    Windows 11 Upgrade Guide
HP Designjet Z5400 PostScript ePrinter Series - Color management from the front panel
You can color-calibrate the loaded paper type from the front panel by pressing , then , then Image quality maintenance > Calibrate color. See Color calibrationColor calibration.
The other color options in the front panel can all be found by pressing , then , then Setup > Printing preferences > Color options.
These front panel settings can all be overridden by the printer driver or Embedded Web Server job submission settings.
All jobs
  • Color/Grayscale: you can choose to print in color or in shades of gray. Default: Print in color.
  • Select RGB source profile: you can choose from a selection of RGB source profiles recognized by the printer. Default: sRGB (HP).
  • Emulate printer: you can choose to emulate a different HP Designjet printer. Default: Off (no printer emulation).
    If you have old HP-GL/2 or PostScript files made for a different HP Designjet printer, you can send them to the printer and use the front panel to turn on the appropriate emulation mode.
PostScript and PDF jobs only
  • Select CMYK source profile: you can choose from a selection of CMYK source profiles recognized by the printer. Default: US Coated SWOP v2.
  • Select rendering intent: you can select the rendering intent. Default: Perceptual.
  • Black point compensation: you can turn black point compensation on or off. Default: On.
  • HP Professional PANTONE Emulation: you can turn HP Professional PANTONE Emulation on or off. Default: On.
