HP DL380z Gen8 Virtual Workstation Product Specifications
Product description
The HP DL380z Gen8 Virtual Workstation is a focused 2U 2-socket rack ecosystem solution based on the proven technologies offered on the HP Proliant DL380p Gen8 server.
Product features
Feature
Processor (one of the following)
E5-2600 v2 series processors
Base processors1:
Intel Xeon E5-2630 v2 (2.6GHz/6-core/15MB/7.2GT-s QPI/80W, DDR3-1600, HT, Turbo2- 3/3/3/3/4/5)
Performance processors2
  • Intel Xeon E5-2695 v2 (2.4GHz/12-core/30MB/8.0GT-s QPI/115W, DDR3-1866, HT, Turbo2- 4/4/4/4/4/4/4/4/5/6/7/8)
  • Intel Xeon E5-2680 v2 (2.8GHz/10-core/25MB/8.0GT-s QPI/115W, DDR3-1866, HT, Turbo2- 3/3/3/3/3/4/5/6/7/8)
  • Intel Xeon E5-2670 v2 (2.5GHz/10-core/25MB/8.0GT-s QPI/115W, DDR3-1866, HT, Turbo2- 4/4/4/4/4/4/5/6/7/8)
  • Intel Xeon E5-2650 v2 (2.6GHz/8-core/20MB/8.0GT-s QPI/95W, DDR3-1866, HT, Turbo2- 4/4/4/4/5/6/7/8)
Cache memory7 (one of the following)
  • 30MB (1x30MB) Level 33
  • 25MB (1x25MB) Level 34
  • 20MB (1x20MB) Level 35
  • 15MB (1x15MB) Level 36
  • Intel C600 Series Chipset
  • Intel E5-2600 v2 Processor Family
Upgradeability
  • Upgradeable to 2 processors (24 Cores)
  • Up to 24 DIMM slots available for higher Memory capacity
  • FlexibleLOM connector for 1 Gigabit or 10 Gigabit networking options
  • 8SFF Hard drive bays
  • Mandatory CPU0 2 PCIe slot riser (x16, x8), optional CPU1 2 PCIe slot riser (x16, x16)8
  • Redundant Power Supply
  • Optical Drive
On System Management Chipset
HP iLO (Firmware: HP iLO 4)
Memory protection
  • Advanced ECC9
  • Online Spare10
  • Lock-step mode11
Memory12
Type
HP SmartMemory
Registered (RDIMM)
DIMM slots
24 (12 DIMM slots per processor /4 channels per processor/3 DIMMs per channel)
Maximum capacity (RDIMM)
384GB (24x 16GB RDIMM @1866MHz)
Network controller (one of the following)
  • HP VWS Ethernet 10Gb 2-port 560FLR-SFP+ FIO Adapter
  • HP Ethernet 1Gb 4-port 366FLR FIO Adapter
Primary Riser (Must order option 766993-B21)
Expansion Slots #
Technology
Bus Width2
Connector Width
Bus Number1
Form Factor
Notes
1
PCIe 3.0
X16
X16
5
Full Length, Full Height Slot
Proc 1
2
PCIe 3.0
X8
X8
4
Proc 1
Secondary Riser (optional 2-slot, requires 766994-B21)
Expansion Slots #
Technology
Bus Width2
Connector Width
Bus Number1
Form Factor
Notes
4
PCIe 3.0
X16
X16
24
Proc 2
5
PCIe 3.0
X16
X16
25
Proc 2
1. Default bus assignment (in decimal). Inserting cards with PCI bridges may alter the actual bus assignment number.
2. Indicates the number of physical electrical lanes running to the connector.
When populating the second optional riser slot, the second processor must be installed
HP DL380z ROM
The HP DL380z Gen8 ROM identifies itself as an HP Proliant DL380p Gen8 platform. This is to be expected and is correct behavior.
Storage controller
HP Smart Array P420i (RAID 0/1/1+0/5/5+0/6/6+0)13
Internal storage devices
Diskette drive
None
Optical drive
Optional: DVD-ROM, DVD-RW
Hard drives
None ship standard
Drive bays
Standard: 8SFF drive bays total with Optical Bay
Unfilled bays come populated with hard drive blanks installed. Should the customer need additional hard drive blanks, they can order more using P/N 666987-B21: HP SFF Gen8 Hard Drive Blank Kit.
Maximum internal storage
Hot Plug SFF SAS
7.2TB (8 x 900GB)
Hot Plug SFF SATA
8.0TB (8 x 1TB)
Hot Plug SFF SAS SSD
6.4TB (8 x 800GB)
Interfaces
Serial
1
Video
2 (1 front, 1 back) not active simultaneously
FlexibleLOM network ports
Can be configured with 4 x 1Gb ports or with 2 x 10Gb ports (See HP Networking section below for more details and options).
HP iLO Remote Management Network Port
1 Gb Dedicated
SD slot1
1 Internal Secure
USB 2.0 Ports
7 total: 2 front, 4 back, 1 internal
1. The SD slot is not a hot-pluggable device. Customers should not attempt to plug an SD card into the SD slot while the server is powered.
