    Fix Windows 10 Update Issues
    Are you working from home?
HP Printers - Printing with Mopria Print Service (Android)
This document is for HP network-connected and Wi-Fi Direct printers and Android smartphones and tablets.
Print photos, documents, webpages, and emails from your Android device to your HP network-connected printer using the Mopria Print Service Plugin, a free app available in the Google Play Store.
Step 1: Check the requirements
Before installing the Mopria Print Service plugin, make sure the printer and your Android device connection requirements are met.
  • The printer is connected to a wireless network or a wired (Ethernet) network, or Wi-Fi Direct is turned on.
  • The Android device is connected to the same wireless network as your printer if you plan to print over a network connection.
  • The printer and the Android device are close to the access point (router), but no closer than approximately 6 ft (1.8 m). Wireless signals can be weaker at greater distances.
Step 2: Install and turn on the Mopria Print Service plugin
Install or update the Mopria Print Service plugin from the Google Play Store.
  1. On your Android device, install or update the Mopria Print Service plugin (in English) from the Google Play Store.
  2. Android versions 5.x or 6.x: Go to the Settings menu on your mobile device, and then enable the Mopria plugin.
    For later Android versions, the plugin is enabled by default.
  3. From the list of apps on your device, open the Mopria Print Service Plugin, and then accept the license agreement.
    The app searches for printers on the same network as your mobile device.
    • If a list of Wi-Fi and Wi-Fi Direct printers display, continue with these steps.
      List of Wi-Fi and Wi-Fi Direct printers in the Mopria app
    • If no printers display, follow the prompt in the app to resolve the issue or tap the Menu icon for detailed troubleshooting steps, and then continue with these steps.
      No printers were found and a resolution to the issue displays in the Mopria app
  4. Enable the Mopria Print Service in Print Settings.
Refer to these frequently asked questions for more information about the Mopria Print Service plugin for Android devices.
You can also look for information in the Mopria app on your mobile device.
