HP Z440 Workstation - Specifications
HP SAS (Serial Attached SCSI) Hard Drives for HP Workstations
600GB SAS 15K rpm 6Gb/s 3.5" HDD
Feature
Capacity
600GB
Height
1 in; 2.54 cm
Width
  • Media Diameter: 3.5 in; 8.9 cm
  • Physical Size: 4 in; 10.17 cm
Interface
SAS
Synchronous Transfer Rate (Maximum)
6.0Gb/s
Buffer
16MB
Seek Time (typical reads, includes controller overhead, including settling)
  • Single Track: 0.2 ms
  • Average: 3.4 ms
  • Full Stroke: 6.6 ms
Rotational Speed
15,000 rpm
Logical Blocks
1,172,123,568 - 512 byte blocks
Operating Temperature
50° to 95° F (10° to 35° C)
300GB SAS 15K rpm 6Gb/s 3.5" HDD
Feature
Capacity
300GB
Height
1 in; 2.54 cm
Width
Interface
SAS
6Gb/s
Buffer
16MB
  • Average: 3.4 ms
Rotational Speed
15,000 rpm
HP 300GB SAS 10K SFF HDD
Feature
Capacity
300GB
Height
0.6 in; 1.53 cm
Width
  • Media Diameter: 2.5 in; 6.36 cm
  • Physical Size: 2.75 in; 6.99 cm
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
64MB Cache multi-segmentable cache buffer
  • Single Track: 0.4 ms (max)
  • Average: 3.6 ms
  • Full Stroke: 7.3 ms
Rotational Speed
10,000 rpm
Logical Blocks
585,937,500
41° to 131° F (5° to 55° C)
HP 600GB SAS 10K SFF HDD
Feature
Capacity
600GB
Height
0.6 in; 1.53 cm
Width
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
  • Average: 3.6 ms
Rotational Speed
10,000 rpm
Logical Blocks
1,172,123,568
HP 1.2TB SAS 10K SFF HDD
Feature
Capacity
1.2TB
Height
0.6 in; 1.53 cm
Width
Interface
SAS 6Gb/s
Up to 600MB/s
Buffer
  • Single Track: 0.18ms (max)
  • Average: 3.5ms
  • Full Stroke: 7.17ms
Rotational Speed
10,000 rpm
Logical Blocks
2,344,225,968
SATA (Serial ATA) Hard Drives for HP Workstations
500GB SATA 7200 rpm 6Gb/s 3.5" HDD
Feature
Capacity
500GB
Height
1 in; 2.5 cm
Width
Interface
Serial ATA (6.0Gb/s), NCQ enabled
Up to 600MB/s
Buffer
16MB
  • Single Track: 2 ms
  • Average: 11 ms
  • Full Stroke: 21 ms
Rotational Speed
7,200 rpm
Logical Blocks
976,773,168
1TB SATA 7200 rpm 6Gb/s 3.5" HDD
Feature
Capacity
1TB
Height
1 in; 2.54 cm
Width
Interface
Up to 600MB/s
Buffer
64MB
  • Average: 11 ms
Rotational Speed
7,200 rpm
2.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
Feature
Capacity
2.0TB
Height
1 in; 2.54 cm
Width
Interface
Up to 600MB/s
Buffer
64MB
  • Single Track: 1.0 ms
  • Average: 11 ms
  • Full Stroke: 18 ms
Rotational Speed
7,200 rpm
Logical Blocks
3,907,029,168
3.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
Feature
Capacity
3.0TB
Height
1 in; 2.54 cm
Width
  • Physical Size: 4.0 in; 10.17 cm
Interface
Up to 6.0Gb/s
Buffer
64MB
  • Single Track: 0.6 ms
  • Average: 11 ms
  • Full Stroke: Not Specified
Rotational Speed
7,200 rpm
41° to 140° F (5° to 60° C)
