HP 350 G1 Notebook PC
Feature
Processor
Chipset is integrated with processor
Graphics
Storage and drives
Memory
Networking/communications
Audio/multimedia
Power
Stand-Alone power (Nominal Operating)
18.5 V/19.5 V
Requirements (ac Power)
Max operating power: < 65 W
Ports/slots
note: note: |
15.6-inch diagonal LEDbacklit
HD anti-glare flat
(1366 x 768)
Active area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Diagonal size
39.6cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
101 ppi
Viewing angle
Internal storage
500GB 7200 rpm SATA
hard drive
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum): 300 MB/s (Drive capability)
Seek Time
(typical reads, including
settling)
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature [case temp]
0°C to 60°C (32°F to 140°F)
Features
ATA Security
1TB 5400 rpm
SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek Time
settling)
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA Security
750GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum): 300 MB/s (Drive Capability)
Seek Time
settling)
Rotational speed
5400 rpm
Logical blocks
1,465,149,168
Features
ATA Security
500GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum): 150 MB/s (Drive Capability)
Seek Time
settling)
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security
320GB 5400 rpm
SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek Time
settling)
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA Security
Optical drives
DVD+/-RW
SuperMulti DL drive
Access times (Random)
Max data transfer rate
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported media (read)
Supported media (write)
Max media capacity (read)
8.5GB
Max media capacity
(write)
8.5GB
Transport
Tray loading
Audio
Audio output quality
Integrated stereo
speakers
Multimedia
Integrated HD webcam
HP 65 W AC adapter
Dimensions
10.7 x 4.7 x 3.0 cm (4.21 x 1.85 x 1.18 in)
280 g (0.62 lb)
Input
Output
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
EMI and safety
certifications
4-Cell (41 WHr)
Lithium-Ion battery
Cells/Type
4-cell Lithium-Ion
Energy temperature
Battery
Re-Charge time
Networking
Integrated Realtek
10/100/1000 NIC
Ethernet features
Power management
Performance features
Manageability
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCIe FE Ethernet family controller
Communications
Atheros 802.11b/g/n
WiFi adapter
Wireless LAN standards
Interoperability
Wi-Fi certified
Frequency band
2.402 - 2.482 GHz
Data rates
Frequency support
Modulation
Direct sequence spread spectrum
Security
Sub-channels
Multinational support with frequency bands and channels compliant to local
regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture
models
Roaming
IEEE 802.11 compliant roaming between access points
Output power
13.5 dBm, minimum
Power consumption
Power management
Receiver sensitivity
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the
display enclosure
Form factor
PCI-Express Half-MiniCard
4 g (0.008 lb)
Dimensions
3.3 x 26.65 x 29.85 mm (0.12 x 1.04 x 1.17 in)
Operating voltage
3.3v +/- 9%
Temperature
Humidity (non-condensing)
Altitude
LED Activity
Ralink 802.11b/g/n
Bluetooth 4.0 combo
card
Interoperability
Wi-Fi certified
Frequency band
2.402 - 2.482 GHz
Data rates
Modulation
Direct Sequence Spread Spectrum
DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
Sub-channels
regulations.
Media Access Protocol
Network Architecture
models
Roaming
QuickSpecs HP 350 G1 Notebook PC
Technical Specifications
DA
Output power
(for CCK)
13.5dBm , minimum
Power consumption
Power management
Antenna type
High efficiency dual antenna with spatial diversity, mounted in the display
enclosure
Form factor
PCI-Express Half-MiniCard v1.2
6 g (0.013 lb)
Dimensions
Operating voltage
3.3v +/- 10%
Temperature
Altitude
LED Activity
Bluetooth specification
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Number of available
channels
79 (1 MHz) available channels
Data rates and
throughput
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power consumption
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical interface
Bluetooth software
supported
Link topology
Security
Full support of Bluetooth Security Provisions
Power management
Certifications
All necessary regulatory approvals for supported countries, including:
Bluetooth profiles
supported
Broadcom 802.11a/b/g/n
(2x2) + Bluetooth 4.0
combo
Interoperability
Wi-Fi certified
Frequency band
Data rates
Modulation
BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security
models
Roaming
Output power
Power consumption
Power management
Antenna type
Form factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating voltage
3.3v +/- 9%
Temperature
Altitude
LED activity
Bluetooth Specification
Number of available
channels
Data rates and
throughput
Transmit power
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Sleep < 17 mW
Antenna
Range
Up to 10 m (33 ft)
Bluetooth software
supported
Link topology
Security
Full support of Bluetooth security provisions
Power management
Certifications
Bluetooth profiles
supported
Temperature
Relative humidity
Shock
Random vibration
Altitude (unpressurized)
Dimensions (W x D x H)
26.1 x 38.4 x 2.31 cm (10.28 x 15.12 x .91 in)
Starting at 2.30 kg (5.07 lbs)
note: |
Feature
Operating system (Preinstalled)
Software and security
note: |
Planned industry
standard
certifications
