    We are upgrading our website
HP ProOne 400 G1 23-Inch Non-Touch All-in-One PC - Specifications
Physical specifications
Feature
With Stand
Without Stand
With Height Adjustable/Reclining Stand
16.9 - 17.2 lbs
7.65 – 7.8 kg
15.6 - 16 lbs
7.09 – 7.24 kg
20.99 lbs
9.52 kg
Shipping box weight
24.34 lbs
11.05 kg
30.36 lbs
13.77 kg
Shipping pallet weight (40 units)
1061.67 lbs
482 kg
430.5 / 551.96 lbs
195.24 / 250.32 kg
Dimensions (W x D x H)
22 x 3.2 x 15.9 in
557.9 x 81.6 x 402.6 mm
22 x 2.2 x 14.3 in
557.9 x 56.6 x 362.9 mm
21.97 x 10.51 x 18.03 in
21.97 x 10.51 x 18.03 mm
Shipping box dimensions (W x D x H)
25.51 x 6.89 x 21.34 in
648 x 175 x 542 mm
25.95 x 12.88 x 22.25 in
659 x 327 x 565 mm
Shipping pallet dimensions (W x D x H)
47.24 x 39.37 x 96.54 in
1200 x 1000 x 2452 mm
48 x 40 x 71.89 / 48 x 40 x 94.14 in
1219 x 1016 x 1826 / 1219 x 1016 x 2391 mm
Operating conditions
Specification
Temperature
Operating: 41 to 95° F (5 - 35° C)
Non-operating: -22 to 149° F (-30° to 65° C)
Relative humidity
Operating: 15 to 80% at 26° C
Maximum Altitude (unpressurized)
Operating:
0 to 6500 ft (0 to 2000 m)
Non-operating:
0 to 15,000 ft (0 to 4,572 m)
Graphics
Intel HD Graphics
Feature
VGA Controller
Integrated
DisplayPort
Multimode capable; supports HDCP, Display Port Audio (2 streams), HBR2 link rates
Bus Type
N/A
RAMDAC
N/A
Memory
Intel graphics do not have dedicated memory but utilizes some of the computer’s system memory The amount of memory used for graphics depending on the amount of system memory installed, BIOS settings, operating system, and system load. 32 MB is pre-allocated for graphics use at system boot time.
Additional memory can be allocated at boot time by the BIOS for PAVP (Protected Audio Video Playback) support for playback of protected video content. Additional memory is allocated for graphics as needed using Intel's Dynamic Video Memory Technology (DVMT), to provide an optimal balance between graphics and system memory use.
Maximum Graphics Memory
  • Windows 7: Up to 1.7GB
  • Windows 8.1: Up to 1.8GB
The actual amount of maximum graphics memory can be less than the amounts listed above depending upon your computer’s configuration.
Maximum Color Depth
32 bits/pixel
Graphics/Video API Support
  • The Processor Graphics contains a refresh of the seventh generation graphics core enabling substantial gains in performance and lower power consumption. Up to 16 EU support.
  • Next Generation Intel Clear Video Technology HD Support is a collection of video playback and enhancement features that improve the end user's viewing experience.
    • Encode/transcode HD content
    • Playback of high definition content including Blu-ray Discs
    • Superior image quality with sharper, more colorful images
  • DirectX Video Acceleration (DXVA) support for accelerating video processing.
    • Full AVC/VC1/MPEG2 HW Decode
  • Advanced Scheduler 2.0, 1.0
  • Windows 7, Windows 8.1, Linux OS Support
  • DirectX 11.1
  • OpenGL 4.0
  • Open CL 1.2
Supported Display Resolutions (all at 60 Hz)
  • 800x600
  • 1024x768
  • 1152x864
  • 1280x600
  • 1280x720
  • 1280x800
  • 1280x960
  • 1280x1024
  • 1360x768
  • 1366x768
  • 1400x1050
  • 1440x900
  • 1600x900
  • 1600x1200*
  • 1680x1050
  • 1920x1080
  • 1920x1200*
  • 1920x1440*
  • 2560x1440*
  • 2560x1600*
* Only supported on displays connected to the external DisplayPort connector.