HP Solid State Drives (SSDs) for Workstations
HP 128GB SATA 6Gb/s SSD
Feature
Capacity
128GB
Height
0.28 in; 0.7 cm
Width
Physical Size: 2.5 in; 6.36 cm
Interface
SATA 6Gb/s
Up to 500MB/s (Sequential Read)
32° to 158° F (0° to 70° C)
HP 256GB SATA 6Gb/s SSD
Feature
Capacity
256GB
Height
0.28 in; 0.7 cm
Interface
SATA 6Gb/s
HP 256GB SATA 6Gb/s SED SSD
Feature
Capacity
256GB
Height
0.28 in; 0.7 cm
Width
Interface
6Gb/s SATA
HP 512GB SATA 6Gb/s SSD
Feature
Capacity
512GB
Height
0.28 in; 0.7 cm
Width
Interface
6Gb/s SATA
HP 1TB SATA 6Gb/s SSD
Feature
Capacity
1TB
Height
0.28 in; 0.7 cm
Width
Interface
6Gb/s SATA
Up to 550MB/s (Sequential Read)
Samsung Enterprise 240GB SATA SSD
Feature
Capacity
240GB
Width
Interface
SATA 6Gb/s
Up to 600MB/s
Samsung Enterprise 480GB SATA SSD
Feature
Capacity
480GB
Width
Interface
SATA 6Gb/s
Up to 600MB/s
Intel Pro 1500 180GB SATA SSD
Feature
Capacity
180GB
Width
Interface
6Gb/s SATA
600Mb/s
PCIe SSDs for HP Workstations
HP Z Turbo Drive 256GB SSD
Feature
Capacity
256GB
Interface
PCI Express 2.0 x4 electrical x4 physical
HP Z Turbo Drive 512GB SSD
Feature
Capacity
512GB
Interface
Hard Drive Controllers
LSI 9217-4i4e 8-port SAS 6Gb/s RAID Card
Feature
PCI Bus
8 lanes, PCI Express 3.0
RAID Levels
Offers Integrated RAID (0, 1, 1E and 10)
PCI Data Burst Transfer Rate
Half Duplex x8, PCIe, 8000MB/s
SAS Bandwidth
Half Duplex: 600MB/s per lane
PCI Card Type
3.3V Add-in card
PCI Voltage
12 V ± 10%
PCI Power
9.8W typical, Airflow min 200 LFM
Bracket
Full height and low profile
Certification Level
PCI Express 3.0 compliant
SAS Processor
LSI SAS2308/ Fusion MPT 2.0
Internal Connectors
One x4 internal mini-SAS (SFF8087)
External Connectors
One x4 external mini-SAS (SFF8088)
Maximum Number of SCSI Devices
256 Non-RAID SAS/SATA devices
LED Indicators
N/A
Graphics
NVIDIA NVS 310 512MB Graphics
Feature
Form Factor
Low Profile: 2.7 inches (H) x 5.7 inches (L), Half-Height
~142 grams
Graphics Controller
  • NVIDIA NVS 310
  • GPU: GF119-825
Bus Type
PCI Express x16, 2.0 compliant
Memory
  • Size: 512MB DDR3
  • Clock: 875Mhz
  • Memory Bandwidth: 14GB/s
Connectors
2 x DisplayPort
Maximum Resolution
Up to 2560 x 1600 (digital display) per display
Image Quality Features
The following video formats are supported:
  • MPEG2
  • MPEG4 Part 2 Advanced Simple Profile
  • H.264 SVC codec support
  • Support for 3D Blu Ray
  • VC1
  • DivX version 3.11 and later
  • MVC
A full range of video resolutions are supported including 1080p, 1080i, 720p, 480p and 480i. The NVS 310 GPU provides hardware acceleration for the computationally intensive parts of video processing, as well as provides improved video playback speeds via faster decode and transcode.
