HP PCs - Using HP Connected Drive to Store and Share Files (iOS)
HP Connected Drive makes it easy to store, find, and share your files, wherever they are. This document describes how to set up and use HP Connected Drive on an iOS device.
HP Connected Drive will be discontinued on October 26, 2015. Our recommendation is to use Microsoft OneDrive as a central file service across all your devices. HP strongly encourages you to download any files in your Collection that you want to keep before the Connected Drive service is discontinued.
Installing HP Connected Drive
You can install HP Connected Drive by downloading it from the App store and loading it directly on your iOS device, or by downloading it from iTunes to your computer, and then transferring it from your computer to your iOS device.
Use the following steps to install HP Connected Drive:
  • Installing from the App Store
    Use the following steps to download and install HP Connected Drive directly to your iOS device.
    1. On your device, tap the App Store icon.
      Figure : Selecting the App store icon
    2. Tap the Search icon at the top of the page, and type HP Connected Drive.
    3. Tap the Free button.
      Figure : Selecting the Connected Drive app
    4. Tap the Install button.
      Figure : Installing from the App Store
    5. Sign in to the App store if necessary, and then tap OK to download the app.
      Figure : Signing in to App store
    6. Wait while the app installs, and then tap the Open button.
      Figure : Opening HP Connected Drive
  • Installing from iTunes
    Use the following steps to download and install HP Connected Drive using iTunes.
    1. On your computer, open the iTunes store, and then type HP Connected Drive in the Search box at the top of the page.
      Figure : Searching for Connected Drive
    2. In the HP Connected Drive page, choose your device, either iPhone or iPad, and then tap the Download button.
      Figure : Downloading the app
      Downloading the app
    3. In your iTunes Library, select Apps.
      Figure : Selecting Apps in iTunes Library
    4. Connect the iOS device to the computer. To install HP Connected Drive, tap the Install button, and then tap Sync.
      Figure : Installing HP Connected Drive
Setting up HP Connected Drive
Follow these steps to set up HP Connected Drive and create an HP Connected account:
  1. On the iOS home screen, tap the HP Drive icon.
    Figure : Connected Drive icon
     HP Drive icon
  2. On the Find your files fast screen, tap Create a FREE account.
    If you already have an HP Connected Account, tap Sign In.
    Figure : Creating a free account
  3. Fill in the required fields to create an account, and read and agree to the Terms of Use. Then tap the Create Account button.
    Figure : Completing the account form
    If you already have an HP Connected Drive account, tap Sign in. Then type your email address and password, and tap the Sign In button.
    Figure : Signing in
    Signing in
  4. On the You’re almost there page, add a custom name for your device or keep the default name.
    Figure : Naming the device
    Naming the device
  5. In the HP Drive Would Like to Send You Notifications message box, tap Don't Allow or OK.
  6. Tap OK in the HP Drive Would Like to Access Your Photos message box to allow HP Connected Drive to access your photos.
    HP Connected Drive opens to the Everything category.
    Figure : Allowing access to photos
    This step is necessary in order for local photos to appear with HP Connected Drive. You can change this in your device settings. To change this, open the Settings app , and then tap Privacy. In the Photos area, tap the arrow.
    Figure : Changing the Privacy setting for Photos
    Move the selection slider next to HP Drive to the left.
    Figure : Disabling access to Photos
    Disabling access to photos
Linking a Service (Box, Dropbox, or Facebook)
You can link HP Connected Drive to your existing account with the following cloud service providers, or go to each service and create a new account:
  • Box
  • Dropbox
  • Facebook
When you link your HP Connected Drive and your cloud service accounts, all of your devices using the connected Drive app are able to see your files on that service. You only need to link to your account one time in order to see the content across all of your devices.
You can link your HP Connected Drive account to only one account on each service. For example, you can link to only one Box account at a time.
If you have closed the instructions and Connect your cloud providers is missing, tap the Sources button on the bottom app bar, and tap the blue Connect button next to the service you want to add.
The following instructions are for linking a Box account; however, the steps are essentially the same for each service.
  1. To add your existing Box account, tap Connect to the right of the Box logo.
    Figure : Adding your existing Box account
  2. Enter your Box account email and password information, and then tap the Authorize button.
    Figure : Authorizing access to Box
  3. On the Box information page, tap the Grant access to Box button. This enables HP Connected Drive to index your Box files so you can access them through the app.