Hard Disk and Solid State Storage
HP 500GB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Feature
Capacity
500GB
Rotational Speed
7,200 rpm
Interface
SATA 6Gb/s
Buffer Size
16MB
Logical Blocks
976,773,168
Seek Time (typical reads, includes controller overhead, including settling)
  • Single Track: 2.0 ms
  • Average: 11 ms
  • Full-Stroke: 21 ms
Height (nominal)
1 in/2.54 cm
Width (nominal)
  • Media diameter: 3.5 in/8.89 cm
  • Physical size: 4 in/10.2 cm
Operating Temperature
41° to 131° F (5° to 55° C)
HP 1TB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Feature
Capacity
1TB
Rotational Speed
7,200 rpm
Interface
SATA 6Gb/s
Buffer Size
32MB
Logical Blocks
1,953,525,168
  • Average: 11 ms
Height (nominal)
1 in/2.54 cm
Width (nominal)
HP 2TB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Feature
Unformatted Capacity
2TB
Rotational Speed
7,200 rpm
Interface
SATA 6Gb/s
Cache, Multisegmented
64MB
Seek Time (average)
  • Read: Less than 8.5 ms
  • Write: Less than 9.5 ms
Height (nominal)
1.028 in/26.11 mm
Width (nominal)
4.0 in/101.6 mm
Depth
5.787 in/146.99 mm
1.38 lb/626 g
32° to 140° F (0° to 60° C)
HP 320GB 7.2K SATA 6.0Gb/s 2.5” Hard Disk Drive
Feature
Capacity
320GB
Rotational Speed
7,200 rpm
Interface
SATA 6Gb/s
Buffer Size
16MB
Logical Blocks
488,397,168
  • Average: 12 ms
  • Full-Stroke: 22 ms
Height (nominal)
0.374 in/9.5 mm
Width (nominal)
  • Media diameter: 2.5 in/63.5 mm
  • Physical size: 2.75 in/70 mm
HP 500GB 7.2K SATA 6.0Gb/s 2.5” Hard Disk Drive
Feature
Capacity
500GB
Rotational Speed
7,200 rpm
Interface
SATA 6Gb/s
Buffer Size
16MB
Logical Blocks
976,773,168
  • Average: 12 ms
  • Full-Stroke: 25 ms
Height (nominal)
0.374 in/9.5 mm
Width (nominal)
128GB SATA 2.5” Opal2 SED Solid State Drive
Feature
128GB
Architecture
Self-Encrypting (SED) Solid State Drive with NAND Flash and SATA interface
Trusted Computing Group(TCG) OPAL compliant encrypted solid state drive
Interface
Serial ATA (6.0Gb/s)
Form Factor
2.5 inch
Height
6.80 mm ± 0.20
Width
69.85 mm ± 0.25
Length
100.20 mm ± 0.25
Up to 55 g
Bandwidth Performance
  • Sustained Sequential Read: Up to 520MB/s
  • Sustained Sequential Write: Up to 340MB/s
Power Consumption
  • Active: 0.78A / 3.891W
  • Idle: 0.005A / 0.026W
Mean Time Between Failure
1,500,000 hours
Environmental (all conditions, non-condensing)
  • Operating Temperature: 32° to 158° F (0° to 70° C)
  • Relative Humidity: 5% to 95%
  • Shock: 1,500 G/0.5 ms
256GB SATA 2.5” Opal2 SED Solid State Drive
Feature
256GB
Architecture
Interface
Form Factor
2.5 inch
Height
6.80 mm ± 0.20
Width
69.85 mm ± 0.25
Length
100.20 mm ± 0.25
Up to 55 g
  • Sustained Sequential Write: Up to 500MB/s
Power Consumption
1,500,000 hours
120GB SATA 2.5” Opal1 SED Solid State Drive
Feature
120GB
Architecture
Self-Encrypting (SED) Solid State Drive with 20nm MLC NAND Flash and SATA interface
Interface
NAND Flash
20nm MLC NAND Flash
Form Factor
2.5 inch
Thickness
7 mm
Up to 78 g
  • Sustained Sequential Read: Up to 540MB/s
  • Sustained Sequential Write: Up to 480MB/s
  • Random 4k Read: Up to 41K IOPs
  • Random 4k Read: Up to 80K IOPs
Power Consumption
  • Active: 195 mW
  • Idle: 125 mW
1,200,000 hours
