    Looking for Site Help?
Remove and replace the hard disk drive assembly for HP ENVY 15-c000 x2 Detachable PCs
This document applies to HP ENVY 15-c000 x2 detachable computers.
Before you begin
  • Have a Phillips head screwdriver, tweezers or needle-nose pliers, and a non-marring flat-bladed tool, or similar prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP ENVY 15-c000 x2 detachable computers.
Removing the hard disk drive assembly
Follow the steps in this section to remove the hard disk drive assembly.
  warning:
Step 1
First remove the recess cover.
Using a non-marring flat-bladed tool, carefully remove the recess cover from the retention tabs and loosen the adhesive that adheres it to the display enclosure...
Removing the recess cover from the retention tabs and the adhesive
...and lift and remove the recess cover.
Step 2
Remove the display enclosure.
For instructions to remove the display enclosure, see the HP support document, Remove and Replace the Display Enclosure for HP ENVY 15-c000 x2 Detachable PCs.
Lifting and removing the display enclosure
Step 3
Carefully disconnect the battery cable from its connector on the system board.
Disconnecting the battery cable
Step 4
Carefully lift the locking bar up and hard disk drive ZIF connector...
Lifting the locking bar on the hard drive ZIF connector
...and disconnect the hard disk drive ribbon cable from the system board.
Disconnecting the hard drive ribbon cable from the system board
Step 5
Lift the disk drive assembly out of the display panel assembly...
Lifting the hard drive off the display panel assembly
...carefully guiding the hard disk drive ribbon cable out from under the heatsink.
Place the hard drive assembly in a static dissipative bag to protect it.
Guiding the ribbon cable from under the heatsink
Replacing the hard disk drive assembly
Use the steps in this section to replace the hard disk drive assembly.
Step 1
To replace the hard disk drive assembly, guide the ribbon cable under the heatsink...
Guiding the ribbon cable under the heatsink
...and lower the hard disk drive assembly into the cradle on the display panel assembly.
Lowering the hard disk drive assembly into place in its cradle
Step 2
Insert the hard disk drive ribbon cable into its ZIF connector on the system board...
Inserting the hard disk drive ribbon cable into its connector
... and press the locking bar down to lock the cable in place.
Pressing the locking bar down
Step 3
Carefully reconnect the battery cable to its connector on the system board.
Reconnecting the battery cable
Step 4
Replace the display enclosure.
For instructions to replace the display enclosure, see the HP support document, Remove and Replace the Display Enclosure for HP ENVY 15-c000 x2 Detachable PCs.
Replacing the display enclosure
Step 5
Insert the retention tabs on the cover into the tabs on the display enclosure.
Inserting the retention tabs on the cover into the tabs on the display enclosure
Step 6
Gently press down to secure the recess cover into place.
Pressing the recess cover into place
Country: Flag Bulgaria