    Figure : Granting access to your Box account
  4. Wait while Box verifies your account and links it to your HP Connected Drive account. Then tap Continue.
    Figure : Verifying that your Box account is linked
    HP Connected Drive displays a message that it is adding the files in your Box account. If you have more than 200 files in your Box account, it might take extra time to show all the files the first time you link to Box.
Signing in to your HP Connected account
After the account is set up and you sign in to your account, you remain signed in. However, if you sign out, follow these steps to sign in to your HP Connected account when you open HP Connected Drive.
You must be signed in to an HP Connected Account to view your files.
Use the following steps to sign in to HP Connected Drive:
  1. On the home screen, tap the HP Drive icon.
    Figure : HP Drive icon
     HP Drive icon
  2. On the Sign In page, type your information and tap Sign In.
    Figure : Signing in
    Signing in
Navigating in HP Connected Drive
The main menu displays at the bottom of each page. Use this menu to move between home, your collection, sources, current activity, and settings.
    Figure : Connected Drive main menu
  1. Home - shows all your content on all your devices and services sorted by category.
  2. My Collection - shows all of the content you have collected (uploaded) to your cloud drive.
  3. Sources - shows your connected devices and services.
  4. Current Activity - shows the progress of files being downloaded and collected (uploaded).
  5. Settings - Shows account, system, and content settings.
Home / Everything: View all your content sorted into the following categories: all content, photos, music, videos, and documents. Everything allows you to view and search all your content across all devices and services.
To view all your content, touch the Everything button on the bottom app bar.
Figure : Opening Home / Everything
Figure : Everything menu
Everything menu
My Collection: View all your HP Connected Drive cloud content. To view the content in your collection, tap the Collection button on the bottom app bar.
Figure : Opening My Collection
My Collection opens showing the files that you have collected to your HP Connected Drive cloud storage.
Figure : My Collection screen
My Collection menu item
Sources: View all the sources associated with your HP Connected Drive account, including your connected services, such as Box and Facebook.
To view your content in each source associated with your HP Connected account, touch the Source button on the bottom app bar.
Figure : Opening the Sources
Opening the Sources
The Sources menu opens showing your connected devices and services. The order of the devices and services display on the screen as follows:
  • The current device displays first in the list.
  • Below that, the devices display in alphabetical order.
  • Below that, the services display in alphabetical order.
Figure : Sources menu
Sources menu
Current Activity - View the progress of file collections and downloads from your connected devices and services.
Tap the Current activity button on the bottom app bar.
Figure : Opening Current Activity
Current Activity opens showing the progress of files that are being uploaded or downloaded.
Figure : Current Activity screen
Settings: Use the Settings options to manage your account, manage services and devices, select the auto refresh option, clear your search history, and view information about the app.
Tap the Settings button on the bottom app bar.
Figure : Opening Settings
Opening Settings
The Settings menu opens with options to change account, system, and content settings; provides information about the app version and terms of use, and provides access to support.
Figure : Settings menu
Settings menu
Viewing files with HP Connected Drive
After you sign in to your account, Connected Drive opens to the Everything / Home page. This page shows everything in all your connected devices and services and categorizes your files into Photos, Music, Videos, and Documents. You can view and sort each category individually. Connected Drive then combines all your files in the All Content category.
The number of items in each category displays. You can also search for an item in your content by using the Search all content function at the top of the page.
Figure : Everything page
Everything page
The All Content category includes the following:
  • Collected (cloud) files.
  • Local content (content on the device you are currently using).
  • Indexed files (content on your other connected devices and cloud services). These indexed files can be remotely collected or downloaded when you are signed into HP Connected Drive on those connected devices. Indexed files have a source badge, showing where the file is located.
    Figure : Source badges on file thumbnails in grid view
    Device badges on file thumbnails
    The following list shows some of the source badges.
    Desktop computer
    Notebook computer
    Tablet
    Phone
    Box service
    Dropbox service
    Facebook service
HP Connected Drive automatically categorizes your files into categories of Photos, Music, Videos, and Documents, which you can view and sort individually. It then combines all your files in the All Content category.
The categories are listed on the Everything page along with the number of items in each category. You can search for an item in your content by using the Search all content function at the top of the page.
Everything page
Sorting a category
In each category, you can change the sort options to help you find and keep your files organized. The following example shows how to use the sort options for the All Content category; however, these options are the same for each category.
  1. On the Everything page, tap All Content.
    The All Content category opens.
    Figure : All Content page
    All Content page
  2. Tap the More options menu icon in the upper right, and then tap Sort.
    Figure : Tapping Sort
    Tapping Sort
  3. Scroll through the options to choose and tap how you want to sort, and then tap Done.
    Figure : Sorting the All Content category
    Although these steps describe sorting the All Content category, you can sort files in each category or device in the following ways.
