Product Name
13-g260br
Product Number
F4H18LA
1.6GHz 4th generation Intel Core i5-4202Y Processor with Turbo Boost up to 2.0GHz
Memory
On-board 4GB 1600MHz DDR3L SDRAM
Video Graphics
Intel HD Graphics 4200
13.3-inch diagonal HD LED- backlit IPS touchscreen display (1366 x 768)
Hard Drive
500GB 5400RPM hard drive with HP ProtectSmart Hard Drive Protection
128GB solid-state drive
Wireless Connectivity
Intel 2x2 802.11b/g/n WLAN and Bluetooth with WiDi
Sound
Beats Audio dual speakers
Keyboard
Full-size island-style keyboard
Pointing Device
HP Imagepad supporting multi-touch gestures without on/off button.
External Ports
2 SuperSpeed USB 3.0
1 HDMI
1 Headphone-out/microphone-in combo jack
Dimensions
Slate only: 1.11cm (H) x 34.00cm (W) x 21.60cm (D)
Clamshell: 1.90cm (H) x 34.00cm (W) x 21.70cm (D)
Slate only: 1.07kg
Clamshell: 2.10kg
Power
45W AC adapter
3-cell 33WHr lithium-ion polymer battery and 3-cell 32WHr lithium-ion polymer battery
ID Mech Description
Front-facing HP TrueVision full HD Webcam with integrated dual digital microphones
- ${title}
- ${title}
- ${title}
- ${title}
HP Split 13-g260br x2 PC Product Specifications
Operating System:
Windows 8.1 Pro (64-bit)
Communication Chat:
Skype
Cyberlink YouCam DE: Chat live and capture video or photos.
HP Help Support:
HP Support Assistant: Helps you maintain the performance of your PC and resolve problems with automated updates and tune-ups, built-in diagnostics, and guided assistance.
HP Utility Center: With the HP Utility Center on Windows 8 PCs, get one place to control your settings for all things HP.
Books, Music, Photos, and Videos:
Amazon Kindle for PC e-reader
HP Connected Photo: Sync, edit, and share photos. Picture the fun.
HP Connected Music: Discover music in a whole new way–from multiple sources.
Productivity Tools:
7-zip: Free File Archive utility preinstalled on HP Windows 8 platforms. Consumers can use 7-zip anywhere, anytime.
HP ePrint
Box: Simple, secure sharing from nearly anywhere.
Buy Office 365: The most powerful Office yet with smarter versions of your favorite applications and new cloud services that connect you to your documents and settings – when and where you need them. (.
Getting Started with Windows 8: HP’s application makes it fun & easy to get to know Windows 8. Let us help you learn the basics of navigating the new Start Screen, powering off your device, and additional tips and tricks through helpful step by step videos.
HP CoolSense technology adjusts its temperature based on usage and conditions. It stays cool. You stay comfortable.
Security Protection:
Free 12-month Trial of McAfee LiveSafe service included. McAfee LiveSafe service enriches your digital life by protecting your data, identity and all your devices so you can connect with confidence.
HP ProtectSmart helps protect your data from accidental bumps and bruises.
HP Recovery Manager: Recover, restore, and create recovery media for, your PC.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
