HP Spectre 13 Pro Notebook PC - Specifications
System unit
Feature
Stand-alone power requirements (AC power)
Max operating power
< 45 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
13.3-inch LED FHD (1900 x 1080) anti-glare
Feature
Dimensions (W x H)
29.3 x 16.5 cm (11.53 x 6.49 in)
Diagonal size
33.8 cm (13.3 in)
Surface treatment
anti-glare
Touch-enabled
Yes
Contrast ratio
500:1 (typical)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Pitch: 0.215 mm
  • Format: 1900 x 1080
  • Configuration: RGB stripe
Backlight
LED
PPI
118 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
13.3-inch diagonal QHD LED Anti-Glare (2560x1440) (Slim 3.0 mm) UWVA
Feature
Dimensions (W x H)
30.63±.05 x 18.87±.05 cm (12.06±.02 x 7.43±.02 in)
Active area
29.34 x 16.50 cm (11.55 x 6.50 in)
235 g (maximum)
Diagonal Size
33.8 cm (13.3 in)
Surface treatment
anti-glare
Touch-enabled
Yes
Contrast ratio
700:1 (typical)
Refresh rate
60 Hz
Brightness
340 nits (typical)
Pixel resolution
  • Pitch: 0.215 mm
  • Format: 2560 x 1440
Backlight
LED
PPI
221 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up) (typical)
Storage and drives
Internal storage
128GB M.2 Solid State Drive (SSD)
Feature
Drive weight
10 g
Capacity
128GB
Height
2.3 mm (0.091 in)
Width
22 mm (0.87 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 500 MB/s
  • Maximum sequential write: Up to 250 MB/s
Logical blocks
250,069,680
Operating temperature
0° to 70°C (32° to 158°F) [case temp]
Features
ATA Security; ATA-7; SATA 2.6; DIPM; TRIM
256GB M.2 SSD
Feature
Drive weight
10 g
Capacity
256GB
Height
2.3 mm (0.091 in)
Width
22 mm (0.87 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential write: Up to 350 MB/s
Logical blocks
500,118,192
Features
Networking/Communication
Intel Dual Band Wireless- N 7260AN 802.11a/b/g/n (2 x 2) WiFi + Bluetooth 4.0 Combo Adaptor
Feature
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
  • 802.11b/g/n: 2.402 - 2.482 GHz
  • 802.11a/n:
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
Direct Sequence Spread Spectrum CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • IEEE and WiFi compliant 64/128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power2
  • 2.4G: +13.5 dBm minimum
  • 5G: +12 dBm minimum
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode3: 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio off: 75 mW
Power management
  • ACPI and PCI Express compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity4
  • 802.11g:-90 dBm (6 Mbps), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11b:-95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mb/s), -88 dBm (11 Mb/s)
  • 802.11g:-90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11n:-69 dBm (150 Mb/s), -66 dBm (300 Mb/s)
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factor
PCI-Express Half-MiniCard
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
3.1g
Operating voltage
3.3 v +/- 9%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
1: Check latest software/driver release for updates on supported security features.
2: Maximum output power may vary by country according to local regulations.
3: In Power Save Polling mode and on battery power.
4: Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Feature
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx): 264 mW
  • Peak (Rx): 231 mW
  • Sleep: < 1 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Intel Dual Band Wireless- AC 7260 802.11a/c (2 x 2) WiFi + BT 4.0 combo Adapter
Feature
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11a/c
Interoperability
Wi-Fi certified
Frequency band
  • 802.11a/n:
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data rates
  • 802.11n: MCS 0 ~ MCS 15, (20 MHz, and 40 MHz)
  • 802.11ac : MCS0 ~ MCS9, (1SS, and 2SS) (20 MHz, 40 MHz, and 80 MHz)
Modulation
BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security1
  • IEEE 802.11i
  • WAPI
Roaming
Output power2
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas >20 cm from the user and peak gain of +3 dBi at 2.4 GHz and +4 dBi at 5 GHz
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN Associated)
  • Radio Off: 75 mW
Power management
Receiver sensitivity3
  • 802.11a/g:-90 dBm (6 Mbps), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
Antenna connections
High efficiency antenna with spatial diversity, mounted in the display enclosure
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
3.1 g
Operating voltage
3.3 v +/- 9%
Temperature
Humidity
Altitude
LED activity
3: Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Feature
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx): 330 mW
  • Peak (Rx): 230 mW
  • Sleep: < 17 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
Link topology
Security
Power management
  • Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
  • Generic Access Profile (GAP)
  • Dial_Up Networking Profile (DUN)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Printing Profile (BPP)
  • VDP (Video Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
Intel Dual Band Wireless- N 7260BN 802.11b/g/n WiFi + BT 4.0 combo adapter
Feature
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
Antenna structure
Data rates
Modulation
Security1
  • IEEE 802.11i
  • WAPI
Roaming
Output power
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Radio Off: 75 mW
Power management
  • 802.11g: -90 dBm (6 Mbps), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11b: -95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mb/s), -88 dBm (11 Mb/s)
Antenna connections
Form factor
Dimensions
3.1 g
Operating voltage
3.3 v +/- 9%
Temperature
Humidity
Altitude
LED activity
Feature
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kb/s asymmetric or 1306.9 kb/ps symmetric
Transmit power
Power consumption
  • Peak (Tx): 330 mW
  • Peak (Rx): 230 mW
  • Sleep: < 17 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
Link topology
Security
Power management
Certifications
  • FAX Profile (FAX)
Audio/Multimedia-DTS sound
Feature
Implementation
IDT92HD99 High Definition CODEC
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes, dual digital microphone array
Audio output quality
Feature
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
> 85 dB
Total harmonic distortion
0.01%
Noise Floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo speakers
Feature
Power rating
2 W
Impedance
4 Ohms
Power specifications
4-cell HP (51 WHr) Lithium-Ion Polymer
Feature
Dimensions (H x W x L)
3.71 x 68.2 x 110.3 mm (0.15 x 2.69 x 4.34 in)
318 +/- 15 g
Cells/Type
4-cell/Polymer
Energy
  • Voltage (Nominal): 7.5 V
  • Amp-hour capacity (minimum): 6.75 Ah
  • Watt-hour capacity: 51 Wh
Temperature
  • Operating (charging): 0° to 45°C (32° to 113°F)
  • Operating (Discharging): -10° to 50°C (14° to 122°F)
  • Non-operating (storage) temperature: -20° to 50°C (-4° to 122°F)
Fuel Gauge LED
No
1 year
Optional travel battery available
No
HP 45-W smart AC adapter
Feature
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
90 to 265 V ac:
  • Input efficiency: 87% min at 115 V ac
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.4 A at 90 V ac and maximum load
Output
  • Output power: 45 W
  • DC output: 19.5 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: < 8 A, Over voltage protection -29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 0° to 35°C (32° to 95°F)
  • Non-operating temperature (storage): -20° to 85°C (-4° to 121°F)
  • Altitude: 0 to 5,000 m (0 to 16,405 ft)
  • Humidity: 0% to 95%
  • Storage humidity: 0% to 95%
EMI and Safety Certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
