    Find Windows 11 and Windows 10 support help. Click here
HP ProBook 650 G1 Notebook PC Product Specifications
HP ProBook 650
Product features
Feature
Mobile Intel HM87 or QM87
Processor
Intel Core i7 processor; Intel Core i5 processor; Intel Core i3 processor14
Graphics
  • Integrated: Intel HD Graphics 4600
  • Discrete: AMD Radeon HD 8750M, with 1GB dedicated DDR5 video memory
Internal
  • 14-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
  • 14-inch diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900)
  • 14-inch diagonal LED-backlit FHD anti-glare UWVA slim (1920 x 1080)
External
Up to 32-bit per pixel color depth
VGA
Port supports resolutions up to 1920 x 1200 external resolution @75 Hz
DisplayPort 1.2
Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
DVI-D (single link)
Video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Storage/Drives
Hard drives
  • 320/500/1TB 5400-rpm SMART SATA II HDD (hard disk drive)
  • 320/500/750GB 7200-rpm SMART SATA II HDD
  • 500GB 7200-rpm SED (Self Encrypting Drive)
  • 500GB 5400-rpm FIPS SED
SSD (Solid State Drive)
  • 128/180GB 2.5-inch SSD
  • 256GB SED SSD
HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
Optical drives
Fixed 9.5 mm Serial ATA upgrade bay
  • Blu-ray ROM DVD+/-RW SuperMulti DL Drive
  • DVD+/-RW SuperMulti DL Drive
  • DVD-ROM Drive
Flash cache
32GB M.2 (NGFF)
Memory
Standard
  • DDR 3L PC3L-12800 (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Maximum
Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Environmental specifications
Specification
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (50 to 40,000 ft)
Display specifications
14.0-inch diagonal LED-backlit HD anti-glare SVA eDP 1.2 flat
Specification
Outline dimensions (W x H x D)
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active area
30.94 x 17.395 cm (12.18 x 6.85 in)
320 g (0.71 lb) max
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Format: 1366 x 768 (HD)
  • Configuration: RGB stripe
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
14.0-inch diagonal LED-backlit HD+ anti-glare SVA eDP 1.2 flat (1600 x 900)
Specification
Active area
30.96 x 17.415 cm (12.19 x 6.86 in)
325 g (0.72 lb) max
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nits (typical)
Pixel resolution
  • Format: 1600 x 900 (HD+)
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
131 ppi
Viewing angle
14.0-inch diagonal LED-backlit FHD anti-glare UWA eDP 1.3 slim PSR (1920 x 1080)
Specification
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active area
30.93 x 17.4 cm (12.19 x 6.86 in)
325 g (0.72 lb) max
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
  • Format: 1920 x 1080 (FHD)
Interface
eDP 1.3+PSR (2 lane)
LCD mode
IPS/FFS/VA
PPI
157 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
15.6-inch diagonal LED-backlit HD anti-glare SVA eDP 1.2 flat (1366 x 768)
Specification
36.0 x 22.43 x 0.38 cm (14.17 x 8.83 x 0.15 in)
Active area
34.42 x 19.35 cm (13.55 x 7.62 in)
500 g (< 1.1 lb) max
Diagonal size
39.62 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
101 ppi
Viewing angle
15.6-inch diagonal LED-backlit FHD anti-glare SVA eDP 1.2 slim (1920 x 1080)
Specification
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
Viewing angle
Storage and drives
Internal storage
320GB 5400-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum): 300 MB/s (drive capability)
Seek time (typical reads, including settling)
  • Single track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
625,142,448
Operating temperature
0° to 60°C (32° to 140°F) (case temp)
Features
ATA security
500GB 5400-rpm SATA hard drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
1TB 5400-rpm SATA hard drive
Specification
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security
320GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA security
500GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
750GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB 7200-rpm SMART SATA II SED (Self Encrypting Drive)
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
  • Single track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
500GB 5400-rpm SATA FIPS hard drive
Specification
Drive weight
95 g (0.20 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
SATA 6-Gb/s 128GB, 2.5-inch SSD (Solid State Drive)
Specification
Drive weight
73 g (0.16 lb)
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 415 MB/s
  • Maximum Sequential Write: 175 MB/s
Logical blocks
250,069,680
0° to 70°C (32° to 158°F) (case temp)
Features
ATA Security; ATA-8; SATA 3.0; DIPM; TRIM
SATA 6-Gb/s 180GB, 2.5-inch SATA SSD
Specification
Drive weight
78 g (0.17 lb)
Capacity
180GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: Up to 550 MB/s
