 32-bit)
  • Microsoft Windows XP Professional (64-bit and 32-bit)
  • Red Hat Enterprise Linux (RHEL) 6 Desktop/Workstation
  • SUSE Linux Enterprise Desktop 11 (64-bit and 32-bit)
HP qualified drivers may be preloaded or available from the HP Software and Drivers.
NVIDIA Quadro K620 2GB Graphics
Specification
Form factor
  • 2.713” H x 6.3” L
  • Single Slot, Low Profile
  • Full Height Profile bracket installed
  • Low Profile bracket included
  • Weight: 133 grams
Graphics controller
  • NVIDIA Quadro K620 Graphics Card
  • GM107 GPU
  • 384 CUDA cores
  • Max Power: 45 Watts
Connectors
  • 1 DL-DVI(I) output, 1 DisplayPort output
  • Factory Configured: No video cable adapter included
  • Option Kit: One DP-to-DVI adapter included with card
Additional DVI-to-VGA, DisplayPort-to-VGA or DisplayPort-to-DVI adapters are available as Factory Configuration or Option Kit accessories.
Memory
  • 2 GB GDDR3, 900 MHz
  • 128-bit memory I/O path
  • 29 GB/s memory bandwidth
Bus type
PCI Express 2.0 x16
Maximum Resolution
DisplayPort 1.2:
  • up to 4096x2160 x 30 bpp @ 60Hz
  • supports High Bit Rate 2 (HBR2) and Multi-Stream Transport (MST)
Dual Link DVI(I) output:
  • up to 2560 x 1600 x 32 bpp @ 60Hz
Single Link-DVI(I) output:
  • up to 1920 x 1200 x 32 bpp @ 60Hz
  • 10-bit internal display processing pipeline
  • 10-bit scan-out support
Display Output
  • 1 Dual-link DVI-I connector
  • 1 Display Port connector
Full Microsoft DirectX 11.1 Shader Model 5.0
  • OpenGL 4.4
  • DirectX 11.1
  • API support includes:
    • CUDA C
    • CUDA C++
    • DirectCompute 5.0
    • OpenCL
    • Java
    • Python
    • Fortran
  • Microsoft Windows 8.1
  • Microsoft Windows 7
  • Linux
1 Factory configured Quadro K620 does not include a video cable adapter. Video cable adapters must be ordered separately.
2 Quadro K620 offered as an Option Kit (AMO) includes one DP-to-DVI video cable adapter. Additional cables must be ordered separately.
NVIDIA Quadro K420 1GB Graphics
Specification
Form factor
Low Profile:
  • 2.713 inches × 6.3 inches, single slot
Graphics controller
  • NVIDIA Quadro K420
  • GPU: GK107
Bus Type
Memory
  • Size: 1GB DDR3
  • Clock: 891MHz
  • Memory Bandwidth: 29GB/s
Connectors
  • One dual-link DVI-I connector
  • One DisplayPort connector
Maximum Resolution
VGA (via adapter cable):
  • 2048 × 1536 × 32 bpp at 85 Hz
Dual-link DVI
  • 2560 × 1600 × 32 bpp at 60 Hz (reduced blanking)
Single-link DVI
  • 920 × 1200 × 32 bpp at 60 Hz (reduced blanking)
DisplayPort 1.2
  • 3840 × 2160 × 30 bpp at 60 Hz
RAMDAC
400 MHz integrated RAMDAC
Display Output
Shader Model 5.0
DX11, OpenGL 4.4
Programming support for CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Python, and Fortran
