HP EliteBook 8540w Mobile Workstation - The System Hangs on Windows Logo If Micro SD Card Is Plugged in
Environment
MS Windows 7 Professional
Micro SD Card.
Questions/Symptoms
The system hangs on Windows Logo and the computer must be rebooted.
The system needs to be restarted twice in order to load Windows.
Cause
A defective Micro SD card plugged in causes the issue.
Answer/Solution
Replace the defective Micro SD card.
