HP 240 G3 Notebook PC
- ${title}
- ${title}
- ${title}
- ${title}
HP 240 G3 Notebook PC Product Specification
Product description
Product features
Feature
Processor1
Intel chipset integrated with processor
Graphics
Storage and drives (Primary storage bay
hard drives)
Optical drives
Fixed Optical Drive:
Memory
Networking/communications
Audio/multimedia
Keyboards/pointing devices/buttons & function keys
Security
Security Lock slot (lock must be purchased separately)
Power
note: |
System specifications
Stand-Alone power
requirements (ac Power)
Temperature
Relative humidity
Shock
Random vibration
Altitude (unpressurized)
Planned industry
standard
certifications
Displays specifications
14.0-inch LED HD
(1366 x 768)
Anti-glare
Active area (w x h)
30.9 x17.4 cm (12.16 x 6.85 in)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
101 ppi
Viewing angle
Power specifications
HP 45 W smart ac adapter
Dimensions
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
Output
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
EMI and Safety Certifications
4-Cell (41 WHr)
Lithium-Ion battery
Cells/Type
4-cell Lithium-Ion
Energy temperature
Battery
re-charge time
HP 3-cell (31 WHr)
Lithium-Ion primary
battery
Dimensions
(H x W x L)
2 x 3 x 20.5 cm (0.8 x 1.2 x 8.1 in)
0.166 kg (0.37 lb)
Cells/type
3-cell Lithium-Ion
Energy
Temperature
Battery
re-charge time
Fuel gauge LED
No
Storage specifications
1TB 5400 rpm
SATA hard drive
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate synchronous (maximum)
300MB/s (Drive capability)
Seek time
(typical reads, including
settling)
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Operating temperature (case temp)
0°C to 60°C (32°F to 140°F)
Features
ATA security
750GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Seek time
settling)
Rotational speed
5400 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
150MB/s (Drive capability)
Seek time
settling)
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
320GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Seek time
settling)
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA security
Optical drives specifications
DVD+/-RW SuperMulti DL
drive
Access times (Random)
Max data transfer rate
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported media (read)
Supported media (write)
Max media capacity (read)
8.5GB
Max media capacity
(write)
8.5GB
Transport
Tray loading
Networking specifications
Integrated Realtek
10/100 NIC
Ethernet features
Power management
Performance features
Manageability
Interface
NIC device driver name
Realtek PCIe FE Ethernet family controller
Communications specifications
Qualcomm 802.11b/g/n
WiFi adapter
Wireless LAN standards
Interoperability
Frequency band
2.402 - 2.482 GHz
Data rates
Frequency support
20 MHz: 2.4 GHz bands
Modulation
Security
Sub-channels
Multinational support with frequency bands and channels compliant to local
regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture
models
Roaming
IEEE 802.11 compliant roaming between access points
Output power
13.5 dBm, minimum
Power consumption
Power management
Receiver sensitivity
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the
display enclosure
Form factor
PCI-Express Half-MiniCard
4 g (0.008 lb)
Dimensions
3.3 x 26.65 x 29.85 mm (0.13 x 1.05 x 1.17 in)
Operating voltage
3.3 v +/- 9%
Temperature
Humidity (non-condensing)
Altitude
LED activity
Qualcomm 802.11b/g/n Bluetooth 4.0 combo card
Interoperability
Frequency band
2.402 – 2.482 GHz
Data rates
Modulation
Security
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
Roaming
Output power (for CCK)
13.5dBm , minimum
Power consumption
Power management
Antenna type
High efficiency dual antenna with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express Half-MiniCard v1.2
6 g (0.013 lb)
Dimensions
Operating voltage
3.3 v +/- 9%
Temperature
Altitude
LED activity
Bluetooth specification (V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0)
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBm at 0.1 % raw bit error rate
Power consumption
Antenna
Internally integrated within module
Range
Up to 33 ft (10 m)
Electrical interface
Bluetooth software
Broadcom Bluetooth for Windows
Supported
Microsoft Windows Bluetooth software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth security provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
Bluetooth profiles supported
Ralink 802.11b/g/n Bluetooth 4.0 combo card
Interoperability
Frequency band
2.402 – 2.482 GHz
Data rates
Modulation
Security
Sub-channels
Roaming
Output
13.5 dBm, minimum
Power consumption
Power management
Antenna type
Form factor
6 g (0.013 lb)
Dimensions
Operating voltage
3.3 v +/- 10%
Temperature
Altitude
LED activity
Transmit power
Power consumption
Antenna
Range
Up to 33 ft (10 m)
Bluetooth software
Supported
Link topology
Security
Power management
Certifications
Realtek 802.11 b/g/n (1x1)
Interoperability
Wi-Fi certified
Frequency band
2.402 – 2.482 GHz
Data rates
Modulation
Security
Roaming
Output
13.5 dBm, nominal
Power consumption
Power management
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Form factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating voltage
3.3 v +/- 9%
Temperature
Altitude
LED activity
Audio/multimedia
Audio
Audio output quality
Integrated stereo speakers
Multimedia
Integrated HD webcam (Multimedia)
Physical specifications
Dimensions (W x D x H)
Weight (weight will vary by configuration)
Starting at 1910 g (<4.21 lb)
Software overview
Feature
preinstalled
Preinstalled software with Windows Operating System
note: |
List of available documents for the HP 240 G3 Notebook PC
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
