HP LaserJet Enterprise MFP M630 - Install the stapling mailbox accessory
This document provides the procedure to install the stapling mailbox accessory for the HP LaserJet Enterprise MFP M630z.
Figure : Stapling mailbox
  1. Remove the packing material from the stapling mailbox.
    Figure : Remove packing material
  2. Press the power button to turn the product off.
    Figure : Turn the product off
  3. M630dn, M630h, and M630f: Pull the output bin and bezel straight out, and then lift up to remove them.
    Figure : Remove the output bin and bezel
  4. Align the rails of the stapling mailbox with the tracks inside the product.
    Figure : Align the stapling mailbox
  5. Connect the accessory connector.
    Figure : Connect the accessory connector
  6. Slide the stapling mailbox into place.
    Figure : Slide stapling mailbox into place
  7. Press the power button to turn the product on.
    Figure : Turn the product on
  8. OS X: The list of installed options automatically updates during the first print job after installing the accessory. Setup is complete.
    Windows: If you are attaching the accessory before you have installed the product software, perform the following steps:
    1. Make sure the product is turned on and connected to the computer or network.
    2. Open the printers folder on the computer.
    3. Right-click the name of this product, and select Printer Properties.
    4. Click the Device Settings tab.
    5. Click the Installable Options section.
    6. In the drop-down box next to Automatic Configuration, select Update Now.
Uninstall the stapling mailbox
  1. Press the button on the top of the stapling mailbox to release it from the product.
    Figure : Release the stapling mailbox
  2. Disconnect the accessory connector.
    Figure : Disconnect accessory connector