Display Output
Up to 2 displays in the following configurations:
DisplayPort output:
  • Drives two DisplayPort enabled digital displays at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected natively using the 2 DisplayPort connectors on the NVS 310 graphics card
  • Supports 2 monitors up to resolution of 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort 1.2 multi stream topology technology
DVI-D output:
  • Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors
  • Drives two digital display at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors
HDMI output:
  • NVS 310 is capable of driving two high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors
VGA display output:
  • Drives two analog display at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors
Shading Architecture
Shader Model 5.0
Supported Graphics APIs
DX11, OpenGL 4.1
Available Graphics Drivers
  • Windows 8 Genuine Microsoft
  • Windows 7 Professional (64-bit and 32-bit)
  • Windows XP Professional (64-bit and 32-bit)
  • Red Hat Enterprise Linux(RHEL)
  • SUSE Linux Enterprise Desktop 11 (64-bit and 32-bit)
Power Consumption
19.5 Watts
Notes
  1. The thermal solution used on this card is an active fan heatsink.
  2. Factory configured NVS 310 graphics card have no cable adapters included. Adapters must be ordered separately.
  3. Option kit NVS 310 includes 2 DP to DVI-D cable adapters.
NVIDIA NVS 315 1GB Graphics (for HP Workstations)
Feature
Form Factor
Low Profile: 2.713 × 5.7 in
~142 grams
Graphics Controller
  • NVIDIA NVS 315 (using GF119-825 GPU)
  • Number of Cores: 48 CUDA cores
  • Max. Power: 19.3W
  • Cooling Solution: Active fan heatsink
Bus Type
Memory
  • Size: 1GB DDR3
  • Clock: 875Mhz
Connectors
DMS-59 output
Cables Included
  • For CTO: DMS-59 to DVI cable
  • For AMO: DMS-59 to DVI cable and DMS-59 to VGA cable
Maximum number of displays supported
2
Maximum Resolution
  • DMS-59 to VGA: 2048 x 1536 @ 85Hz
  • DMS-59 to DVI: 1980 x 1200 @ 60Hz
  • DMS-59 to DP: 2560 x 1600 @ 60Hz
  • MPEG2
  • VC1
  • DivX version 3.11 or later
A full range of video resolutions are supported including 1080p, 1080i, 720p, 480p and 480i. The NVS 315 GPU provides hardware acceleration for the computationally intensive parts of video processing, as well as provides improved video playback speeds via faster decode and transcode.
Display Output
Up to 2 displays using either a DMS-59 to DVI cable, a DMS-59 to VGA cable, or a DMS-59 to DP cable
DisplayPort output:
  • Drives two DisplayPort enabled digital displays at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking when connected via the DMS-59 to DP adapter
DVI-D output:
  • Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DMS-59 to DVI-D single-link cable adaptor
VGA display output:
  • Drives two analog display at resolutions up to 2048 × 1536 at 85 Hz using DMS-59 to VGA cable adaptor.
Shader Model 5.0
DX11, OpenGL 4.3
  • Windows 8
  • Red Hat Enterprise Linux (RHEL)
Notes
  2. Factory configured graphics card includes DMS-59 to DVI cable
  3. Option kit graphics card includes DMS-59 to DVI and DMS-59 to VGA cables (one each)
NVIDIA NVS 510 2GB Graphics
Feature
Form Factor
Low Profile: 2.713 x 6.3 in, single slot
Graphics Controller
  • NVS 510 GPU
  • Core Clock: 797 Mhz
  • Memory Clock: 891 Mhz
  • CUDA Cores: 192
Bus Type
PCI Express x16, Generation 2.0
Memory
2GB DDR3
Connectors
Four mini-DisplayPort
Four mini-DisplayPort to DisplayPort adapters included. (DisplayPort to DVI-D, DisplayPort to VGA, DisplayPort to HDMI, and DisplayPort to Dual-Link DVI adapters available as separate accessories)
Maximum Resolution
Mini-DisplayPort connectors support ultra-high-resolution panels (up to 3840 x 2160 @ 60Hz)
10-bit internal display processing, including hardware support for 10-bit scanout
Display Output
DisplayPort with Multi-Stream Technology (MST) and High Bit Rate 2 (HBR2) support
DisplayPort output:
  • Drives four DisplayPort enabled digital display at resolutions up to 3840 × 2160 at 60 Hz with reduced blanking, when connected natively using the 4 DisplayPort connectors on the NVS 510 graphics card