Notes
1 Factory configured Quadro K420 does not include any video adapters. Adapters must be ordered separately.
2 Option kit Quadro K420 includes one DP to DVI-D adapter.
NVIDIA Quadro K2200 4 GB Graphics
Specification
Form factor
4.38" H x 7.97" L
Single Slot, Full Height
Weight:
240 grams
Graphics controller
  • NVIDIA Quadro K2200 Graphics Card
  • GM107 GPU
  • 640 CUDA cores
  • Max Power: 67.7 Watts
Bus Type
PCI Express 2.0 x16
Memory
  • 4 GB GDDR5, 2500 Mhz
  • 80 GB/s memory bandwidth
Connectors
  • 1 DL-DVI(I) output, 2 DisplayPort outputs
  • Factory Configured Option: No video cable adapter included
Additional DVI-to-VGA, DisplayPort-to-VGA or DisplayPort-to-DVI adapters are available as accessories
Maximum Resolution
DisplayPort:
  • up to 4096 x 2160 x 30 bpp @ 60Hz
DL-DVI(I) output:
Display Output
VGA:
  • requires use of DVI-to-VGA and/or DP-to-VGA video cable adapters
  • 400 MHz integrated RAMDAC
  • Max resolution: 2048 x 1536 x 32 bpp @ 85 Hz
DL-DVI(I):
  • Max resolution: 2560 x 1600 x 32 bpp @ 60 Hz
SL-DVI(I):
  • Max resolution: 1920 x 1200 x 32 bpp @ 60 Hz
DisplayPort:
  • Supports HBR2 and MST
  • Max resolution: 4096 x 2160 x 30 bpp @ 60 Hz (only one monitor can be connected to a Quadro K2200 DisplayPort connector at this resolution)
  • Max number of DisplayPort daisy-chained monitors or hub connected monitors from a single Quadro K2200 DisplayPort connector: 4 with maximum resolution of 1920 x 1200
Maximum number of monitors across all available Quadro K2200 outputs is 4.
  • OpenGL 4.4
  • DirectX 11.1
    • CUDA C
    • CUDA C++
    • DirectCompute 5.0
    • OpenCL
    • Java
    • Python
    • Fortran
  • Linux
1 Quadro K2200 offered as Factory Configured Option does not include a video cable adapter. Video cable adapters must be ordered separately.
2 Quadro K2200 offered as an Option Kit includes one DP-to-DVI video cable adapter. Additional cables must be ordered separately.
3 A total maximum of 4 active monitors are supported across all display output types. This may be accomplished by using daisy chained DisplayPort 1.2 displays or a DisplayPort 1.2 hub device.
4 A DisplayPort hub device may be used to connect multiple DisplayPort monitors to a single Quadro K2200 DisplayPort output.
AMD FirePro W2100 2GB Graphics
Specification
Form factor
Low Profile, half length (full-height bracket included)
Graphics controller
AMD FirePro™ W2100 professional graphics
Power: <50W
Cooling: Active
Bus Type
PCI Express® x8, Generation 3.0
Memory
2GB DDR3 memory
Memory Bandwidth: 14.4 GB/s
Connectors
2x Display Port 1.2 connectors
Additional DisplayPort-to-VGA or DisplayPort-to-DVI adapters are available as Factory Configuration or Option Kit accessories.
Maximum Resolution
DisplayPort 1.2:
Dual Link DVI(I) (requires adapter cable):
Single Link-DVI(I)(requires adapter):
VGA(requires adapter):
Display Output
2 x DisplayPort® 1.2
Shader Model 5.0
OpenCL™ 1.2, DirectX® 11 and OpenGL 4.4
Windows 8.1 (64-bit and 32-bit)
Windows 7 (64-bit and 32-bit)
SUSE Linux Enterprise Desktop 11(64-bit and 32-bit)
Ubuntu
HP qualified drivers may be preloaded or available from the the HP Software and Drivers.
Notes
Depending on the card model, native DisplayPort™ connectors and/or certified DisplayPort™ active or passive adapters to convert your monitor’s native input to your card’s DisplayPort™ or Mini-DisplayPort™ connector(s) may be required. See www.amd.com/firepro for details
NVIDIA Quadro K4200 4GB Graphics
Specification
Form factor
4.376” H x 9.5” L
~458 grams (without extender)
Graphics controller
NVIDIA Quadro K4200 Graphics Card
Kepler GK104 GPU
1344 CUDA cores
Max Power: 108 Watts
Bus Type
PCI Express 2.0 x16
Memory
4 GB GDDR5, 2700 MHz
256-bit memory I/O path
173 GB/s memory bandwidth
Connectors
CTO: No video cable adapter included
AMO: One DP-to-DVI adapter included with card
Maximum Resolution
DisplayPort:
  • up to 3840 x 2160 x 30 bpp @ 60Hz
DL-DVI(I) output:
Display Output
VGA:
DL-DVI(I):
SL-DVI(I):
DisplayPort:
  • Max resolution: 3840 x 2160 x 30 bpp @ 60 Hz (only one monitor can be connected to a Quadro K4200 DisplayPort connector at this resolution)Max resolution: 3840 x 2160 x 30 bpp @ 60 Hz (only one monitor can be connected to a Quadro K4200 DisplayPort connector at this resolution)
  • Max number of DisplayPort daisy-chained monitors or hub connected monitors from a single Quadro K4200 DisplayPort connector: 4 with maximum resolution of 1920 x 1200
  • Requires use of DP-to-HDMI cable
  • Max Resolution: 1920 x 1080 x 32 bpp @ 60Hz
HDMI:
Maximum number of monitors across all available Quadro K4200 outputs is 4.
