    Fix HP Printer issue on macOS
HP OfficeJet Enterprise Color X555, MFP X585 - 15.B0, 15.C0 jam error in the left door
Use the information in this document to clear a paper jam inside the left door of the printer. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 15.B0.yz
  • 15.C0.yz
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam inside the left door of the printer:
  1. Open the left door.
    Figure : Open the left door
  2. Gently remove any visible paper from the rollers and delivery area.
    If the sheet tears, make sure that all fragments are removed before you resume printing. Do not use sharp objects to remove fragments.
    Figure : Remove paper from inside the left door
  3. Close the left door.
    Figure : Close the left door