    • Date created
    • Date modified
    • A-Z
    • Z-A
    • Source
    • File size
    • File type
Changing between Grid and List view
You can view your contents in either grid view or list view.
To change the view, tap the More options menu icon and then tap View as list or Grid view.
Figure : Changing grid view to list view
  • Grid View (Default): Shows a file thumbnail image or an icon, if the image is not displayed, and the filename.
    Figure : Grid view
    Grid view
  • List View: Shows a small file thumbnail or an icon, if the image is not displayed, and image information, depending on the type of file you are viewing, such as filename, date created, file size, file type, or source.
    Figure : List View
    List View
Changing how you view your files
Change the view between grid and list by tapping the More options menu icon and then tapping View as grid or View as list.
Figure : All Content category in grid view
Refreshing your files
To resynchronize all your files with the cloud, use Refresh. You might do this if you want to verify that a file was uploaded from another device with your account.
Use one of the following methods:
  • Refresh your files by tapping the More options menu icon and then tap Refresh.
    Figure : Refreshing your files
  • Or, you can refresh your files by pulling down from the top of the screen.
Searching for a file with HP Connected Drive
Follow these steps to search for a file in your HP Connected Drive content.
  1. Tap the Search all content icon under Everything.
    Search results span the entire application and include results across all your devices associated with the account.
    Figure : Search all content
    Search all content
  2. Type in the search terms and tap a search suggestion from the list in order to access that file, or tap the blue Search button on the keyboard to narrow the results.
    Figure : Typing the search terms
  3. In the Search results, tap the file name to open the Preview.
    The lower left corner of the Preview screen shows the file size, when the file was last modified, and the source.
    Figure : File details
    File details
    Depending on the location of the file, several options are available on the bottom menu bar: Collect, Download, Print, and Open in.
    Figure : Details screen
    Details screen
Opening and using files with HP Connected Drive
Follow these steps to select and begin using a file.
When selecting only local files, the Collect, Print, and Open buttons are enabled, but Download is not. When selecting cloud files (Box, Dropbox, Facebook, and HP Connected Drive), the Download, Print, Open in, and Delete buttons are enabled, but Collect is not.
You cannot delete files on the local device or connected devices; you can delete only files from your Collection and other cloud storage services such as Box and Dropbox.
  1. Use one of the following methods to select the files:
    • Selecting a single file - Tap the file you want to work with.
      Figure : Selecting a single file
      Tapping the file
    • Selecting multiple files - Tap the Select mode icon in the upper right.
      Figure : Using Select mode
      Using Select mode
      Then tap the selection buttons for the files you want to work with.
      Figure : Selection buttons
      Selection buttons
      If you select multiple files from a variety of locations (for example some local, some in Box, and some in HP Connected Drive), some of the buttons at the bottom of the screen might be disabled.
      Figure : Selecting multiple files
  2. You can review the details about the files selected. Depending on the type of file you are viewing and whether you are in grid view or list view, this information might include file name, source, date modified, date created, or file size.
  3. Select an icon at the bottom of the screen to begin using the file. The icons are contextual and offer only those actions that apply to the selected file.
    Figure : Example of icons for photo file in the cloud
The following list describes the actions available for a photo file.
  • Download
    1. Tap Download to download a cloud file from HP Connected Drive, Facebook, Box, or Dropbox.
    2. After downloading, go to All Content to view the downloaded file.
  • Collecting a file - uploading to your Collection (HP Connected cloud drive)
    The following example shows how to collect a file to your Collection. You can collect a file from the local device or a remote connected device.
    1. Tap Collect to upload a file.
      Figure : Collecting a file
      Collecting a file
    2. To see the file progress, tap the Back button in the upper left and then tap Current Activity on the bottom app bar.
      Cancel the download by tapping the X button beside the progress bar.
      Collecting a file
    3. When the file upload is complete, tap the blue menu button on the bottom app bar to see the new file.
    4. The uploaded file displays.
      Figure : New file in My Collection
  • Print: You can print a PDF or photo file from HP Connected using an Airprint compatible device.
    1. Tap More and then tap Print to print a PDF document or photo.
      Figure : Printing a photo
      Printing a photo
    2. Select a printer and set the number of copies. Then follow the on-screen instructions to print.
      Figure : Setting printer options
  • Open in: Tap Open in , and tap Open in again.
    You can also save the image, assign it to a contact, copy, or print from this screen.--
    Figure : Example of options
    Example of options
    In the Open in Options menu, tap the app you want to use.