  • DisplayPort Multi-Stream Topology (MST) Technology supports various combinations of display resolutions and number of displays - up to a maximum of 4 monitors at a resolution of 1920 × 1200 at 60 Hz with reduced blanking
DVI-D output:
  • Drives four digital displays at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors
  • Drives four digital displays at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors
HDMI output:
  • The NVS 510 graphics board is capable of driving four high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors
VGA display output:
  • Drives four analog displays at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors
Full Microsoft DirectX 11, Shader Model 5.0 support Full OpenGL 4.3 support
  • Genuine Windows 7 Professional (64-bit and 32-bit)
  • Microsoft Windows XP Professional (64-bit and 32-bit)
  • Red Hat Enterprise Linux(RHEL) 6 Desktop/Workstation
Note
  1. Heatsink cooler design is active
NVIDIA Quadro K620 2GB Graphics
Feature
Form Factor
2.713" H x 6.3" L Single Slot, Low Profile Full Height
133 grams
Graphics Controller
  • GM107 GPU
  • 384 CUDA cores
Max Power
45 Watts
Bus Type
PCI Express 2.0 x16
Memory
  • Size: 2GB GDDR3, 900 MHz 128-bit memory
  • Memory Bandwidth: 29GB/s memory bandwidth
Connectors
1 DL-DVI(I) output, 1 DisplayPort output
Maximum Resolution
  • DisplayPort 1.2: 4096x2160 x 30 bpp @ 60Hz - supports High Bit Rate 2 (HBR2) and Multi-Stream Transport (MST)
  • Dual Link DVI(I): 2560 x 1600 x 32 bpp @ 60Hz Single Link-DVI(I) output: - up to 1920 x 1200 x 32 bpp @ 60Hz
10-bit internal display processing pipeline 10-bit scan-out support
Display Output
  • 1 Dual-link DVI-I connector
  • 1 Display Port connector Shading Architecture
Full Microsoft DirectX 11.1 Shader Model 5.0
  • OpenGL 4.4
  • DirectX 11.1
  • API support includes CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Java, Python, and Fortran
  • Windows 8.1
  • Windows 8
  • Windows 7
  • Linux
NVIDIA Quadro K420 1GB Graphics
Feature
Form Factor
Graphics Controller
GK107 GMU
Bus Type
Memory
  • Size: 1GB DDR3
  • Clock: 891MHz
Connectors
  • One dual-link DVI-I connector
  • One DisplayPort connector
Maximum Resolution
  • VGA (via adapter cable): 2048 × 1536 × 32 bpp at 85 Hz
  • Dual-link DVI: 2560 × 1600 × 32 bpp at 60 Hz (reduced blanking)
  • Single-link DVI: 920 × 1200 × 32 bpp at 60 Hz (reduced blanking)
  • DisplayPort 1.2: 3840 × 2160 × 30 bpp at 60 Hz
RAMDAC
400 MHz integrated RAMDAC
2
Shader Model 5.0
DX11, OpenGL 4.4
Programming support for CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Python, and Fortran
  • Windows 8.1
  • Windows 8
  • Windows 7
  • Linux
Notes
  1. Factory configured Quadro K420 does not include any video adapters. Adapters must be ordered separately.
  2. Option kit Quadro K420 includes one DP to DVI-D adapter.
NVIDIA Quadro K2200 4 GB Graphics Form Factor
Feature
Form Factor
4.38 H x 7.97 in L Single Slot, Full Height
240 grams
Graphics Controller
  • GM107 GPU
  • 640 CUDA cores
Max Power
67.7 Watts
Bus Type
PCI Express 2.0 x16
Memory
  • Size: 4GB GDDR5, 2500 Mhz 128-bit memory
  • Memory Bandwidth: I/O path 80GB/s
Connectors
1 DL-DVI(I) output, 2 DisplayPort outputs
Maximum Resolution
  • DisplayPort: 4096 x 2160 x 30 bpp @ 60Hz (only one monitor can be connected to a Quadro K2200 DisplayPort connector at this resolution) - supports High Bit Rate 2 (HBR2) and Multi-Stream Transport (MST)
  • DL-DVI(I): 2560 x 1600 x 32 bpp @ 60Hz
  • SL-DVI(I): 1920 x 1200 x 32 bpp @ 60 Hz
  • VGA: 2048 x 1536 x 32 bpp @ 85 Hz
  • 10-bit internal display processing pipeline
  • 10-bit scan-out support
Display Output
DisplayPort output:
  • Supports HBR2 and MST
VGA display output:
  • requires use of DVI-to-VGA and/or DP-to-VGA video cable adapters
  • 400 MHz integrated RAMDAC
  • OpenGL 4.4
  • DirectX 11.1
  • Windows 8.1
  • Windows 8
  • Windows 7
  • Linux
Notes
  1. Quadro K2200 offered as Factory Configured Option does not include a video cable adapter. Video cable adapters must be ordered separately.