Full Microsoft DirectX 11 Shader Model 5.0
  • OpenGL 4.4
  • DirectX 11.1
    • CUDA C,
    • CUDA C++
    • DirectCompute 5.0
    • OpenCL
    • Java
    • Python
    • Fortran
  • Linux
Notes
1 Quadro K4200 offered as CTO does not include a video cable adapter. Video cable adapters must be ordered separately.
2 Quadro K4200 offered as AMO includes one DP-to-DVI video cable adapter. Additional cables must be ordered separately.
4 A DisplayPort hub device may be used to connect multiple DisplayPort monitors to a single Quadro K4200 DisplayPort output.
NVIDIA Quadro K5200 8GB Graphics
Specification
Form factor
4.376” H x 10.5” L
Dual Slot
~880 grams
Graphics controller
NVIDIA Quadro K5200
GK 110 GPU
2304 CUDA cores
Max Power: 150 Watts
Bus Type
PCI Express 3.0 x16
Memory
8GB GDDR5
192 GB/s memory bandwidth
Connectors
DVI-I (1), DVI-D (1), DP (2)
Factory configured option: No adapter included with card.
Option Kit: No adaptor included with card.
DVI to VGA, DisplayPort to VGA, DisplayPort to DVI, and DisplayPort to Dual-Link DVI adapters available as accessories.
  • DisplayPort with Multi-Stream Technology (MST) and High Bit Rate 2 (HBR2), HDMI 1.4, and HDCP support
  • NVIDIA 3D Vision™ technology
Display Output
  • Maximum resolution over VGA (through DVI to VGA cable): 2048 × 1536 × 32 bpp at 85 Hz
Dual-link internal TMDS (DVI 1.0)
  • Maximum resolution over digital port (single GPU and SLI mode): 2560 × 1600 × 32 bpp at 60 Hz (reduced blanking)
Single-link internal TMDS (DVI 1.0)
  • Maximum resolution over digital port (single GPU and SLI mode):1920 × 1200 × 32 bpp at 60 Hz (reduced blanking)
DisplayPort with MST and HBR2
  • Maximum resolution: 4096 × 2160 × 30 bpp at 60Hz
  • Maximum resolution:2560 x 1600 x 30bpp at 120Hz
HDMI:
  • Maximum resolution: 1920 × 1080 × 32 bpp at 60Hz
Shader Model 5.0
OpenGL 4.4
DirectX 11
API support for NVIDIA’s CUDA ™ C, CUDA C++, DirectCompute 5.0, OpenCL, Java, Python, and Fortran
Windows 8
Red Hat Enterprise Linux (RHEL) 6 Desktop/Workstation (64-bit)
SUSE Linux Enterprise Desktop 11 SP3(64-bit and 32-bit)
Notes
1 NVIDIA GRID VGX Pass Through feature supported on NVIDIA Quadro K5200 to enable direct mapping of GPU to Virtual Machine.
2 No display output adapter included.
NVIDIA Quadro K6000 12GB Graphics
Specification
Form factor
4.376” H x 10.5” L
Dual Slot
Power: 234 Watts
~880 grams
Graphics controller
NVIDIA Quadro K6000 Graphics Card based on the GK180 GPU
Core Count: 2880
Base Clock: 797 MHz
Boost Clock: 902 MHz
Bus Type
PCI Express 3.0 x16
Memory
12GB GDDR5
384-bit memory I/O path
288 GB/s memory bandwidth
ECC Memory
Connectors
DVI-I (1), DVI-D (1), DP (2), Optional 3D Stereo bracket with 3-pin mini-DIN connector.
  • NVIDIA Premium Mosaic and nView
Display Output
  • Maximum resolution: 3840 × 2160 × 36 bpp at 60Hz
HDMI:
  • Shader Model 5.0
  • Full IEEE 764-2008 32-bit and 64-bit precision
Full OpenGL 4.3
Full DirectX 11
CUDA API support includes:
  • CUDA C
  • CUDA C++
  • DirectCompute 5.0
  • OpenCL
  • Java
  • Python
  • Fortran
Windows 8
Novell SUSE Linux Enterprise drivers may also be obtained from NVIDIA website.
