    Looking for Site Help?
Removing and Replacing the Optical Drive for HP Envy 17-k000 Notebook PCs
This document applies to HP Envy 17-k000 notebook computers.
Before you begin
  • You need a Phillips head screwdriver and a non-metallic prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures for the CD/ DVD drive, or optical drive, apply to all configurations for all HP Envy 17-k000 notebook computers.
Removing the optical drive
Follow the steps in this section to remove the optical drive, which is also called the DVD drive.
  warning:
Step 1
First, remove the battery.
For instructions to remove the battery, see the HP support document, Removing and Replacing the Battery for HP Envy 17-k000 Notebook PCs.
Lifting and removing the battery
Step 2
Remove the screw that secures the optical drive to the base enclosure.
Removing the screw that secures the optical drive
Step 3
Grasp the optical drive bezel and carefully slide the optical drive out of the base enclosure.
Replacing the optical drive
Use the steps in this section to replace the optical drive.
Step 1
Insert the optical drive into the optical drive bay until the optical drive bezel is flush with the side of the base enclosure.
Step 2
Replace the screw that secures the optical drive to the base enclosure.
Replacing the screw that secures the optical drive
Step 3
Replace the battery.
For instructions to replace the battery, see the HP support document, Removing and Replacing the Battery for HP Envy 17-k000 Notebook PCs.
Replacing the battery into its bay
Country: Flag Bulgaria