  2. Quadro K2200 offered as an Option Kit includes one DP-to-DVI video cable adapter. Additional cables must be ordered separately.
  3. A total maximum of 4 active monitors are supported across all display output types. This may be accomplished by using daisy chained DisplayPort 1.2 displays or a DisplayPort 1.2 hub device.
AMD FirePro W2100 2GB Graphics
Feature
Form Factor
Low Profile, half length (full-height bracket included)
Graphics Controller
  • AMD FirePro W2100 professional graphics
  • Power: Less than 50W
  • Cooling: Active
Bus Type
PCI Express x8, Generation 3.0
Memory
  • Size: 2GB DDR3
  • Memory Bandwidth: 14.4GB/s
Connectors
2x Display Port 1.2
Maximum Resolution
  • Dual Link DVI(I) (requires adapter cable): 2560 x 1600 x 32 bpp @ 60Hz
  • Single Link-DVI(I) (requires adapter):
  • VGA (requires adapter): 1920 x 1200 x 32 bpp @ 60Hz
Shader Model 5.0
OpenCL 1.2, DirectX 11 and OpenGL 4.4
  • Windows 8.1 (64-bit and 32-bit)
  • Windows 7 (64-bit and 32-bit)
  • SUSE Linux Enterprise Desktop 11(64-bit and 32-bit)
  • Ubuntu
Note
  1. Depending on the card model, native DisplayPort connectors and/or certified DisplayPort active or passive adapters to convert your monitor's native input to your card's DisplayPort or Mini-DisplayPort connector(s) may be required.
NVIDIA Quadro K4200 4GB Graphics
Feature
Form Factor
4.376" H x 9.5" L Single Slot, Full Height
~458 grams (without extender)
Graphics Controller
  • Kepler GK104 GPU
  • 1344 CUDA cores
  • Max Power: 108 Watts
Bus Type
PCI Express 2.0 x16
Memory
  • Size: 4GB GDDR5, 2700 MHz 256-bit
  • Memory Bandwidth: I/O path 173GB/s
Connectors
Maximum Resolution
  • DisplayPort: 3840 x 2160 x 30 bpp @ 60Hz - supports High Bit Rate 2 (HBR2) and Multi-Stream Transport (MST)
  • DisplayPort: 3840 x 2160 x 30 bpp @ 60 Hz (only one monitor can be connected to a Quadro K4200 DisplayPort connector at this resolution)
Display Output
DisplayPort output:
VGA display output:
Maximum number of monitors across all available Quadro K4200 outputs is 4.