Notes
1 NVIDIA GRID VGX Pass Through feature supported on NVIDIA Quadro K6000 to enable direct mapping of GPU to Virtual Machine.
High performance GPU computing
NVIDIA Tesla K40 Workstation Compute Processor
Factory Configured
Option Kit
Form Factor
  • Size: 4.376 inches by 10.5 inches
  • Slots: Dual Slot
  • Power Connectors: One 6-pin and one 8-pin
~826 grams
System Interface
PCI Express Gen3 ×16
Video Outputs
None
Memory
  • 12GB GDDR5
  • memory path: 384-bit
  • memory clock: 3Ghz
Peak Memory Bandwidth
288 GB/s
Supported APIs
CUDA, OpenACC, OpenCL 1.2 API support includes:
  • C
  • C++
  • Java
  • Python
  • Fortran
Supported Operating Systems
  • Windows 8 (64-bit)
  • Genuine Windows 7 Professional (64-bit)
  • Red Hat Enterprise Linux (RHEL) 5, 6 Desktop/Workstation (64-bit)
  • SUSE Linux Enterprise Desktop 11 (64-bit)
Processor Cores
  • GK110B GPU
  • Base Clock: 745 MHz
  • Boost Clock: up to 875 MHz
  • 2888 CUDA cores
Power Consumption
~235 Watts
A 700W PSU is required for any K40 configuration on the Z440.
Multimedia and audio devices
Factory Configured
Option Kit
Yes
No
Storage and hard drives
HP SAS (Serial Attached SCSI) Hard Drives for HP Workstations
Specification
Capacity
600GB
Height
2.54 cm (1 in)
  • Media Diameter 8.9 cm (3.5 in)
  • Physical Size 10.17 cm (4 in)
Interface
SAS
Synchronous Transfer Rate (Maximum)
6.0 Gb/s
Buffer
16 MB
Seek time (typical reads, includes controller overhead, including settling)
  • Single Track 0.2 ms
  • Average 3.4 ms
  • Full Stroke 6.6 ms
Rotational Speed
15,000 rpm
Logical Blocks
1,172,123,568 - 512 byte blocks
Operating temperature
10° to 35° C (50° to 95° F)
Specification
Capacity
300GB
Height
2.54 cm (1 in)
Width
  • Physical Size 0.17 cm (4 in)
Interface
SAS
6Gb/s
Buffer
16MB
Seek Time (typical reads, includes controller overhead, including settling)
  • Average 3.4 ms
Rotational Speed
15,000 rpm
Specification
Capacity
300GB
Height
1.53 cm (0.6 in)
Width
  • Media Diameter 6.36 cm (2.5 in)
  • Physical Size 6.99 cm (2.75 in)
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
64MB
Cache
multi-segmentable cache buffer
  • Single Track 0.4 ms (max)
  • Average 3.6 ms
  • Full Stroke 7.3 ms
Rotational Speed
10,000 rpm
Logical Blocks
585,937,500
5° to 55° C (41° to 131° F)
Specification
Capacity
600GB
Height
1.53 cm (0.6 in)
Width
  • Media Diameter: 6.36 cm (2.5 in)
  • Physical Size: 6.99 cm (2.75 in)
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
64MB
Cache
  • Single Track: 0.4 ms (max)
  • Average: 3.6 ms
  • Full Stroke: 7.3 ms
Rotational Speed
10,000 rpm
Logical Blocks
1,172,123,568
Specification
Capacity
1.2TB
Height
1.53 cm (0.6 in)
Drive Type
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
64MB
Cache
Number of Sectors
976,773,168
  • Single Track: 0.18ms (max)
  • Average: 3.5ms
  • Full Stroke: 7.17ms
Rotational Speed
10,000 rpm
Logical Blocks
2,344,225,968
Operating Temperature
SATA (Serial ATA) Hard Drives for HP Workstations
Specification
Capacity
500GB
Height
2.54 cm (1 in)
Width
  • Media Diameter: 8.9 cm (3.5 in)
  • Physical Size: 10.17 cm (4 in)
Interface
Serial ATA (6.0Gb/s), NCQ enabled
Up to 600MB/s
Buffer
16MB
  • Single Track: 2 ms
  • Average: 11 ms
  • Full Stroke: 21 ms
Rotational Speed
7,200 rpm
