HP ProOne 400 G1 23-Inch Non-Touch All-in-One PC - Overview
Product description
Processors
Feature
Intel® 4th Generation Core™ i7 Processors
  • Intel® Core™ i7-4790T:
    • Up to 3.9 GHz Max. Turbo Frequency (2.7 GHz base frequency), 8 MB cache, 4 cores, 8 threads
    • Intel HD Graphics 4600
    • Supports DDR3 memory up to 1600 MT/s data rate
  • Intel® Core™ i7-4785T:
    • Up to 3.2 GHz Max. Turbo Frequency (2.2 GHz base frequency), 8 MB cache, 4 cores, 8 threads
  • Intel® Core™ i7-4765T:
    • Up to 3.0 GHz Max. Turbo Frequency (2.0 GHz base frequency), 8 MB cache, 4 cores, 8 threads
Intel® 4th Generation Core™ i5 Processors
  • Intel® Core™ i5-4690T:
    • Up to 3.5 GHz Max. Turbo Frequency (2.5 GHz base frequency), 6 MB cache, 4 cores, 4 threads
  • Intel® Core™ i5-4590T:
    • Up to 3.0 GHz Max. Turbo Frequency (2.0 GHz base frequency), 6 MB cache, 4 cores, 4 threads
  • Intel® Core™ i5-4670T:
    • Up to 3.3 GHz Max. Turbo Frequency (2.3 GHz base frequency), 6 MB cache, 4 cores, 4 threads
  • Intel® Core™ i5-4570T:
    • Up to 3.6 GHz Max. Turbo Frequency (2.9 GHz base frequency), 4 MB cache, 2 cores, 4 threads
Intel® 4th Generation Core™ i3 Processors
  • Intel® Core™ i3-4350T:
    • 3.1 GHz base frequency, 4 MB cache, 2 cores, 4 threads
    • Supports DDR3 memory 1600 MT/s data rate
  • Intel® Core™ i3-4150T:
    • 3.0 GHz base frequency, 3 MB cache, 2 cores, 4 threads
    • Intel HD Graphics 4400
  • Intel® Core™ i3-4330T:
    • 3.0 GHz base frequency, 4 MB cache, 2 cores, 4 threads
  • Intel® Core™ i3-4130T:
    • 2.9 GHz base frequency, 3 MB cache, 2 cores, 4 threads
  • Intel® Core™ i3-4160T:
    • 3.1 GHz base frequency, 3 MB cache, 2 cores, 4 threads
  • Intel® Core™ i3-4360T:
    • 3.2 GHz base frequency, 4 MB cache, 2 cores, 4 threads
Intel® 4th Generation Pentium® Processors
  • Intel® Pentium® G3440T:
    • 2.8 GHz base frequency, 3 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
  • Intel® Pentium® G3240T:
    • 2.7 GHz base frequency, 3 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
    • Supports DDR3 memory 1333 MT/s data rate
  • Intel® Pentium® G3420T:
    • Intel HD Graphics
  • Intel® Pentium® G3220T:
    • 2.6 GHz base frequency, 3 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
  • Intel® Pentium® G3250T:
    • Intel HD Graphics
  • Intel® Pentium® G3450T:
    • 2.9 GHz base frequency, 3 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
Intel® 4th Generation Celeron® Processors
  • Intel® Celeron® G1840T:
    • 2.5 GHz base frequency, 2 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
  • Intel® Celeron® G1820T:
    • 2.4 GHz base frequency, 2 MB cache, 2 cores, 2 threads
    • Intel HD Graphics
Storage
Feature
3.5" SATA Hard Drive
  • 2TB, 7200 rpm, SATA 6.0 Gb/s, SMART IV
  • 1TB, 7200 rpm, SATA 6.0 Gb/s, SMART IV
  • 500GB, 7200 rpm, SATA 6.0 Gb/s, SMART IV
2.5" SATA Hard Drive
  • 320GB, 7200 rpm, SATA 6.0 Gb/s, SMART IV
2.5" Self-Encrypting Solid State Drive
  • 256GB, SATA, Self-Encrypting Opal 2 Solid State Drive
  • 180GB Intel Pro 1500, SATA, Self-Encrypting Opal 1 Solid State Drive
  • 180GB SATA 2.5 Opal1 SED SSD
  • 180GB SATA 2.5 w/caddy Opal1 SED SSD
  • 128GB, SATA, Self-Encrypting Opal 2 Solid State Drive
  • 120GB SATA 2.5 Opal1 SED SSD
  • 120GB SATA 2.5 w/caddy Opal1 SED SSD
2.5" Solid State Drive
  • 128GB SATA 2.5 TLC SSD (Non-SED_TLC)
  • 128GB SATA 2.5 TLC w/caddy SSD (Non-SED_TLC)
  • 256GB SATA 2.5 SSD (Non-SED)
  • 256GB SATA 2.5 w/ca SSD (Non-SED)
  • 256GB SATA 2.5 TLC SSD (Non-SED_TLC)
  • 256GB SATA 2.5 TLC w/caddy SSD (Non-SED_TLC)
2.5" Self-Encrypting Drive
500GB, SATA, Self-Encrypting Drive
2.5" Solid State Hybrid Drive
  • 1TB SATA, Solid State Hybrid Drive
  • 1TB SATA 6G 2.5 8GB w/caddy SSHD Drive
  • 500GB, SATA, Solid State Hybrid Drive
Optical Disc Drive
  • Slim SATA DVD-ROM
  • Slim SATA SuperMulti DVD Writer
  • Slim SATA BDXL Blu-ray Writer
  • No included Optical Disc Drive
Removable
HP Slim Removable SATA HDD Frame/Carrier
Media Card Reader
  • HP 5-in-1
  • Supports Secure Digital (SD, SDHC, SDXC, Memory Stick (MS), Memory Stick Pro (MS Pro)
Product features
Feature
Intel® H81 Express
Graphics controller
Intel® Processor Graphics