  • Maximum Sequential Write: Up to 520 MB/s
Logical blocks
351,651,888
Features
SATA 6-Gb/s 256GB, 2.5-inch SATA SED SSD
Specification
Drive weight
73 g (0.16 lb)
Capacity
256GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 460 MB/s
  • Maximum sequential write: Up to 260 MB/s
Logical blocks
500,118,192
Features
ATA Security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
Power specifications
HP 90-W Smart AC adapter (discrete or UMA configurations)
Specification
Dimensions
12.7 x 5.0 x 2.9 cm (5.00 x 1.97 x 1.1 in)
370 g (0.82 lb)
Input
100 to 240 V ac
Input efficiency
87% min at 115 V ac
Input frequency range
47 to 63 Hz
Input AC current
  • 1.5 A at 90 V ac, 0.75 A at 180 V ac PFC Version
  • 2.4 A at 90 V ac, 1.2 A at 180 V ac non PFC Version
Output
  • Output power: 90 W
  • DC output: 19.0 V
  • Hold-up time: 5 ms at 115 V input
  • Output current limit: < 11 A, Over voltage protection -29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
0° to 40°C (32° to 104°F)
Non-operating (storage) temperature
-20° to 65°C (-4° to 149°F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
Storage humidity
10% to 90%
EMI and Safety Certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
HP 65-W Smart AC adapter (UMA configurations)
Specification
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
100 to 240 V ac
Input efficiency
87% min at 115 V ac
47 to 63 Hz
Input AC current
1.7 A at 90 V ac, 0.85 A at 180 V ac
Output
  • Output power: 65 W
  • DC output: 18.5 V
Connector
Altitude
Humidity
20% to 80%
Storage humidity
10% to 90%
HP 9-cell (100 WHr) Lithium-Ion Primary battery
Specification
Dimensions (H x W x L)
2 x 6.6 x 20.5 cm (0.8 x 2.4 x 8.1 in)
Weight (max)
0.498 g (1.1 lb)
Cells/Type
Lithium-Ion
Energy
  • Voltage: 11.25 V
  • Amp-hour capacity: 8.85 Ah
  • Watt-hour capacity: 100 Wh
Temperature
Operating (Charging)
0° to 40°C (32° to 113°F)
Operating (Discharging)
-10° to 50°C (14° to 122°F)
Non-operating
-20° to 50°C (-4° to 122°F)
Humidity
20% to 80%
Battery re-charge time
  • System in Off or Standby Mode: 3.5 to 5 hours
  • System On: 4 to 7 hours
Fuel gauge LED
No
1 year
Compatible with optional travel battery
Yes
HP 6-cell (55 WHr) Lithium-Ion primary battery
Specification
2.0 x 4.7 x 20.5 cm (0.8 x 1.8 x 8.0 in)
Weight (max)
0.313 g (0.70 lb)
Cells/Type
Lithium-Ion
Energy
  • Voltage: 10.8 V
  • Amp-hour capacity: 5.1 Ah
  • Watt-hour capacity: 55 Wh
Temperature
Non-operating
  • System in Off or Standby Mode: 2.5 hours
  • System On: 3 to 5hours
Fuel gauge LED
No
1 year
Yes
HP 3-cell (31 WHr) Lithium-Ion primary battery
Specification
Weight (max)
0.210 g (0.471 lb)
Cells/Type
Lithium-Ion
Energy
  • Voltage: 11.1 V
  • Amp-hour capacity: 2.8 Ah
  • Watt-hour capacity: 31 Wh
Temperature
Non-operating
Fuel gauge LED
No
1 year
Yes
Software overview
Feature
Operating System1
Preinstalled:
  • Windows 8 64
  • Windows 8 Pro 64
  • Windows 7 Professional 32 (available through downgrade rights from Windows 8 Pro 32)
  • Windows 7 Professional 64 (available through downgrade rights from Windows 8 Pro 64)
  • Windows 7 Home Premium 32
  • Windows 7 Home Premium 64
  • SUSE Linux Enterprise Desktop
  • FreeDOS 2.0
Preinstalled Software with Windows Operating System
BIOS
  • HP DriveLock
  • HP Automatic Drive Lock
  • HP BIOS Protection
  • HP Disk Sanitizer
  • HP SpareKey
  • Update via Network
  • Master Record Security
  • Power On Authentication
  • Pre-Boot Security
  • Secure Erase
  • Hybrid Boot
  • Measured Boot
  • Secure Boot
  • Absolute Persistence Module
MultiMedia
  • CyberLink PowerDVD
  • CyberLink Power2Go (Optical drives)
  • CyberLink YouCam BE (Windows 7 only)
Communication
  • HP Connection Manager (Windows 7 only)
  • HP GPS and Location (Windows 7 only)
  • HP Mobile Connect (Windows 8 only)
  • HP Wireless Hotspot (Windows 8 only)
  • Intel WiDi Software
  • HP Roaming Alert (Windows 8 only)
  • Intel My WiFi and Wireless Drivers
1: Not all features are available in all editions of Windows 8. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows 8 functionality.
Energy consumption
Energy Consumption (in accordance with US ENERGY STAR test method)
115 V ac, 60Hz
230 V ac, 50 Hz
100 V ac, 60 Hz
Normal Operation
13.57 W
13.7 W
12.9 W
Sleep
0.88 W
1.02 W
0.87 W
 Off
0.36 W
0.47 W
0.35 W
Heat dissipation
115 V ac, 60Hz
230 V ac, 50 Hz
100 V ac, 60 Hz
Normal Operation
46 BTU/hr
47 BTU/hr
44 BTU/hr
Sleep
3 BTU/hr
3 BTU/hr
3 BTU/hr
 Off
1 BTU/hr
2 BTU/hr
1 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Declared noise emissions
Declared Noise Emissions
Sound Power (LWAd, bels)
Sound Pressure (LpAm, decibels)
Typically Configured - Idle
3.6
29
Fixed Disk - Random writes
3.7
30