Intel 180GB SATA 2.5” Opal1 SED Solid State Drive (Pro 1500)
Feature
180GB
Architecture
Interface
Serial ATA (6.0 Gb/s)
NAND Flash
20nm MLC NAND Flash
Form Factor
2.5 inch
Thickness
7 mm
Up to 78 g
  • Sustained Sequential Write: Up to 490MB/s
Power Consumption
  • Active: 195 mW
  • Idle: 125 mW
1,200,000 hours
HP 500GB 7200 RPM SATA 2.5” Self-Encrypting (SED) Hard Disk Drive
Feature
Capacity
500GB
Rotational Speed
7,200 rpm
Drive Type
Self-Encrypting Drive (SED) with SATA interface
Interface
SATA 6Gb/s
Number of Sectors
976,773,168
  • Single Track: 1.0 ms
  • Average: 13 ms
Height (nominal)
0.267 in/6.8 mm, ±0.2mm
Length
3.945 in/100.2 mm, ±0.25mm
Width (nominal)
  • Physical size: 2.75 in/69.85 mm, ±0.25mm
Weight (max)
3.35 oz/95 g
HP 500 GB SATA 6G 2.5” 8GB Solid State Hybrid Drive (SSHD)
Feature
Formatted Capacity
500GB
Spindle Speed
5,400 rpm +/- 0.2%
Drive Type
Solid State Hybrid Drive (SSHD) technology with NAND Flash
Interface
SATA 6 Gb/s
Cache Buffer
64MB
NAND Flash
Commercial Multilevel Cell (cMLC) 8GB
Number of Sectors
976,773,168
Seek Time (typical reads)
  • Average: 12 ms
Height
0.268 +/-.008 in (6.8 +/- 0.2 mm)
Width
2.750 +/- 0.010 in (69.85 +/- 0.25 mm)
Length
3.951 +0.008 / -0.010 in (100.35 +0.20 / -0.25 mm)
Weight (max)
0.209 lb/95 g
HP 1TB SATA 6G 2.5” 8GB Solid State Hybrid Drive (SSHD)
Feature
Formatted Capacity
1TB
Spindle Speed
5,400 rpm +/- 0.2%
Drive Type
Interface
SATA 6 Gb/s
Cache Buffer
64 MB
NAND Flash
Number of Sectors
976,773,168
  • Average: 12 ms
Height
0.374 +/-.008 in (9.5 +/- 0.2 mm)
Width
Length
Weight (max)
0.254 lb/115 g
Removable Storage
HP Slim SuperMulti DVD Writer Drive
Feature
Height height
12.7mm
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5GB DL or 4.7GB standard
Dimensions (W x H x D)
5.04 x 0.5 x 5.0 in (128 x 12.7 x 127 mm) without bezel
Weight (max)
0.42 lb (190 g)
Write speeds
  • DVD-RAM: Up to 5X
  • DVD-R DL: Up to 6X
  • DVD+R: Up to 8X
  • DVD+RW: Up to 8X
  • DVD+R DL: Up to 6X
  • DVD-R: Up to 8X
  • DVD-RW: Up to 6X
  • CD-R: Up to 24X
  • CD-RW: Up to 24X
Read speeds
  • DVD-RAM : Up to 5X
  • DVD-RW, DVD+RW: Up to 8X
  • DVD-R DL, DVD+R DL: Up to 8X
  • DVD+R, DVD-R: Up to 8X
  • DVD-ROM DL, DVD-ROM: Up to 8X
  • CD-ROM, CD-R: Up to 24X
  • CD-RW: Up to 24X
Access time (typical reads, including settling)
  • Random: DVD-ROM: 170 ms (typical), CD-ROM: 170 ms (typical)
  • Full Stroke: DVD-ROM: 320 ms (typical), CD-ROM: 320 ms (typical)
  • Stop Time: 6 seconds (typical)
Power Source
  • Source: Slimline SATA DC power receptacle
  • DC Power Requirement: 5 VDC ± 5%-100 mV ripple p-p
  • DC Current: 5 VDC (less than 1000mA typical, less than 1600 mA maximum)
Environmental conditions (operating - non-condensing)
  • Temperature: 41° to 122° F (5° to 50° C)
  • Relative Humidity: 10% to 80%
  • Maximum Wet Bulb Temperature: 84° F (29° C)
HP Slim Blu-ray BDXL Drive
Feature
Height
12.7mm
Orientation
Interface type
SATA/ATAPI
Up to 128GB QL, 100GB TL, 50GB DL or 25GB standard SL
Up to 0.37 lb (170 g) without bezel
Write speeds
  • BD-R: Up to 4X (triple-layer and quadruple-layer)
  • BD-RE: Up to 2X (triple-layer; quadruple-layer not supported)
