    Fix HP Printer issue on macOS
HP LaserJet Pro 500 Color MFP M570 - Replace the duplex-reverse guide
To see a short video demonstrating this procedure, click here.
Before you begin
  • Use the table below to identify the correct kit part number for your product, and then go to www.hp.com/buy/parts to order the kit.
    Kit part number
    CC468-67913
    Duplex-reverse guider kit with instruction guide
Required tools
  • No special tools are required to install this kit.
Step 1 - Remove the Duplex-Reverse Guide
  1. Grasp the duplex-reverse guide and pull it away from the product to release it.
Step 2 - Unpack the Replacement Duplex-Reverse Guide
Unpack the replacement duplex reverse guide from the packaging.
If your part requires return or recycling, go to Product return and recycling
HP recommends responsible disposal of the duplex reverse guide.
Step 3 - Install the Replacement Duplex-Reverse Guide
Install the replacement duplex reverse guide.
  • Hold the guide so, when installed, the front point of the guide is angled upward.
  • Align the replacement guide with the slits in the product, and then push the guide to lock the tabs in the slits.