Full Microsoft DirectX 11 Shader Model 5.0
  • OpenGL 4.4
  • DirectX 11.1
  • Windows 8.1
  • Windows 8
  • Windows 7
  • Linux
Power Consumption
Notes
  1. Quadro K4200 offered as CTO does not include a video cable adapter. Video cable adapters must be ordered separately.
  2. Quadro K4200 offered as AMO includes one DP-to-DVI video cable adapter. Additional cables must be ordered separately.
NVIDIA Quadro K5200 8GB Graphics
Feature
Form Factor
4.376" H x 10.5" L Dual Slot
~880 grams
Graphics Controller
  • GK 110 GPU
  • 2304 CUDA cores
  • Max Power: 150 Watts
Bus Type
PCI Express 3.0 x16
Memory
  • Size: 8GB GDDR5 256-bit
  • Memory Bandwidth: I/O path 192GB/s
Connectors
DVI-I (1), DVI-D (1), DP (2)
Maximum Resolution
  • VGA (through DVI to VGA cable): 2048 × 1536 × 32 bpp at 85 Hz
  • Dual-link internal TMDS (DVI 1.0) (single GPU and SLI mode): 2560 × 1600 × 32 bpp at 60 Hz (reduced blanking)
  • Single-link internal TMDS (DVI 1.0) (single GPU and SLI mode): 1920 × 1200 × 32 bpp at 60 Hz (reduced blanking)
  • DisplayPort with MST and HBR2: 4096 × 2160 × 30 bpp at 60Hz, 2560 x 1600 x 30bpp at 120Hz
  • HDMI: 1920 × 1080 × 32 bpp at 60Hz
DisplayPort with Multi-Stream Technology (MST) and High Bit Rate 2 (HBR2), HDMI 1.4, and HDCP support
NVIDIA 3D Vision technology
Display Output
Shader Model 5.0
  • OpenGL 4.4
  • DirectX 11
  • API support for NVIDIA's CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Java, Python, and Fortran
  • Windows 8
  • Red Hat Enterprise Linux (RHEL) 6 Desktop/Workstation (64-bit)
  • SUSE Linux Enterprise Desktop 11 SP3(64-bit and 32-bit)
Note
  1. NVIDIA GRID VGX Pass Through feature supported on NVIDIA Quadro K5200 to enable direct mapping of GPU to Virtual Machine.
  2. No display output adapter included.
NVIDIA Quadro K6000 12GB Graphics
Feature
Form Factor
Power
234 Watts
~880 grams
Graphics Controller
  • GK180 GPU
  • Core Count: 2880
  • Base Clock: 797 MHz
  • Boost Clock: 902 MHz
Bus Type
PCI Express 3.0 x16
Memory
  • Size: 12GB GDDR5 384-bit
  • Memory Bandwidth: I/O path 288GB/s
Connectors
DVI-I (1), DVI-D (1), DP (2), Optional 3D Stereo bracket with 3-pin mini-DIN connector
Maximum Resolution
  • DisplayPort with MST and HBR2: 3840 × 2160 × 36 bpp at 60Hz
  • DisplayPort with Multi-Stream Technology (MST) and High Bit Rate 2 (HBR2), HDMI 1.4, and HDCP support
  • NVIDIA 3D Vision technology
  • NVIDIA Premium Mosaic and nView
Display Output
Shader Model 5.0 Full IEEE 764-2008 32-bit and 64-bit precision
  • Full OpenGL 4.3
  • Full DirectX 11
  • CUDA API support includes CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Java, Python, and Fortran
  • Windows 8
Notes
  1. NVIDIA GRID VGX Pass Through feature supported on NVIDIA Quadro K6000 to enable direct mapping of GPU to Virtual Machine.
High Performance GPU Computing
NVIDIA Tesla K40 Workstation Compute Processor
Feature
Form Factor
  • Size: 4.376 inches by 10.5 inches
  • Slots: Dual Slot
  • Power Connectors: One 6-pin and one 8-pin
~826 grams
System Interface
PCI Express Gen3 ×16
Video Outputs
None
Memory
  • 12GB GDDR5
  • Memory path: 384-bit
  • Memory clock: 3Ghz
Peak Memory Bandwidth
288 GB/s
Supported APIs
CUDA, OpenACC, OpenCL 1.2 API support includes C, C++, Java, Python, and Fortran
Supported Operating Systems
  • Windows 8 (64-bit)
  • Genuine Windows 7 Professional (64-bit)
  • Red Hat Enterprise Linux (RHEL) 5, 6 Desktop/Workstation (64-bit)
  • SUSE Linux Enterprise Desktop 11 (64-bit)
Processor Cores
  • GK110B GPU
  • Base Clock: 745 MHz
  • Boost Clock: up to 875 MHz
  • 2888 CUDA cores
Power Consumption
~235 Watts
Optical and Removable Storage
HP DX115 Removable Drive Enclosure
Feature
Interface Type
Compatible with SAS or SATA controllers. Offers 6Gb/s performance when used with 6Gb/s HDDs.
