Printer Specifications for HP LaserJet Pro MFP M201, M202 Printers
This document is for HP LaserJet Pro MFP M201 and LaserJet Pro MFP M202 printers.
Review this document for detailed technical data, such as model numbers, system requirements, print speeds, connectivity types, physical dimensions, cartridges, paper handling, and print specifications.
Printer Model
Product Number
HP LaserJet Pro MFP M201n Printer
Image: HP LaserJet Pro MFP M201n printer
CF455A
HP LaserJet Pro MFP M202n Printer
Image: HP LaserJet Pro MFP M202n printer
C6N20A
HP LaserJet Pro MFP M201dw Printer
Image: HP LaserJet Pro MFP M201dw printer
CF456A
HP LaserJet Pro MFP M202dw Printer
C6N21A
Connectivity
The following table contains types of connection methods supported by this printer.
Model
Wireless
Ethernet
USB
Wireless Direct
No
10/100Base LAN
Hi-speed USB 2.0
No
Yes
10/100Base LAN
Hi-speed USB 2.0
Yes
No
10/100Base LAN
Hi-speed USB 2.0
No
HP LaserJet Pro MFP M202dw printer
Yes
10/100Base LAN
Hi-speed USB 2.0
Yes
Mobile printing capability
The following table contains types of mobile printing technologies supported by this printer.
Model
ePrint
ePrint mobile app
Apple AirPrint
Android Built-in Print Solution
Yes
No
No
Yes
Yes
No
Yes
Yes
Yes
No
No
Yes
Yes
No
Yes
Yes
Supported Web Services
The following table describes the Web Services the printers support.
Model
Print apps
Scheduled Delivery Printables
No
Yes
No
Yes
No
Yes
No
Yes
System requirements
The following sections contain the minimum system requirements for supported Windows and Mac operating systems.
This printer might be compatible with operating systems not listed if they were released after this specification was created. HP might have driver downloads available, or the printer might work with drivers built into the operating system.
Physical dimensions
Select your printer model to review its physical dimensions.
Cartridges
Refer to the following table for print cartridge types, names, and part numbers.
Cartridge name
Type
HP 83A Toner Cartridge
Replacement print cartridge
CF283A
HP 83XToner Cartridge
High-capacity replacement print cartridge
CF283X
HP 88A Toner Cartridge
Replacement print cartridge (China and India only)
CC388A
Control panel display
Review the following specifications to learn the size and display type of the printer's control panel.
  • Type:2-line LCD graphical display with push-button navigation
  • Dimensions:
    • Diagonal: 142.2 mm (5.6 inches)
    • Length: 119.4 mm (4.7 inches)
    • Height: 83.8 mm (3.2 inches)
  • Color or black and white: Black and white
  • Special features: Anti-glare finish
Paper-handling specifications
Review the following tables to make sure that you are using the correct paper types and sizes and are not overloading the input tray.
Printing specifications
Review the following for print resolutions, method, and speeds.
  • Output: Black and white only
  • Normal mode resolution: 600 x 600 dpi
  • Plain-Best mode resolution: Up to 1200 dpi
  • Device languages: PCL5c, PCL6, PS, PCLm, PDF
  • Print speed: Up to 26 ppm*
  • First page out: Up to 8 seconds
  • Duty cycle: 8,000 pages per month
* Print speeds vary according to the complexity of the document.
Copy specifications
The printer does not support copying.
Scanning specifications
The printer does not support scanning.
Faxing specifications
The printer does not support faxing.
Power specifications
Review the following information for power specifications.
Review the following information for the power specifications of the LaserJet Pro M225dn printer.
  • Power supply: Internal power supply
  • Power requirements:
    • Input voltage: 110 to 127 VAC (+/- 10%), 60 Hz (+/- 2 Hz)
      • India and China: 220 to 240 VAC (+/- 10%), 50 Hz (+/- 2Hz)
  • Power consumption: 450 watts maximum, 2.2 watts (Ready), 0.1 watts (Auto-Off), 0.1 watts (Manual Off)
Acoustic emission specifications
Review the following information for the printer's acoustic emission specifications.
  • Sound pressure (bystander position): LpAm 50 (dBA) (mono Draft print)
  • Sound power: 6.3 B(A)
Environmental specifications
Review the following information for the printer's environmental specifications.
Allowed operating conditions
Review the following information for the printer's allowed operating conditions.
Factor
Temperature
15° to 30° C; 59° to 86° F
Humidity
10% to 80% relative humidity
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
For information about material safety data sheets, go to the HP Material safety data sheets (MSDS) website.
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on these program is available on HP's Product return and recycling website.
Regulatory model number
For regulatory identification purposes, your printer is assigned a Regulatory Model Number. The Regulatory Model Number for your printer is SHNGC-1302-00 or SHNGC-1302-01. This regulatory number should not be confused with the marketing name (HP LaserJet Pro MFP M225dn, LaserJet Pro MFP M226dn, etc.) or product numbers (CF485A or C6N23A, etc.).