  • BD-R: Up to 6X (single-layer and double-layer)
  • BD-RE: Up to 2X (single-layer and double-layer)
  • DVD-R: Up to 8X (single-layer), up to 6X (double-layer)
  • DVD-RW: Up to 6X (single-layer; double-layer not supported)
  • DVD+R: Up to 8X (single-layer), up to 6X (double-layer)
  • DVD+RW: Up to 8X (single-layer; double-layer not supported)
  • DVD-RAM: Up to 5X (single-layer)
  • CD-R: Up to 24X (single-layer)
  • CD-RW: Up to 24X (single-layer)
  • BD-RE: Up to 4X (triple-layer; quadruple-layer not supported)
  • BD-ROM: Up to 6X (single-layer and double-layer)
Read speeds
  • BD-RE: Up to 6X (single-layer and double-layer)
  • DVD-ROM: Up to 8X (single-layer and double-layer)
  • DVD-R: Up to 8X (single-layer and double-layer)
  • DVD-RW: Up to 8X (single-layer)
  • DVD+R: Up to 8X (single-layer and double-layer)
  • DVD+RW: Up to 8X (single-layer)
  • BDMV (AACS Compliant Disc): Up to 6X/2X (Read/Play) (single-layer)
  • DVD-Video (CSS Compliant Disc): Up to 8X/4X (Read/Play) (single-layer)
  • CD-R/RW/ROM: Up to 24X (single-layer)
  • CD-DA(DAE): Up to 20X/10X (Read/Play) (single-layer)
  • Random: BD-ROM: 205 ms (typical), DVD-ROM: 185 ms (typical), CD-ROM: 165 ms (typical)
  • Full Stroke: BD-ROM: 350 ms (typical), DVD-ROM: 345 ms (typical), CD-ROM: 340 ms (typical)
Power
  • DC Current: 5 VDC -1200 mA typical, 2000 mA maximum
HP Slim DVD-ROM Drive
Feature
Height
12.7mm
Orientation
Interface type
SATA/ATAPI
Read speeds
  • DVD+R/-R/+RW/-RW/+R DL/-R DL: Up to 8X
  • DVD-ROM: Up to 8X
  • CD-RW : Up to 24X
Power
  • DC Current: 5 VDC - less than 1000mA typical, less than 1600 mA maximum
Environmental (all conditions non-condensing)
  • Maximum Wet Bulb Temperature (operating): 84° F (29° C)
Networking/Communication
Realtek RTL8151GH-CG GbE LOM Network Adapter
Feature
Connector
RJ-45
System Interface
Integrated on PCA
Controller
Realtek RTL8151GH-CG Gigabit Ethernet Controller
Memory
16 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mbps
IEEE Compliance
  • 802.1P
  • 802.1Q
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture
PCI Express
Data transfer mode
PCIe-based interface for active state operation (S0 state)
Power requirement
3.3V and 1V or 3.3V with integrated regulators
Power consumption 0.425 W
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10Mbps
  • 10BASE-T (full-duplex) 20Mbps
  • 100BASE-TX (half-duplex) 100Mbps
  • 100BASE-TX (full-duplex) 200Mbps
  • 1000BASE-T (full-duplex) 2000Mbps
Environmental
  • Operating Humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, Advanced cable diagnostic
Intel Dual Band Wireless-N 7260 802.11 a/b/g/n (2x2) Wireless Network Interface Connection
Feature
Wireless LAN Standards
IEEE 802.11a/b/g/n
Interoperability
  • Wi-Fi certified (802.11 a/b/g/n WMM, WPA, WPA2 and WPS)
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
Frequency Band
  • 802.11b/g/n: 2.402-2.482 GHz
  • 802.11a/n:
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
Antenna Structure
2 transmit; 2 receive (2x2)
Data Rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
Modulation
  • Direct Sequence Spread Spectrum
  • CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI Note: Check latest software/driver release for updates on supported security features
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output Power
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
Power Consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN associated) In Power Save Polling mode and on battery power
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio off: 100 mW (WLAN unassociated)
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity
  • 802.11g: -90 dBm (6 Mbps), -89 dBm (9 Mbps), -87 dBm (12 Mbps), -85 dBm (18 Mbps), -82 dBm (24 Mbps), -79 dBm (36 Mbps), -76 dBm (48 Mbps), -74 dBm (54 Mbps)
  • 802.11b: -95 dBm (1 Mbps), -93 dBm (2 Mbps), -91 dBm (5.5 Mbps), -88 dBm (11 Mbps)
Antenna Connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form Factors
PCI-Express Half-MiniCard
0.0068 lb (3.1 g)
Dimensions
0.12 x 1.06 x 1.18 in (3.1 x 26.8 x 30.0 mm)
Operating Voltage
3.3V +/- 9%
Temperature
  • Operating: 14° to 158° F (-10° to 70° C)
  • Non-operating: -40° to 176° F (-40° to 80° C)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
Altitude
  • Operating: 0 to 10,000 ft (3,048 m)
  • Non-operating: 0 to 50,000 ft (15,240 m)
LED Activity
LED Amber - Radio OFF; LED White - Radio ON
HP 802.11a/b/g/n Wireless Minicard with Bluetooth Combo
Feature
Dimensions (L x H)
1.18 x 1.06 in (30 x 26.8 mm)
Broadcom BCM43228 + BCM20702
System interface
PCI Express x1
Network standard
802.11 a/b/g/n
Frequency band
  • Bluetooth: 2.402 - 2.480 GHz
  • Wi-Fi: 802.11a – 5.15-5.85 GHz; 802.11bg 2.412-2.4835 GHz
Temperature
  • Operating: 32° to 131°F (0° to 55°C)
  • Non-operating: -40° to 176°F (-40° to 80°C)
Humidity
  • Operating: 5-90%
  • Non-operating: 5-95%
Operating voltage
3.3V ±9% I/O supply voltage
Power Consumption
  • Wi-Fi:
    • Tx Mode: 515 mA
    • Rx Mode: 425 mA
  • Bluetooth:
    • Tx Mode: 40 mA
    • Rx Mode: 38 mA
    • Standby Mode: Wi-Fi + Bluetooth – 165 mA, Wi-Fi only – 165 mA, Bluetooth only – 0.5 mA
    • Radio Off: 77 mA
Output Power (2x2 – Tolerance +/- 1.5 dBm )
  • 802.11a: 15.5 dBm@6Mbps; 15.5 dBm@54Mbps
  • 802.11b: 18.5 dBm@11Mbps
  • 802.11g: 16.5 dBm@6Mbps; 16.5 dBm@54Mbps
  • 802.11n/2.4G: 20MHz: 18 dBm@MCS0, 18 dBm@MCS15; 40MHz: 17 dBm@MCs0, 17 dBm@MCS15
  • 802.11n/5G: 20MHz: 16 dBm@MCS, 16 dBm@MCS15; 40MHz: 16 dBm@MCs0, 16 dBm@MCS15
Security
  • IEEE 802.11i 64-/128-bit WEP encryption
  • WPS, WPA, WPA2, WEP 64bit & 128bit, IEEE 802.11x, IEEE 802.11i
Antenna
Dual antenna connectors
Audio
Realtek ALC3228 High Definition Audio
Feature
Type
Integrated
HD Stereo Codec
Realtek ALC3228 4-channel codec
Ports
  • Line-In/Microphone input ports are 47K (nominal) at the pin
  • Line-Out intended to drive an external 10K load (nominal) and an on board shunt resistor of 20-47K (nominal)
  • Headphone-Out designed to drive 32 ohm (nominal) headphones or a 10K (nominal) load
  • All ports are 3.5 mm
Internal Speaker Amplifier
2.2W/channel Class-D stereo BTL speaker amplifier@ 4 ohms and 5V
Sampling
The ALC3228 audio CODEC provides stereo 24- bit, full duplex resolution supporting sample rates up to 192kHz by the DAC and ADC. Additional sample rates are supported by the driver software.