Logical Blocks
976,773,168
Specification
Capacity
1TB
Height
2.54 cm (1 in)
Width
Interface
  • Serial ATA (6.0Gb/s)
  • NCQ enabled
Up to 600 MB/s
Buffer
64MB
Cache
Adaptive
  • Average: 11 ms
Rotational Speed
7,200 rpm
Specification
Capacity
2 TB
Height
2.54 cm (1 in)
Width
Interface
Serial ATA (6.0 Gb/s), NCQ Enabled
Up to 600MB/s
Buffer
64MB
  • Single Track: 1.0 ms
  • Average: 11 ms
  • Full Stroke: 18 ms
Rotational Speed
7,200 rpm
Logical Blocks
3,907,029,168
Specification
Capacity
3.0 TB
Height
2.54 cm (1 in)
Width
  • Physical Size: 10.17 cm (4.0 in)
Interface
Up to 6.0 Gb/s
Buffer
64 MB
  • Single Track: 6 ms
  • Average: 11 ms
  • Full Stroke: Not specified
Rotational Speed
7200 rpm
5° to 60° C (41° to 140° F)
HP Solid State Drives (SSDs) for Workstations
Specification
Capacity
128 GB
Height
0.7 cm (0.28 in)
Width
Physical Size: 6.36 cm (2.5 in)
Interface
SATA 6Gb/s
Up to 500MB/s (Sequential Read)
0° to 70° C (32° to 158° F)
Specification
Capacity
256 GB
Height
0.7 cm (0.28 in)
Interface
SATA 6Gb/s
Specification
Capacity
256 GB
Height
0.7 cm (0.28 in)
Width
Interface
6Gb/s SATA
Specification
Capacity
512GB
Height
0.7 cm (0.28 in)
Width
  • Physical Size: 6.36 cm (2.5 in)
Interface
SATA 6Gb/s
Specification
Capacity
1TB
Height
0.7 cm (0.28 in)
Width
Interface
6Gb/s SATA
Up to 550MB/s (Sequential Read)
Specification
Capacity
240GB
Width
Interface
SATA 6Gb/s
600 Mb/s
Specification
Capacity
480 GB
Width
Interface
SATA 6Gb/s
600 Mb/s
Specification
Capacity
180 GB
Width
Interface
6Gb/s SATA
PCIe SSDs for HP Workstations
Specification
Capacity
256GB
Interface
PCI Express 2.0 x4 electrical x4 physical
Specification
Capacity
512GB
Interface
Optical and removable storage specifications
HP 9.5mm Slim SuperMulti DVD Writer
Specification
9.5 mm height, tray-load
Mounting Orientation
Either horizontal or vertical
Interface Type
SATA/ATAPI
Dimensions (W x H x D)
128 x 9.5 x 127 mm
Supported Media Types
  • DVD-RAM
  • DVD+R
  • DVD+RW
  • DVD+R DL
  • DVD-R DL
  • DVD-R
  • DVD-RW
  • CD-R
  • CD-RW
Disc Capacity
  • DVD-ROM: 8.5 GB DL or 4.7 GB standard
  • Full Stroke DVD: < 200 ms (seek)
  • Full Stroke CD: < 200 ms (seek)
Maximum Data Transfer Rates
CD ROM Read
  • CD-ROM, CD-R Up to 24X
  • CD-RW Up to 24X
DVD ROM Read
  • DVD-RAM Up to 8X
  • DVD+RW Up to 8X
  • DVD-RW Up to 8X
  • DVD+R DL Up to 8X
  • DVD-R DL Up to 8X
  • DVD-ROM Up to 8X
  • DVD-ROM DL Up to 8X
  • DVD+R Up to 8X
  • DVD-R Up to 8X
Power
  • Source: SATA DC power receptacle
  • DC Power Requirements: 5 VDC ± 5%-100 mV ripple p-p
  • DC Current: 5 VDC -< 800 mA typical, <1600 mA maximum
Operating Environmental (all conditions non-condensing)
  • Temperature: 5° to 50° C (41° to 122° F)
  • Relative Humidity: 10% to 80%
  • Maximum Wet Bulb Temperature: 29° C (84° F)
Operating Systems Supported
  • Windows 8.1
  • Windows 8 32-bit and 64-bit
  • Windows 7 Professional 32-bit and 64-bit
  • Windows Vista Business 64*
  • Windows Vista Business 32*
  • Windows Vista Home Basic 32*
  • Windows 2000
  • Windows XP Professional
  • Windows XP Home 32*
  • Red Hat Enterprise Linux(RHEL) WS4**, 5, 6 Desktop/Workstation SUSE Linux Enterprise Desktop 10 & 11
No driver is required for this device. Native support is provided by the operating system.