Dimensions (WxHxD)
5.81" x 1.62" x 8.08" (147.6mm x 41.1mm x 205mm)
  • Frame and Carrier: 3.8 lbs (1.73 kg)
  • Carrier: 1 lb (0.45 kg)
HP 15-in-1 Media Card Reader
Feature
  • Supports hardware ECC (Error Correction Code) function
  • Supports hardware CRC (Cyclic Redundancy Check) function
  • Supports MS 4-bit parallel transfer mode
  • Supports MS-PRO 4-bit parallel transfer mode
  • Supports MS PRO-HG Duo 4-bit parallel transfer mode
  • Supports SD 4-bit parallel transfer mode
  • Supports UHS-104 SD 4-bit card (version 3.0)
  • Supports CF v6.0 with PIO mode 6 and Ultra DMA 7 mode
Interface Type
USB 3.0 High-speed interface
Dimensions (WxHxD)
4.9 x 4 x 1 in (124.5 x 101.6 x 25.4 mm)
Fits conveniently in the 5.25" drive bay
Supported Media Types
  • CompactFlash Type I
  • CompactFlash Type II
  • Microdrive
  • Secure Digital Card (SD)
  • Secure Digital High Capacity (SDHC)
  • SD Extended Capacity Memory Card (SDXC)
  • SD Ultra High Speed II (SD UHSII)
  • Memory Stick
  • Memory Stick Select
  • Memory Stick Duo (MS Duo)
  • Memory Stick PRO (MS PRO)
  • Memory Stick PRO Duo (MS PRO Duo)
  • Memory Stick PRO-HG Duo
  • MagicGate Memory Stick (MG)
  • MagicGate Memory Stick Duo
These additional media types are supported with a card adapter:
  • Memory Stick Micro (M2)
  • miniSD
  • miniSD High Capacity
  • Micro SD Memory Card (MicroSD)
  • Micro SD High Capacity Memory Card (MicroSDHC)
Operating Systems Supported
  • Windows 8 Pro (64-bit)
  • Windows 8.1 (64-bit)
  • Windows 7 Ultimate (32-bit)
  • Windows 7 Ultimate (64-bit)
  • Windows 7 Professional (32-bit)
  • Windows 7 Professional (64-bit)
  • Windows 7 Home Basic
  • Windows 7 Home Premium (32-bit)
  • Windows 7 Home Premium (64-bit)
  • Windows Vista Business 64
  • Windows Vista Business 32
  • Windows Vista Home Basic 32
  • Windows XP Home 32
No driver is required for this device. Native support is provided by the operating system.
Kit Contents
Media card reader, 5.25" bracket/rails/bezel, Install Guide, IO & Security Software and Documentation CD
Approvals
USB-IF, WHQL, Compliant with USB Mass Storage Class Bulk only Transport Specification Rev. 1.0, Compliant Intel Front Panel I/O Connectivity Design Guide V. 1.3, FCC, CE, BSMI, C-Tick, VCCI, MIC, cUL, TUVT
0.35 lbs (0.16 kg)
Controller Cards
HP IEEE 1394b FireWire PCIe Card
Feature
Data Transfer Rate
Supports up to 800Mbps
Devices Supported
IEEE-1394 compliant devices
Bus Type
PCIe card full height PCIe slots
Ports
Two IEEE-1394b external 9-Pin connectors (Rear)
Internal Connectors
One 10-Pin header Custom Connector
System Requirements
Windows 8.1 64-bit, Windows 7 Professional 32-bit and 64-bit, SLED 11 and RHEL 6. Intel i5 series or higher processor, min 2GB of RAM, 20GB Hard Drive, CD-ROM drive, built in sound system, Available PCIe slot.