Analog Audio
Yes
Number of Channels on Line-Out
4 Channels (2 stereo DACs and 2 stereo ADCs) with 24-bit resolution
Internal Speaker
Yes
Keyboards and Mice
HP USB Keyboard
Feature
Physical characteristics
  • Keys: 104, 105, 106, 107, 109 layout (depending upon country)
  • Dimensions (L x W x H): 18.12 x 6.47 x 0.96 in (46.03 x 16.43 x 2.44 cm)
  • Weight: 2 lb (0.9 kg)
Electrical
  • Operating voltage: + 5VDC ± 5%
  • Power consumption: 50-mA maximum (with three LEDs ON)
  • System interface: USB Type A plug connector
  • ESD: CE level 4, 15-kV air discharge
  • EMI - RFI: Conforms to FCC rules for a Class B computing device
  • Microsoft PC 99 - 2001: Functionally compliant
Mechanical
  • Keycaps: Low-profile design
  • Switch actuation: 55-g nominal peak force with tactile feedback
  • Switch life: 20 million keystrokes (using Hasco modified tester)
  • Switch type: Contamination-resistant switch membrane
  • Key-leveling mechanisms: For all double-wide and greater-length keys
  • Cable length: 6 ft (1.8 m)
  • Microsoft PC 99 - 2001: Mechanically compliant
Environmental
  • Acoustics: 43-dBA maximum sound pressure level
  • Operating temperature: 50° to 122° F (10° to 50° C)
  • Non-operating temperature: -22° to 140° F (-30° to 60° C)
  • Operating humidity: 10% to 90% (non-condensing at ambient)
  • Non-operating humidity: 20% to 80% (non-condensing at ambient)
  • Operating shock: 40 g, six surfaces
  • Non-operating shock: 80 g, six surfaces
  • Operating vibration: 2-g peak acceleration
  • Non-operating vibration: 4-g peak acceleration
  • Drop (out of box):
    26 in (66 cm) on carpet, six-drop sequence
  • Drop (in box): 30 in (76.2 cm) on concrete, 16-drop sequence
Approvals
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, KC
Ergonomic compliance
ANSI HFS 100, ISO 9241-4, and TUVGS
Kit contents
  • Keyboard
  • Installation Guide
  • Warranty Card
  • Safety and Comfort Guide
HP Wireless Keyboard and Mouse
Feature
Keyboard
  • Dimensions (H x L x W): 1.09 x 18.1 x 6.47 in (27.87 x 460.3 x 164.3 mm)
  • Weight: 1.94 lb (880 g) without batteries
Mouse
  • Dimensions (H x L x W): 1.46 x 4.53 x 2.47 in (37 x 115 x 62.9 mm)
  • Weight: 0.15 lb (67 g) without batteries
Receiver
  • Dimensions (H x L x W): 0.33x 1.79 x 0.72 in (8.4 x 45.5 x 18.4 mm)
  • Weight: 0.21 oz (5.9 g)
  • Cable Length: 6 ft (1.8 m)
  • Range: 32.8 ft (10 m)
System Requirements
  • Windows 7 Home Basic, Windows 7 Home Premium, Windows 7 Professional Edition 32, Windows 7 Professional Edition 64, Windows 7 Ultimate Edition 32, Windows 7 Ultimate Edition 64 Windows Vista or Windows XP
  • Available USB port for the receiver
  • CD-ROM Drive
Approvals
  • Product Safety: UL; CSA /TUV (Europe only); CE Mark; CB Report
  • Ergonomics: ANSI; ISO (Europe only); GS Mark (Germany only)
  • EMC: FCC; CE; ACA (-tick); BSMI; KC ; VCCI
  • CE Mark: EN 55022:2010; EN 55024; EN 301489-1; EN 61000
  • Design Guidelines for PCs: PC 99 – connector overmold colors; PC 2001 – full functionality
  • Telecom: All local telecom requirements and approvals for intended markets
