Document ID: c04347462
Version: 1
HP Elitebook 745, 755, and 725 G2 Notebook PCs - During Fresh Install of OS, Driver Missing Error Is Displayed
Release date : 20-Jun-2014
Last updated : 23-Jan-2015
DESCRIPTION
When trying to restore or freshly install the Operating System (OS) from the HP restore media (OSDVD) or media created from HP Recovery Disk Creator (HPRDC), the following error message is displayed:
"A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD or USB flash drive, please insert it now."
This occurs when using an external optical drive which is connected to USB 3.0 port.
SCOPE
Computers:
  • HP EliteBook 745 G2 Notebook PC
  • JHP EliteBook 725 G2 Notebook PC
Operating Systems:
  • Microsoft Windows 7 Home Basic (32-bit)
  • Microsoft Windows 7 Home Premium (32-bit)
  • Microsoft Windows 7 Home Premium (64-bit)
  • Microsoft Windows 7 Professional (32-bit)
  • Microsoft Windows 7 Professional (64-bit)
  • Microsoft Windows 8.1 (standard)
  • Microsoft Windows 8.1 Pro
RESOLUTION
Solution 1:
a. if possible user disable USB 3.0 in BIOS (F10) and save setting. Perform the installation again.
Solution 2:
a. If possible user should use internal optical drive.
Solution 3:
a. If possible user should connect external optical drive to the USB 2.0 port to perform the installation or restore.
Solution 4:
1. Download the latest USB 3.0 drivers from HP download site on a USB stick for the operating system.
2. Insert the USB stick in one of the USB 2.0 ports.
3. Reboot the system from the external drive.
3. Use Browse button when the message pops up during installation and point to the drivers location on the USB stick.
4. Click Next and go through the installation.
Hardware platforms affected : HP EliteBook 725 G2 Notebook PC, HP EliteBook 745 G2 Notebook PC, HP EliteBook 755 G2 Notebook PC
Operating systems affected : Microsoft Windows 7 Home Basic (32-bit) (deleted) Microsoft Windows 7 Home Premium (32-bit) (deleted) Microsoft Windows 7 Home Premium (64-bit) (deleted) Microsoft Windows 7 Professional (32-bit) (deleted) Microsoft Windows 7 Professional (64-bit) (deleted)
Support Communication Cross Reference ID : IA04347462
