    Windows 11 Upgrade Guide
HP Pavilion 17-e148ca Notebook PC Product Specifications
Product Name
17-e148ca
Product Number
F9A50UA
2.5GHz up to 3.5GHz AMD Quad-Core A10-5750M Accelerated Processor
Microprocessor Cache
4MB L2 Cache
Memory
8GB DDR3L SDRAM (1 DIMM)
Memory Max
Maximum supported = 8GB
Memory Slots
2 user accessible
Video Graphics
AMD Radeon HD 8650G graphics with up to 4206MB total graphics memory
17.3-inch diagonal HD+ BrightView LED-backlit display (1600 x 900)
Hard Drive
1TB 5400RPM hard drive with HP ProtectSmart Hard Drive Protection
Multimedia Drive
SuperMulti DVD burner
Network Card
10/100BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity
1x1 802.11b/g/n WLAN
Bluetooth
Sound
DTS Sound+
Keyboard
Full-size keyboard with numeric keypad
Pointing Device
Touchpad supporting multi-touch gestures without on/off button
External Ports
Multi-format digital media card reader for Secure Digital cards
2 SuperSpeed USB 3.0
1 Universal Serial Bus (USB) 2.0
1 HDMI
1 VGA (15-pin)
1 RJ-45 (LAN)
1 Headphone-out/microphone-in combo jack
Dimensions
1.16 in (min H) / 1.29 in (max H) x 16.5 in (W) x 10.5 in (D)
5.99 lb
Power
65W AC adapter
6-cell 47WHr 2.2 Ah lithium-ion battery
ID Mech Description
Front facing HP TrueVision HD Webcam with integrated dual array digital microphone
Operating System:
Windows 8.1 (64-bit)
Communication Chat:
Pinger: Let your PC handle all your communication with a local phone number, unlimited text messaging to any US/Canada number, incoming calls and voicemail—all for free.
Skype
Cyberlink YouCam DE: Chat live and capture video or photos. Be yourself or a favorite avatar!
Games:
Microsoft Games: (Solitaire and Mahjong) Free pre-installed Windows 8 games, ready to play.
WildTangent Games for HP.
HP Games
HP Help Support:
HP Support Assistant: Helps you maintain the performance of your PC and resolve problems with automated updates and tune-ups, built-in diagnostics, and guided assistance.
HP Utility Center: With the HP Utility Center on Windows 8 PCs, get one place to control your settings for all things HP.
Shopping Services:
Netflix: Watch movies and TV online or via DVDs with subscription.
Amazon
Books, Music, Photos, and Videos:
Amazon Kindle for PC e-reader
CyberLink PowerDirector: Fast, feature-rich and easy to use, the powerful set of integrated tools lets you create brilliant videos. Whether you’re practically an expert or a novice. Packed with intuitive and exciting features and is designed for creating brilliant high definition videos that will amaze your friends and family.
CyberLink PhotoDirector: Makes it easy to create spectacular photos. From the moment your images are imported, the software empowers you with the tools you need to create eye-catching images, including photo management, photo adjustment and advanced editing features.
CyberLink Media Suite
CyberLink Power2Go
CyberLink LabelPrint
HP Connected Photo: Sync, edit, and share photos. Picture the fun
HP Connected Music: Discover music in a whole new way–from multiple sources.
Productivity Tools:
7-zip: Free File Archive utility preinstalled on HP Windows 8 platforms. Consumers can use 7-zip anywhere, anytime.
HP ePrint
Box: Simple, secure sharing from nearly anywhere.
Buy Office 365: The most powerful Office yet with smarter versions of your favorite applications and new cloud services that connect you to your documents and settings – when and where you need them.
Getting Started with Windows 8: HP’s application makes it fun & easy to get to know Windows 8. Let us help you learn the basics of navigating the new Start Screen, powering off your device, and additional tips and tricks through helpful step by step videos.
HP CoolSense technology adjusts its temperature based on usage and conditions. It stays cool. You stay comfortable.
Security Protection:
Free 30-day Trial of McAfee LiveSafe service included. McAfee LiveSafe service enriches your digital life by protecting your data, identity and all your devices so you can connect with confidence.
HP ProtectSmart helps protect your data from accidental bumps and bruises.
HP SimplePass: Access online accounts with a single password or PIN.
HP Recovery Manager: Recover, restore, and create recovery media for, your PC.
