    Apache Log4j Update
Document ID: c04113076
Version: 1
System BIOS Update F.46 for 8470w, 8470p, 6470b, 8570p, and 6570b
Release date : 03-Feb-2014
Last updated : 03-Feb-2014
DETAILS OF CHANGE
  • Provides support to view hard drive information and the MAC address in F10 (BIOS) Setup System Information.
  • Fixed an intermittent issue where the computer does not PXE boot properly from Wake on LAN (WOL).
  • Fixed an issue where the fan could cause an error message to be displayed.
  • Fixed an issue where crisis recovery does not run properly from certain flash drives.
  • Fixed an issue where the information of the secondary battery would not be correct when running HP System Diagnostics.
  • Added support the the new Elpida VRAM modules.
SUPPORT URL
Get the latest BIOS update from the HP Software dowload site for the 8470p, 6470b, 8570p, and 6570b.
REASON FOR CHANGE
Quarterly refresh for factory and Web release only.
IMPACT OF CHANGE
- To avoid compatibility issues on computers with the new Elpida VRAM modules, do not downgrade the BIOS to any version older than F.46.
If upgrading to this BIOS from a version older than F.30, it is recommended that the user enter the F10 (BIOS) Setup and restore defaults after backing up existing F10 (BIOS) Setup settings. For information on restoring F10 (BIOS) Setup settings, see System BIOS Update F.46 for 8470w, 8470p, 6470b, 8570p, and 6570b.
Components affected:
HP EliteBook 8470w Mobile Workstation, HP EliteBook 8470p Notebook PC, HP ProBook 6470b Notebook PC, HP EliteBook 8570p Notebook PC, and HP ProBook 6570b Notebook PC
DATE OF CHANGE
Effective date : 15-Jan-2014
Hardware platforms affected : HP EliteBook 8470p Notebook PC, HP EliteBook 8470w Mobile Workstation, HP EliteBook 8570p Notebook PC, HP ProBook 6470b Notebook PC, HP ProBook 6570b Notebook PC
