HP EliteDisplay E241i 24-inch IPS LED Backlit Monitor - Identifying Components
Front view
Item
Component
Function
1
Menu
Opens, selects or exits the OSD menu.
2
If the OSD menu is On, press to navigate backward through the OSD menu and decrease adjustment levels.
3
"+"/Input
Select input source. If the OSD menu is On, press to navigate forward through the OSD menu and increase adjustment levels.
4
OK/auto
If the OSD menu is On, press to select the highlighted menu item. If the OSD menu is inactive, press to activate the auto adjustment feature to optimize the screen image.
5
Power LED
fully powered = green; sleep mode = amber; sleep timer mode = flashing amber.
6
Power
Turns the monitor On or Off.