  • USA: FCC Title 47 CFR, Par 15, Subpart C; other local requirements
  • Country Support: US, Belgium, Switzerland, Spain, Denmark, Netherlands, France, Germany, Italy, Portugal, Sweden, Norway, Finland, UK, Poland, Czech Republic, Turkey, Greece, Austria, Bulgaria, Cyprus, Estonia, Hungary, Ireland, Latvia, Lithuania, Luxemburg, Malta, Romania, Slovakia, Slovenia, Vietnam, HK, Australia, NZ, Malaysia, Singapore, Indonesia, Philippines, Thailand, Canada, China, Japan, Korea, Taiwan, India, Venezuela, Ecuador, Russia, Ukraine, Israel, Croatia, United Arab Emirates, Peru, Brazil, Chile, Argentina, Mexico, South Africa, and up to 193 countries worldwide.
Environmental
Keyboard contains 25% post-consumer recycled plastic material.
HP USB Smart Card (CCID) Keyboard
Feature
Key Benefits
  • Protects against unauthorized access with smart card technology
  • Delivers even greater security when combined with a HP ProtectTools smart card and the HP ProtectTools Security Software
  • Combination of username and password or pin with a smart card or security token
  • Secures online transactions using digital signatures and certificates
  • Conforms to industry standards for ease of setup and use
  • Delivers long product life and quiet operation with high-impact materials and lubricated keys
  • Spill drain feature
Physical Characteristics
  • Form factor: USB basic smart card keyboard
  • Colors: Carbonite/Silver
  • Dimensions (H x W x D): 18.2 x 6.3 x 1.3 in (46.3 x 16.1 x 3.3 cm)
  • Weight: 2 lb (0.9 kg) minimum
Electrical
  • Power consumption: 100-mA maximum (with four LEDs ON)
Mechanical
  • Languages: 30+ available
  • Keycaps: Standard design
  • Switch actuation: 55 g nominal peak force with tactile feedback
  • Switch type: Contamination-resistant membrane
Environmental
  • Drop (out of box): 26 in (66 cm) on carpet, six-drop sequence
  • Drop (in box): 42 in (107 cm) on concrete, 16-drop sequence
SmartCard Function
  • Support: All ISO 7816 smart cards
  • Interface: Reads from and writes to all ISO7816-1, 2, 3, 4 memory and microprocessor smart cards (T=0, T=1)
  • Chipset: SCM STCII
  • Standard APIs supported: PC/SC, EMV2000, SET
  • Power:
    • USB Port
    • Short circuit detection (protects smart card and reader)
    • Power supply compliant with ISO7816 and EMV (5V, 60 mA)
    • Supports 3-V and 5-V cards
  • Power consumption: 100-mA maximum draw
  • Communication:
    • From card: 9600 bps to 330,000 bps
    • From computer: 12 Mbps (USB transfer speed)
  • Landing mechanism:
    • Contact device: Friction contact
    • Card insertions rating: Up to 100,000 insertion cycles
  • Interface modes: CCID protocol
  • Reader performance interface: USB connection
  • Electro-magnetic standards:
    • Europe: 2004/108/EC
    • USA: USAFCC part 15
Approvals
CE-Mark, UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC, EMV2000, USB-IF
Ergonomic Compliance
ISO 9241-4, TUVGS
Kit Contents
Keyboard, I/O Security and Documentation CD, warranty card
HP USB PS/2 Washable Keyboard
Feature
  • Keys: 104 (US) Layout, 105 (EU) layout – depending upon country