Kit Contents
9.5mm Slim SuperMulti DVD Writer, 5.25" ODD Bay adapter/carrier, slim SATA data/power cable, installation guide
HP 9.5mm Slim DVD-ROM Drive
Specification
9.5mm height, tray-load
Interface Type
SATA / ATAPI
128 x 9.5 x 127mm
Disc Capacity
DVD-ROM
  • Single layer: Up to 4.7 GB
  • Double layer: Up to 8.5 GB
Access Times
  • DVD-ROM Single Layer: < 110 ms (typical)
  • CD-ROM Mode 1: < 110 ms (typical)
  • Full Stroke DVD: < 230 ms (typical)
  • Full Stroke CD: < 220 ms (typical)
Power
  • DC Current: VDC – < 800mA typical, < 1600 mA maximum
  • Windows 8.1, Windows 8 32-bit and 64-bit, Windows 7 Professional 32-bit and 64-bit, Windows Vista Business 64*, Windows Vista Business 32*, Windows Vista Home Basic 32*, Windows 2000, Windows XP Professional or Windows XP Home 32*.
  • No driver is required for this device. Native support is provided by the operating system.
Kit Contents
9.5mm Slim DVD-ROM Drive, 5.25" ODD Bay adapter/carrier, slim SATA data/power cable, installation guide
HP 9.5mm Slim BDXL Blu-Ray Writer
Specification
Interface Type
SATA/ATAPI
128 x 9.5 x 127 mm
  • BD-ROM
  • BD-R
  • BD-RE
  • DVD-RAM
  • DVD+R
  • DVD+RW
  • DVD+R DL
  • DVD-R DL
  • DVD-R
  • DVD-RW
  • CD-R
  • CD-RW
Disc Capacity
  • DVD-ROM
    • 8.5 GB DL or 4.7 GB standard
  • Blu-ray
    • 25 GB (single-layer)
    • 50 GB (dual-layer)
    • 100/128 GB (BDXL)
  • Full Stroke DVD
    • < 230 ms (seek)
  • Full Stroke CD
    • < 220 ms (seek)
  • Blu-ray
    • < 230 ms (seek) (Full Stroke Blu-ray)
  • Startup Time
    (Time to drive ready from tray loading)
    • BD-ROM (SL/DL): 25S / 28S
    • BD-R (SL/DL): 25S / 28S
    • BD-RE (SL/DL): 25S / 28S
    • DVD-ROM (SL/DL): 18S / 18S
    • DVD-R (SL/DL): 25S / 25S
    • DVD-RW: 25S
    • DVD+R (SL/DL): 25S / 25S
    • DVD+RW: 25S
    • DVD-RAM: 45S
    • CD-ROM: 15S
  • CD ROM Read
    • CD-RW Up to 24X
  • DVD ROM Read
    • DVD-RAM Up to 8X
    • DVD+RW Up to 8X
    • DVD-RW Up to 8X
    • DVD+R DL Up to 8X
    • DVD-R DL Up to 8X
    • DVD-ROM Up to 8X
    • DVD+R Up to 8X
    • DVD-R Up to 8X
  • Blu-ray
    • BD-ROM Up to 6X
    • BD-ROM DL Up to 6X
    • BD-R Up to 6X
    • BD-R DL Up to 6X
    • BD-R Up to 6X
    • BD-RE SL/DL Up to 6X
Power
  • DC Current: 5 VDC -900 mA typical, 2000mA maximum
Kit Contents
9.5mm Slim BDXL Blu-Ray Writer, 5.25" ODD Bay adapter/carrier, slim SATA data/power cable, installation guide
As Blu-ray is a new format containing new technologies, certain disc, digital connection, compatibility and/or performance issues may arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Blu-ray titles to play, they may require a DVI or HDMI digital connection and your display may require HDCP support. HD-DVD movies cannot be played on this workstation.
HP DX115 Removable Drive Enclosure
Specification
Interface Type
Compatible with SAS or SATA controllers. Offers 6Gb/s performance when used with 6Gb/s HDDs.
Dimensions (WxHxD)
147.6 x 41.1 x 205 (5.81 x 1.62 x 8.08 in)
Approvals
  • Frame and Carrier: 1.73 kg (3.8 lbs.)
