    We are upgrading our website
HP Designjet T2500 eMultifunctional Printer Series - Cannot insert an ink cartridge
  1. Check that you have the correct type of cartridge (model number).
  2. Check that the colored label on the cartridge is the same color as the label on the slot.
  3. Check that the cartridge is correctly oriented, with the letter or letters marking the cartridge label right-side up and readable.
Never clean inside the ink cartridge slots.