    For example, you can send the file by email, SMS, or use other services that appear on screen. Each type of file has its own options. This list will depend on what apps are already installed on the device.
    Figure : Open in options menu
  • Delete: Tap Delete . Tap Delete on the confirmation screen to delete the file. Tap Cancel to cancel the action.
    You cannot delete files on the local device; you can delete only cloud files.
    Figure : Deleting a file
    Deleting a file
Collecting or Downloading files from a remote connected device
With HP Connected Drive, you can download files located on another connected device. Connected Drive retrieves the file from the remote device (downloads) and makes a copy of it on your local device. Connected Drive can also retrieve files located on another connected device (collect) and make a copy of them in your Connected Drive cloud storage.
To retrieve files from remote devices, make sure that all your connected devices are upgraded to the latest version of the HP Drive app. In addition, the connected device on which you want to access files must be powered on with Connected Drive running in the background.
Use the following steps to download files to the local device.
  1. Tap the Sources button on the bottom app bar.
  2. In the Devices area, select the device that contains the files you want to download.
    Figure : Selecting the connected device
  3. The device opens showing all the files. Tap the check mark in the upper right corner.
    A circle appears next to each file.
    Figure : Circles appear next to each file (list view)
  4. Tap each file that you want to download. As you select each file, a check mark appears in the circle, and the total number of selected files appears at the top of the screen.
    Figure : Selecting files
    Selecting files
  5. After you have selected the files, tap the Download button at the bottom of the screen.
    The process might take a few minutes, depending on the number of files collected.
    Figure : Downloading files
    Downloading files
  6. To see the download progress, tap the Current Activity button on the bottom app bar.
  7. To view the files you downloaded, tap the Sources button on the bottom app bar, and select the local device.
    Figure : Viewing the downloaded files
Changing the Settings for HP Connected Drive
Use the following steps to change the settings for HP Connected Drive.
  1. On the All apps screen, tap the HP Drive icon to open the app.
     HP Drive icon
  2. To open Settings, tap the Settings button on the bottom app bar. The Settings screen displays.
    Settings menu
    The Settings options are described below.
Account
  • Account settings: Name, email, country, change password, and communication preferences.
    Name, email, and country preferences: Click Edit to change the account name, email address, or country.
    Figure : Name and Email settings
    Make the required changes and click Save Changes.
    Changing the password: Click the arrow on the right to open the password screen.
    Figure : Opening the password settings
    Make the required changes. Your password must be at least six characters. When done, click Save Changes.
    Figure : Changing the password
  • Files collected: Shows how many files are uploaded to My Collection. The storage limit is 1,000 files for the Basic service, and unlimited files for the Unlimited service.
  • File size limit: Shows the maximum file size you can upload to HP Connected Drive. The file size is limited to 100MB for any type of file for the Basic service, and 1GB for the Unlimited service.
  • Sign Out: Tap Sign out, and then tap Sign out again or tap Cancel.
    Figure : Signing out
    Signing out
    Signing out removes any content being held temporarily on your device.
System
  • Auto Refresh: The Auto Refresh feature refreshes automatically every 10 minutes. The content includes files, devices, and services. Choose one of the options.
    By default, the option When connected via Wi-Fi is selected.
    • When connected via Wi-Fi: all content will be updated every 10 minutes when the connection is Wi-Fi.
    • Via Wi-Fi or mobile network: all content will be updated every 10 minutes when any connection is available such as Wi-Fi, 3G, or 4G.
    • Never, manual only: Connected Drive will never update the content automatically.
    Figure : Auto refresh options
  • My Devices & Services: Use the Manage Services setting to remove connected services such as Box, Dropbox, and Facebook. Use the Manage Devices section to add, remove, or rename your connected devices.
    Figure : My devices & services
    Renaming a device: To rename a device, click Edit and type a new device name. Then click Save.
    Figure : Renaming a device
    Renaming a device
    Removing a device: To remove a device, click Remove for the device.
Content
  • Clear Search history: When you search for any file, the search history is saved on your device. To clear, tap Clear Search History, and then tap OK.
    Figure : Clearing Search history
    Tapping Search history
About
The About area on the Settings screen provides general information about the app.
  • Terms of use: View the HP Connected Terms of Use.
  • Privacy policy: View the HP Online Privacy Statement.
  • Support: Connect to HP Customer Care.
  • Send feedback: Provide feedback about the app to the HP Connected Drive team. You must have an email connection set up to provide feedback.
  • App version: Indicates the app version.