  • Dimensions (L x W x H): 17.67x 6.62 x 1.38 in (449 x 168 x 35 mm)
  • Weight: 1.7 lb (0.77 kg) minimum
Electrical
  • Operating voltage: + 5VDC ±5%
Mechanical
  • Keycaps: Stepped-profile design
  • Cable length: 7 ft (2.2 m)
Environmental
  • Non-operating temperature: 4° to 149° F (-20° to 65° C)
  • Operating humidity: 10% to 95% (non-condensing at ambient)
  • Non-operating humidity: 0% to 95% (non-condensing at ambient)
Operating system support
Windows 7, Windows Vista, Windows XP
Professional Approvals
UL, cUL, FCC, CE, TUV GS, VCCI, BSMI, C-Tick, KCC, USB-IF, WHQL, EN/IEC 60601-1, IP66/NEMA4X
HP USB Mouse
Feature
Dimensions(H x L x W)
1.5 x 4.5 x 2.5 in (3.7 x 11.5 x 6.3 cm)
0.22 lb (0.10 kg)
Cable length
70.9 in (180 cm)
System requirements
Available USB port
HP USB 1000dpi Laser Mouse
Feature
1.47 x 4.53 x 2.47 in (37.3 x 114.97 x 62.86 mm)
3.360 oz (102g)
Cable length
70.9 in (180 cm)
System requirements
Available USB port
Environmental
  • Operating Temperature: 32° to 104° F (0° to 40° C)
  • Non-operating Temperature: -4° to 140° F (-20° to 60° C)
  • Operating Humidity: 10% to 90% (non-condensing at ambient)
Mechanical
  • Resolution: 1000dpi
  • Tracking Speed: 45 cm/sec
  • Cable Length: 70.9 in (180 cm)
HP USB PS/2 Washable Mouse
Feature
1.56 x 2.44 x 4.61 in (3.95 x 6.21 x 11.7 cm)
4.44 oz (126 g)
Environmental
  • Operating temperature: -32° to 104°F (0° to 40° C)
  • Non-operating temperature: -4° to 140°F (-20° to 60° C)
  • Operating humidity: 10% to 90% (non condensing at ambient)
  • Non-operating humidity: 10% to 90% (non condensing at ambient)
  • Operating shock: 40 g, 6 surfaces
  • Non-operating shock: 80 g, 6 surfaces
  • Operating vibration: 2 g peak acceleration
  • Non-operating vibration: 4 g peak acceleration
  • Drop(out of box): 80 cm height onto asphalt tile over concrete or equivalent, 5-drop in 5 direction except the cable face
Electrical
  • Operating voltage: 5 VDC ± 10%
  • Power consumption: 100mA
  • System consumption: PS/2 mini-din connector
  • ESD: CE level 4, 15 kV air discharge
  • EMI-RFI: Conforms to FCC rules for a Class B computing device
  • Microsoft PC99 - 2001: Functionally compliant
Mechanical
  • Resolution: 400 ± 20% DPI
  • Tracking speed: 10 in/s (25.4 cm/s) maximum
  • Acceleration: 100 in/s/s (2.54 m/s/s)
  • Switch actuation: 61 g nominal peak force
  • Switch life: 3,000,000 operations (using Hasco modified tester)
  • Switch type: Low force micro-switches
  • Tracking mechanism life: 155 mi (250 km) at average speed of 10 in/s
  • Microsoft PC99 - 2001: Mechanically compliant
Scroll wheel
  • Width: 8 mm
  • Diameter: 1.01 in (25.6 mm)
  • Maximum rotation speed: 48 rats/sec
  • Switch type: Light force micro-switch
  • Switch life: 1 million operations
  • Mechanical life: Minimum 200,000 revolutions
Regulatory Approvals
Compliant: UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC
Compatibility
Operating system support: Windows 7, Windows Vista Business 64, Windows Vista Business 32, Windows Vista Home Basic 32, Windows 2000, Windows XP Professional or Windows XP Home 32, xpe, ce.net, Linux, XP-64
Country: Flag Bulgaria
