HP Officejet Printers - Replacement Printer Instructions
This document is for HP Officejet 6812, 6815, 6820, Officejet Pro 6830, and 6835 e-All-in-One printers.
When HP replaces your defective product, some accessories or parts need to be transferred from the defective product to the replacement product.
  • Some optional accessories might not be included with your product model.
  • Keep any optional accessories that you bought separately.
See the following list for the HP Officejet Pro 6830 e-All-in-One printers that are included in this document:
Figure : Example of the Officejet Pro 6830 e-All-in-One printers
Image: Example of the HP Officejet 6810 and Officejet Pro 6830 e-All-in-One printers
Printer model
Printer Number
E3E02A
HP Officejet Pro 6835 e-All-in-One printer
J2D37A
HP Officejet 6812 e-All-in-One Printer
G1W52A
HP Officejet 6815 e-All-in-One Printer
F0M65A
HP Officejet 6820 e-All-in-One Printer
B6T06A
Instructions
Before you replace or dispose of your defective printer, follow these instructions to make sure that you remove the correct accessories before you send it back to HP.
If you have an HP Instant Ink subscription and were using Instant Ink cartridges in your old printer, they will not work in your new printer. New Instant Ink cartridges are required for the new printer and will be shipped separately.
  1. Press the Power button to turn on the printer, if it not already on.
  2. Remove the cartridges.
    Figure : Example of cartridges
    Image: Example of  cartridges
  3. Recycle or discard the cartridges.
  4. Press the Power button to turn off the printer.
  5. Disconnect the power cord from the rear of the printer, and then unplug the power cord from the wall outlet, surge protector, extension cable, or power strip.
  6. Keep the following accessories to use with the replacement printer:
    • Power supply adapter
      Image: Power supply adapter
    • Power cord
      Image: Power cord
    • Ethernet cable
      Image: Ethernet cable
    • Universal Serial Bus (USB) cable
      Image: Universal Serial Bus (USB) cable
    • Printer manuals
      Image: Example of a printer manual
    • CDs
      Image: Example of a printer software CD
  7. Connect the power cord to the rear of the replacement printer, and then plug it into a wall outlet.
  8. Press the Power button to turn on the replacement printer, and then test all printer functions.
  9. For additional support information, go to www.hp.com/support.
Country: Flag Bulgaria