Industry standard compliance
  • ACPI 2.0b Compliant
  • PCIe 3.0 Compliant
  • PXE Support
  • WOL Support
  • USB 2.0 Compliant
System fans (one of the following)
  • 2P Models have (6) (N+1 redundancy standard)
  • 1P Models have (4) (N+1 redundancy standard)
Graphics
Integrated Matrox G200 video standard
  • 1280 x 1024 (32 bpp)
  • 1920 x 1200 (16 bpp)
HP iLO 4 On System Management Memory
  • 16 MB Flash
  • 256 MB DDR 3 with ECC (112 MB after ECC and video)
Virtual Workstation Graphics options14
  • NVIDIA Quadro K4000 3GB graphics (up to 3) only for pass through GPU virtualization solutions
  • NVIDIA Quadro K5000 4GB graphics (up to 2) only for pass through GPU virtualization solutions
  • NVIDIA Quadro K6000 12GB graphics (up to 2) only for pass through GPU virtualization solutions
  • NVIDIA GRID K2 8GB graphics (up to 2) for pass through and virtual GPU virtualization solutions
Form factor (H x W x L)
2U Rack form factor
8 SFF: 8.74 x 44.55 x 69.85 cm (3.44 x 17.54 x 27.5 in)
Security
  • Power-on password
  • Serial interface control
  • Administrator's password
  1. All support up to1600MHz DDR3 memory speeds.
  2. All support up to 1866MHz DDR3 memory speeds.
  3. For Twelve-core processors.
  4. For Ten-core processors.
  5. For Eight-core processors.
  6. For Six-core processors.
  7. All processor models above list the L3 Cache associated with that particular processor.
  8. To take advantage of the CPU1 riser, the second processor must be installed.
  9. Advanced ECC uses single device data correction (SDDC) to detect and correct single and all multi-bit error that occurs within a single DRAM chip. Both x4 and x8 SDDC are supported (x8 requires lockstep mode).
  10. Memory online spare mode (also known as rank spare mode) detects a rank that is degrading and switches operation to the spare rank.
  11. Memory Lockstep mode is used to correct a single x8 DRAM device failure on a DIMM. The DIMMs in each paired memory channel must have identical HP part numbers.
  12. The DL380z Gen8 Virtual Workstation supports only RDIMM. If only one processor is installed, only half the DIMM slots are available. Depending on the memory configuration and processor model, the memory speed may run at 1866 MHz, 1600 MHz, 1333 MHz, or 1066 MHz.
  13. P420i controller comes with no cache memory options. For cache module options for this controller, use P/N 631679-B21 or 631681-B21.
  14. All Virtual Workstation Graphics options will require one or two graphics PCIe Riser cages to be configured.
Electrical specifications
Input requirements (per power supply)
  • Rated line voltage
    100 to 120 V ac
    200 to 240 V ac
  • Rated input current
    For 1200 W power supply:
    10 A (at 100 V ac)
    4.9 A (at 200 V ac)
  • Rated input frequency
    50 to 60 Hz
  • Rated input power
    930 W (at 100 V ac)
    1348 W (at 200 V ac)
BTU rating
Maximum (For 1200 W power supply)
3530 BTU/hr (at 100 V ac)
4600 BTU/hr (at 200 V ac)
Power supply output (per power supply)
Rated steady-state power / Maximum peak power (For 1200 W power supply)
800 W (at 100 V ac)
900 W (at 120 V ac)
1200 W (at 200 to 240 V ac)
HP Smart Array P420i controller specifications
Dimensions
Embedded
Disk Drive and Enclosure Interface - Transfer Rate
6Gb/s SAS (Serial Attached SCSI)
6Gb/s SATA (Serial ATA)
SAS connectors
2 internal 4X connectors
Cache memory speed
1GB or 2GB FBWC DDR3-1333MHz with 72-bit wide bus
System interface
x8 PCIe 3.0 provides 8GB/s maximum bandwidth
SAS speed
(8) 6Gb/s SAS links provide 4.8GB/s maximum bandwidth
Cache memory
Zero Memory RAID has no cache memory
72-bit 1GB ECC protected flash back write cache (FBWC) or 72-bit 2GB FBWC
Logical drives supported
Zero Memory, Up to 2 logical volumes (8SFF physical drives)
Up to 64 logical drives with cache
Host memory addressing
64-bit, supporting greater than 4GB system memory space
RAID support
  • RAID 6, 60 (Advanced Data Guarding)
  • RAID 5, 50 (Distributed Data Guarding)1
  • RAID 10 (Striping & Mirroring)
  • RAID 0 (Striping), RAID 1 (Mirroring)
1. A minimum of 512 MB cache is required to enable RAID 5, 50, 6, 60.
HP Smart Array Advanced Pack (SAAP 2.0) is no longer required to enable RAID 6 & 60 (Advanced Data Guarding). However, controller must be in firmware version 4.68 (or later).