Temperature – Operating
50° to 131° F (10° to 55° C)
Temperature – Storage
–22° to 140° F (–30° to 60° C)
Relative Humidity – Operating
20% to 80%
Compliances
FCC Part 15B, cULus 60950, CE Mark EN55022B(1995)/EN55024-1998 STD, Taiwan BSMI CNS13438, Korea MIC
HP Thunderbolt-2 PCIe 1- port I/O Card
Feature
Data Transfer Rate
Supports up to 20Gb/s (20,000Mb/s)
Devices Supported
Thunderbolt certified devices
Bus Type
PCIe card, full or half height PCIe slots
Ports
One Thunderbolt 2 external 20-Pin output connectors (Rear)
One full size DisplayPort input connector (Rear)
Internal Connectors
One 5-Pin header connector
System Requirements
Genuine Windows 7 Professional 64-bit, Genuine Windows 8.1 64-bit, Intel i5 series or higher processor, 4-GB RAM, 20-GB Hard Drive, available PCIe slot.
-22° to 140° F (-30° to 60° C)
20% to 80%
Compliances
Kit Contents
HP Thunderbolt 2 PCIe 1-port I/O Card, full height and half height bracket, DisplayPort to DisplayPort cable, internal header cables (2), user documentation and warranty card
Integrated Intel I218LM PCIe GbE Controller
Feature
Connector
RJ-45 (motherboard integration)
Controller
Intel I218LM GbE platform LAN connect networking controller
Memory
3KB FIFO packet buffer memory (both Tx and Rx)
Data Rates Supported
10/100/1000 Mbps
Compliance
802.1as, 802.1p, 802.1Q, 802.3, 802.3ab, 802.3az, 802.3i, 802.3u, 802.3x, 802.3z
Bus Architecture
PCI Express 1.1 (x1) and SMBus
Data Path Width
X1, 250 MB/s, Bi-directional interface
Data Transfer Mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power Requirement
Requires 3.3V only (integrated regulators)
Boot ROM Support
Yes
Network Transfer Rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Management Capabilities
  • WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostics
  • AMT 9.1 support, vPro compliant
HP X520 10GbE Dual Port Adapter
Feature
Hardware Certifications
FCC B, UL, CE, VCCI, BSMI, CTICK, KCC
HP 10GbE SFP+ SR Transceiver
Feature
32°F to 113°F (0°C to 45°C)
Operating Humidity
0% to 85%, noncondensing
Dimensions (H x W x D)
0.47 x 0.54 x 2.19 in (1.19 x 1.38 x 5.57 cm)
HP 361T PCIe Dual Port Gigabit NIC
Feature
Connector
Two RJ-45
Controller
Intel Ethernet I350 Controller
10/100/1000 Mbps, Half- and full-duplex
Compliance
  • 802.3, 802.3u, 802.3x, 802.3ab, 802.3ad, 802.1p, 802.1Q, 802.3az, IEEE 1588
  • PCIe v2.0 standard
  • RoHS (6 of 6)
  • FCC (U.S. only) Class B
  • DOC (Canada) Class B
  • CE EN 55024, EN55022 Class B
  • VCCI Class II
  • UL 1950
  • CSA 950
  • EN 60950
  • CE
  • ACPI 1.1a
  • Microsoft WHQL (Windows Hardware Quality Labs)
Data Path Width
Four lane (x4) PCI Express compatible with x4, x8, and x16 PCI Express slots
Power Requirement
  • 4.1W idle without EEE link partner
  • 3.2W idle with EEE link partner
  • 4.2W maximum
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
32° to 131°F (0° to 55° C)
Operating Humidity
10% to 95% non-condensing
Dimensions (H x W)
5.3 x 2.5 in (13.50 cm x 6.4 cm) (without brackets)
Operating System Driver Support
  • Windows 7 Professional 32-bit and 64-bit
  • Red Hat Enterprise Linux(RHEL) WS4, 5, 6 Desktop/Workstation
  • Novell SLED 10 & SLED 11
Kit Contents
  • HP 361T PCIe Dual Port Gigabit NIC PCA with a standard height bracket attached to it (the low profile bracket is included in the clamshell that the PCA ships in)
  • Product Warranty statement and the Quick Install Card (QIC)
Intel 7260 802.11 a/b/g/n PCIe WLAN NIC
Feature
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
  • Native HMC: 26.8 x 30.0 x 2.4 mm
  • Carrier Card Assembly: 84 x 119 mm
Kit Contents
PCIe x1 card with full height bracket, rf antenna, antenna cable, separate low profile bracket, software CD and warranty
Country: Flag Bulgaria