  • Carrier: 0.45 kg (1 lbs.)
HP 15-in-1 Media Card Reader
Specification
  • Supports hardware ECC (Error Correction Code) function
  • Supports hardware CRC (Cyclic Redundancy Check) function
  • Supports MS 4-bit parallel transfer mode
  • Supports MS-PRO 4-bit parallel transfer mode
  • Supports MS PRO-HG Duo 4-bit parallel transfer mode
  • Supports SD 4-bit parallel transfer mode
  • Supports UHS-104 SD 4-bit card (version 3.0)
  • Supports CF v6.0 with PIO mode 6 and Ultra DMA 7 mode
Interface Type
USB 3.0 High-speed interface
If there is a USB2 connection, USB2 transfer speeds are supported.
Dimensions (WxHxD)
124.5 x 101.6 x 25.4 mm (4.9 x 4 x 1 in)
Fits conveniently in the 5.25" drive bay.
  • CompactFlash Type I
  • CompactFlash Type II
  • Microdrive
  • Secure Digital Card (SD)
  • Secure Digital High Capacity (SDHC)
  • SD Extended Capacity Memory Card (SDXC)
  • SD Ultra High Speed II(SD UHSII)
  • Memory Stick
  • Memory Stick Select
  • Memory Stick Duo (MS Duo)
  • Memory Stick PRO (MS PRO)
  • Memory Stick PRO Duo (MS PRO Duo)
  • Memory Stick PRO-HG Duo
  • MagicGate Memory Stick (MG)
  • MagicGate Memory Stick Duo
These additional media types are supported with a card adapter.
  • Memory Stick Micro (M2)
  • miniSD
  • miniSD High Capacity
  • Micro SD Memory Card (MicroSD)
  • Micro SD High Capacity Memory Card (MicroSDHC)
Test Parameters/Conditions - Power applied, unit operating on system ±5%
  • Windows 8 Pro (64-bit)*
  • Windows 8.1 (64-bit)*
  • Windows 8 (64-bit)*
  • Windows 7 Ultimate (32-bit)**
  • Windows 7 Ultimate (64-bit)**
  • Windows 7 Professional (32-bit)**
  • Windows 7 Professional (64-bit)**
  • Windows 7 Home Basic**
  • Windows 7 Home Premium (32-bit)**
  • Windows 7 Home Premium (64-bit)**
Not all features are available in all editions of Windows 8. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows 8 functionality.
Not all features are available in all editions of Windows 7. This system may require upgraded and/or separately purchased hardware to take full advantage of Windows 7 functionality.
Kit Contents
Kit Contents
Media card reader, 5.25" bracket/rails/bezel, Install Guide, IO & Security Software and Documentation CD
Approvals
USB-IF, WHQL, Compliant with USB Mass Storage Class Bulk only Transport Specification Rev. 1.0, Compliant Intel Front Panel I/O Connectivity Design Guide V. 1.3, FCC, CE, BSMI, C-Tick, VCCI, MIC, cUL, TUVT
0.16 kg (0.35 lbs)
Networking and communications
Specification
Connector
RJ-45 (motherboard integration)
Controller
Intel I218LM GbE platform LAN connect networking controller
Memory
3 KB FIFO packet buffer memory (both Tx and Rx)
Data Rates Supported
10/100/1000 Mbps
Compliance
  • 802.1as
  • 802.1p
  • 802.1Q
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3i
  • 802.3u
  • 802.3x
  • 802.3z
Bus architecture
PCI Express 1.1 (x1) and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power requirement
Requires 3.3V only (integrated regulators)
Boot ROM Support
Yes
Network Transfer Mode
Full-duplex; Half-duplex (not supported for the 1000BASE-T transceiver)
Network Transfer Rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Management Capabilities
  • WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostics
  • AMT 9.1 support, vPro compliant
Hardware Certifications
FCC B, UL, CE, VCCI, BSMI, CTICK, KCC
32°F to 113°F (0°C to 45°C)
Operating Humidity
0% to 85%, noncondensing
Dimensions (H x W x D)
1.19 x 1.38 x 5.57 cm (0.47 x 0.54 x 2.19 in)
Specification
Connector
Two RJ-45
Controller
Intel® Ethernet I350 Controller
Data rates supported
10/100/1000 Mbps, Half- and full-duplex
Compliance
  • 802.3, 802.3u, 802.3x, 802.3ab, 802.3ad, 802.1p, 802.1Q, 802.3az, IEEE 1588
  • PCIe v2.0 standard
  • RoHS (6 of 6)
  • FCC (U.S. only) Class B
  • DOC (Canada) Class B