HP Ethernet 1Gb 4-port 366FLR adapter specifications
HP flexible network technology
HP flexible network technology consists of replaceable network solutions to meet customer requirements now and in the future.
10Base-T/100Base-TX/1000Base-TX
Compatibility
  • IEEE 802.3
  • IEEE 802.3ab
  • IEEE 802.3u
  • IEEE 802.3x
  • IEEE 802.3ad
  • IEEE 802.1q
  • IEEE 802.3az
  • IEEE 802.1as
  • IEEE 1588
Data transfer method
PCI Express, four lanes (x4)
Intel Ethernet Controller I350
Network transfer rate
  • 10Base-T (Half-Duplex) - 10 Mb/s
  • 10Base-T (Full-Duplex) - 20 Mb/s
  • 100Base-TX (Half-Duplex) - 100 Mb/s
  • 100Base-TX (Full-Duplex) - 200 Mb/s
  • 1000Base-TX (Full-Duplex) - 2000 Mb/s
Connector
Four RJ-45
Cable support
  • 10Base-T
    Category 5e (CAT-5e) or better twisted-pair cabling; up to 328 ft (100 m)
  • 100Base-TX
  • Category 5e (CAT-5e) or better twisted-pair cabling; up to 328 ft (100 m)
  • 1000BaseTX
HP Ethernet 10Gb 2-port 560FLR-SFP+ adapter specifications
SFP+ for Direct Attach Cable copper or fiber
Compatibility
  • IEEE 802.3
  • IEEE 802.1ab
  • IEEE 802.3x
  • IEEE 802.3ad
  • IEEE 802.1p/802.1q
  • IEEE 802.3ae
  • IEEE 802.1Qau
PCI Express 2.0, eight lanes (x8)
Intel 82599 Controller (generation 10)
  • Full duplex - 20 Gb/s per port
  • Total aggregate - 40 Gb/s Full Duplex theoretical bandwidth
Connector
Two SFP+ cages allowing use of Direct Attach copper and SR fiber optic modules
Physical specifications
Dimensions (H x W x D)
SFF Drives: 8.73 x 44.55 x 69.85 cm (3.44 x 17.54 x 27.50 in)
Weight (approximate)
  • Maximum
    27.66 kg (61.00 lb)
  • Minimum (one SFF hard drive, power supply, and processor installed, ODD not installed)
    18.59 kg (41.0 lb)
Software/OS
Feature
Operating systems and virtualization software support1
  • VMware
  • Citrix XenServer
HP iLO Management Engine
HP Insight management
  • HP Service Pack for Proliant (SPP)
  • HP Insight Control
  • HP iLO Advanced
1. Choice of hypervisor solution will depend on chosen GPU virtualization strategies.
Environmental specifications
System inlet temperature
  • Operating
    10° to 35°C (50° to 95°F) at sea level with an altitude derating of 1.0°C per every 304.8 m (1.8°F per every 1000 ft) above sea level to a maximum of 3048 m (10,000 ft), no direct sustained sunlight. Maximum rate of change is 10°C/hr (18°F/hr). The upper limit may be limited by the type and number of options installed.
    System performance may be reduced if operating with a fan fault or above 30°C (86°F).
  • Non-operating
    -30° to 60°C (-22° to 140°F). Maximum rate of change is 20°C/hr (36°F/hr).
Relative humidity (non-condensing)
  • Operating
    10% to 90% relative humidity (Rh), 28°C (82.4°F) maximum wet bulb temperature, non-condensing.
  • Non-operating
    5% to 95% relative humidity (Rh), 38.7°C (101.7°F) maximum wet bulb temperature, non-condensing.
Altitude
  • Operating
    3048 m (10,000 ft). This value may be limited by the type and number of options installed. Maximum allowable altitude change rate is 457 m/min (1500 ft/min).
  • Non-operating
    9144 m (30,000 ft). Maximum allowable altitude change rate is 457 m/min (1500 ft/min).
Acoustic noise
Listed are the declared A-Weighted sound power levels (LWAd) and declared average bystander position A-Weighted sound pressure levels (LpAm) when the product is operating in a 23°C ambient environment. Noise emissions were measured in accordance with ISO 7779 (ECMA 74) and declared in accordance with ISO 9296 (ECMA 109). The listed sound levels apply to standard shipping configurations. Additional options may result in increased sound levels.
Performance
Idle
Operating
LWAd
4.1 B
5.0 B
LpAm
25 dBA
35 dBA
Emissions classification (EMC)
Certifications
FCC rating
Class A
Normative standards
CISPR 22; EN55022; EN55024; FCC CFR 47, Pt 15; ICES-003; CNS13438; GB9254; K22;K24; EN 61000-3-2; EN 61000-3-3; EN 60950-1; IEC 60950-1
Product conformance to cited product specifications is based on sample (type) testing, evaluation, or assessment. This product or family of products is eligible to bear the appropriate compliance logos and statements.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
