HP EliteDisplay E231i 23-in IPS LED Backlit Monitor Product Specification
Product description
Product features
Feature
58.42cm (23 in.) widescreen; diagonally measured
Display type
IPS Gen 2, LED Backlit
Color support
16.7 million colors
Aspect ratio
16:9
Contrast ratio (typical)
1,000:1
Dynamic contrast ratio (typical)
4,000,000:1
Response rate (typical)
8 ms (Grey to Grey)
Pixel pitch
0.265 mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Security Lock-Ready
Yes
User controls
  • Buttons or switches
    • Menu
    • Minus ("-")
    • Plus ("+") /Input
    • OK/Auto
    • Power
  • On Screen Display (OSD)
    • Brightness
    • Contrast
    • Color
    • Image control
    • OSD control
    • Management
    • Language
    • Factory reset
    • Input control
Languages
  • English
  • Spanish
  • German
  • French
  • Italian
  • Netherlands
  • Portuguese
  • Japanese
  • T-Chinese
  • S-Chinese
Video/Other Inputs
  • Plug and Play: Yes
  • Self Powered USB 2.0 Hub: One upstream, two downstream ports (cable included)
  • Input connectors
    • 1 VGA
    • 1 DisplayPort 1.2 (1.1 compatible)
    • 1 DVI-D
  • Sync input: Separate synch
  • Video cables included
    • 1 VGA
    • 1 DVI-D
    • 1 DisplayPort
Signal Interface/ Performance
  • Horizontal frequency: 24-94 kHz
  • Vertical frequency: 50.76 Hz
  • Native resolution: 1920 x 1080 @ 60 Hz
  • Preset VESA Graphic Modes (non-interlaced):
    • 640 x 480 @ 60Hz
    • 720 x 400 @ 70 Hz
    • 800 x 600 @ 60 Hz
    • 1024 x 768 @ 60 Hz
    • 1280 x 720 @ 60 Hz
    • 1280 x 1024 @ 60 Hz
    • 1440 x 900 @ 60 Hz
    • 1600 x 900 @ 60 Hz
    • 1680 x 1050 @ 60 Hz
    • 1920 x 1080 @ 60 Hz
  • Maximum pixel clock speed: 170 MHz
  • User programmable modes: Yes, 10
  • Anti-Glare: Yes
  • Default color temperature: 6500 K
Ergonomic features
  • 4-Way comfort adjust
  • Cable management
  • Detachable stand: No
  • Tilt range: -5° to + 30° vertical
  • Swivel range: 360°
  • Height adjustable: Yes, 150 mm
  • Pivot rotation: Yes
Certification and compliance
  • CB
  • CE
  • TUV
  • GS
  • GOST
  • CUL
  • CEL Grade 1
  • FCC
  • E-Star
  • CSA
  • NOM
  • S-Mark
  • VCCI
  • MIC
  • PSB
  • ISC
  • CCC
  • BSMI
  • CTick
  • ICES
  • Microsoft WHQL Certification (Windows 8 and Windows 7)
  • ENERGY STAR Qualified
  • EPEAT Gold8
  • TCO 6.0 Edge Certified
Monitor E231i 23 inch LED spare part number
756033-001
Panel specifications
Panel active area (W x H)
50.91 x 28.64 cm (20.04 x 11.27 in)
58.42cm (23 in) widescreen; diagonally measured
Type
Resolution
1920 x 1080 @ 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250nits (cd/m2)
1,000:1
4,000,000:1
8 ms gray to gray
Pixel pitch
0.265 mm
Gen 2 technology, also called AH-IPS, enables lower power consumption.
Power specifications
Power supply
Internal
Input power
100- 240 V ac at 50 to 60 Hz
ENERGY STAR power1
22 W
Default power2
28 W
Maximum power3
36 W
Sleep power
0.5 W
Power cable length
1.9 m (6.2 ft)
1: ENERGY STAR power is measured with factory defaults, brightness at ENERGY STAR level of 200 cd/m2 and with no USB loads.
2: Default Power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
3: Maximum Power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Physical specifications
Dimensions (W x D x H)
  • Unpacked w/stand (highest setting): 54.4 x 24.29 x 46.99 cm (21.4 x 9.5 x 18.5 in)
  • Unpacked w/o stand (head only): 54.4 x 5.1 x 32.9 cm (21.4 x 2.0 x 12.9 in)
  • Packaged: 62.0 x 18.3 x 51.8 cm (24.4 x 7.2 x 20.4 in)
  • Head only: 4.19 Kg (9.23 lb)
  • Unpacked: 6.4 Kg (14.1 lb)
  • Packaged: 8.4 Kg (18.52 lb)
Environmental specifications
Temperature
  • Operating: 5°C to 35°C (41°F to 95°F)
  • Nonoperating: -20°C to 60°C (-4°F to 140°F)
Humidity
  • Operating: 20% to 80% non-condensing
  • Nonoperating: 5% to 95%, 38.7° C max wet-bulb
Altitude
  • Operating: 0 to 5.000 m (16,404 ft)
  • Nonoperating: 0 to 12,192 m (0 to 40.000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-Free display glass
Yes
Low Halogen
Yes
Mercury-Free Display Backlighting
Yes
External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