  • CE EN 55024, EN55022 Class B
  • VCCI Class II
  • UL 1950
  • CSA 950
  • EN 60950
  • CE
  • ACPI 1.1a
Microsoft WHQL (Windows Hardware Quality Labs)
Data Path Width
Four lane (x4) PCI Express compatible with x4, x8, and x16 PCI Express slots
Power requirement
  • 4.1W idle without EEE link partner
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
  • 10BASE-T (half-duplex) 10 Mb/s
  • 3.2W idle with EEE link partner
  • 4.2W maximum
0° to 55° C (32° to 131° F)
Operating Humidity
10% to 95% non-condensing
13.50 x 6.4 cm (5.3 x 2.5 in) (without brackets)
Operating System Driver Support
  • Red Hat Enterprise Linux(RHEL) WS4, 5, 6 Desktop/Workstation
  • Novell SLED 10 & SLED 11
Kit Contents
HP 361T PCIe Dual Port Gigabit NIC PCA with a standard height bracket attached to it (the low profile bracket is included in the clamshell that the PCA ships in)
Product Warranty statement and the Quick Install Card (QIC)
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
  • Native HMC: 26.8 x 30.0 x 2.4 mm
  • Carrier Card Assembly: 84 x 119 mm (3.3 x 4.7 in)
Kit Contents
PCIe x1 card with full height bracket, rf antenna, antenna cable, separate low profile bracket, software CD and warranty.
1. WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista.
2. Check latest software/driver release for updates on supported security features.
3. Maximum output power may vary by country according to local regulations.
4. In Power Save Polling mode and on battery power.
5. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Physical specifications
Specification
Chassis (W x D x H)
43.2 x 16.9 x 44.5 cm (17.0 x 6.65 x 17.5 in)
System weight
Actual weight depends upon configuration
  • Minimum: 11.0 kg (24.3 lbs)
  • Standard: 13.5 kg (29.8 lbs)
  • Maximum: 17.5 kg (38.5 lbs)
Software/OS
Feature
Operating systems (Preinstalled)
  • Windows 8.1 Pro 64-bit*
  • Windows 7 Professional 64-bit (available through downgrade rights from Windows 8.1 64-bit)**
  • Windows 7 Professional (MSNA) 64-Bit*
  • HP Linux Installer Kit
  • Red Hat Enterprise Linux (RHEL) Workstation - Paper License (1yr)
* Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality. See http://www.microsoft.com.
** This system is preinstalled with Windows® 7 Pro software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
1 This second OS must be ordered with the HP Linux Installer Kit as the first OS.
  • HP Performance Advisor
  • HP Remote Graphics Software (RGS) 6.0
  • MS Office Home & Business 2013
  • Cyberlink PowerDVD and Power2Go
  • Foxit PhantomPDF Express
Available as a free download from HP Performance Advisor.
NOTE 2: Supported operating systems:
  • Windows 7 Professional 32/64
  • Windows 8 Professional 32/64
  • RHEL v6.5
  • SLED 11 SP3
For more information, go to HP Remote Graphics Software.
Must select as a Configure to Order option.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Environmental specifications
Temperature range
  • Operating: 5°C to 35°C (40°F to 95°F)
  • Non-operating: -40°C to 60°C (-40°F to 140°F)
Relative humidity
  • Operating: 8% to 85% RH, non-condensing
  • Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
  • Operating: 3,000 m (10,000 ft)
  • Non-operating: 9,100 m (30,000 ft)
Dynamic (new)
Shock
  • Operating: ½-sine: 40g, 2-3ms (~62 cm/sec)
  • Non-operating:
    • ½-sine: 160 cm/s, 2-3ms (~105g)
    • square: 422 cm/s, 20g
Values represent individual shock events and do not indicate repetitive shock events.
Vibration
  • Operating random: 0.5g (rms), 5-300 Hz, up to 0.0025g²/Hz
  • Non-operating random: 2.0g (rms), 5-500 Hz, up to 0.0150 g²/Hz
Values do not indicate continuous vibration.
Cooling
Above 1524 m (5,000 ft.) altitude, maximum operating temperature is de-rated by 1° C (1.8° F) per 305 m (1,000 ft.) elevation increase