DisplayPort
Support for 1 external display
Graphics Memory
Up to 1.8GB DDR3
Supported Graphics APIs
DX11.1, OpenGL 4.0, OpenCL 1.2, full 1080p Blu-Ray Disc (H264) playback in hardware
23" diagonal WVA (Wide Viewing Angle) widescreen WLED backlit anti-glare LCD
Aspect ratio
16:9
Contrast ratio
1000:1
Pixel pitch
0.2652 mm
Anti-glare
Yes
Optional integrated 1 MP webcam & dual microphone array; maximum resolution of 1280 x 720
Memory Type
Non-ECC, DDR3 SDRAM, 1600 MHz, SODIMM
Maximum memory
16GB
Memory slots
Two 204-pin slots supporting dual-channel memory
Ethernet (RJ-45)
Integrated Realtek RTL8151GH-CG GbE LOM 10/100/1000
Wireless
  • Intel 802.11 a/b/g/n wireless 7260 PCIe minicard (optional)
  • Intel 7260 802.11 a/b/g/n wireless PCIe mini card with Bluetooth Combo (optional)
  • HP 802.11 a/b/g/n wireless PCIe minicard with Bluetooth Combo (optional)
Audio/Multimedia
  • DTS Sound +™
  • Realtek ALC3228 codec – 16 & 24-bit PCM
  • Integrated business class 2.0 speakers (2W x 2)
  • Stereo headphone jack
  • Microphone in
  • Stereo line out
  • Optional integrated 1.0 MP webcam & dual microphone array – Up to 30 frames/sec
Keyboard
  • HP USB Standard:
    • 104 keys plus special functions for Mute, Volume Up, Volume Down, Sleep & Multimedia control keys
    • Separate numeric keypad
    • Cable length 71 in (180 cm)
  • HP Wireless Keyboard & Mouse:
    • Separate numeric keypad; two buttons with scroll wheel acting as third button
    • Operates at ~ 2.4 GHz and supports a working distance of up to 23 ft (7m)
    • Keyboard contains 25% post-consumer recycled plastic material
  • HP USB CCID SmartCard Keyboard:
    • 104, 105, 106, 107, 109 layout (depending upon country)
    • All ISO 7816 smart cards
  • HP USB PS/2 Washable Keyboard:
    • SpillSeal® keyboard technology protection
    • USB & PS/2 support in one solution
    • Cable length 7ft (2.2m)
Mice
  • HP USB Optical Mouse:
    • Two buttons with scroll wheel
  • HP USB 1000dpi Laser Mouse:
    • 1000 dpi support
    • Cable length 70.8 in (180 cm)
  • HP USB PS/2 Washable:
    • Scroll Mouse SpillSeal® mouse technology protection
    • Cable length 8.8 ft total (70 cm+ 2m extension)
Security
  • Security lock slot
  • HP UltraSlim Cable Lock (optional)
  • USB port disable (configurable at factory)
  • Rear cover security screw
Software overview
Feature
  • Microsoft Windows 8.1 Pro 64-bit
  • Microsoft Windows 8.1 (China) 64-bit
  • Microsoft Windows 8.1 Pro 64 downgrade to Windows 7 Professional 64-bit
  • Microsoft Windows 7 Professional (MSNA) 64-Bit
  • HP Installer Kit for Linux (includes drivers for 64-bit OS versions of RHEL 5 & 6 and SUSE Linux Enterprise Desktop 11)
  • Red Hat Enterprise Linux Desktop (Paper license with 1 year support; no preinstalled OS)
Feature
Windows 7
Windows 8.1
BIOS
  • HP BIOSphere
  • HP DriveLock
  • HP BIOS Protection
  • BIOS Update via Network
  • Master Boot Record Security
  • Power On Authentication
  • Pre-Boot Security
  • Secure Erase
  • Absolute Persistence Module
  • HP BIOSphere
  • HP DriveLock
  • Pre-Boot Security
  • Secure Erase
  • Hybrid Boot
  • Measured Boot
  • Secure Boot
Multimedia
  • CyberLink Power DVD, BD
  • CyberLink Power2Go (Secure Burn)
  • CyberLink YouCam BE
Communication
  • HP Wireless Hotspot
HP Value Add
  • HP Ceement
  • HP ePrint Driver
  • HP PageLift
  • HP Recovery Manager
  • HP Support Assistant
  • HP Recovery Disk Creator
  • HP ePrint Driver
  • HP PageLift
3rd Party
  • Foxit PhantomPDF Express for HP
  • Box 50GB Offer
  • Box 50GB Offer
  • Box App
Microsoft Products
  • Buy Office
  • Bing Search
  • Skype
  • Buy Office
  • Bing Search
  • Skype
Manageability
  • HP Drive Packs
  • HP SoftPaq Download Manager (SDM)
  • HP System Software Manager (SSM)
  • HP BIOS Config Utility (BCU)
  • HP Client Catalog
  • HP CIK for Microsoft SCCM
  • LANDESK Management
  • HP Drive Packs
  • HP Client Catalog
Security
  • HP Device Access Manager
  • HP Drive Encryption
  • HP File Sanitizer
  • HP Disk Sanitizer External Edition
  • HP Security Manager
  • Microsoft Security Essentials
  • HP File Sanitizer
  • Microsoft Defender
Standard
  • Preboot Authentication
Country: Flag Bulgaria
