HP Spectre 13 x2 Pro Notebook PC Specifications
Product description
True flexibility, true innovation, truly powerful. The sleek, precision-crafted HP Spectre13 x2 offers the benefits of an UltrabookTM that does it all and a convenient tablet in a single, sophisticated design.
Product features
Feature
Integrated SoC PCH
Graphics
Integrated: Intel HD Graphics 4200
  • Support HD Decode, DX11, and HDMI
  • Support PX5.0
Internal
13.3-inch diagonal HD LED Anti-Glare (1366 x 768) (Slim 3.0 mm) UWVA:
  • Supports eDP
  • Touchscreen, Multitouch enabled
External
Up to 32-bit per pixel color depth
HDMI
1.4a port supports up to 1080p, 1920 x 1080 at 60 Hz
Storage and drives1
Internal storage device
128/256GB mSATA 3 solid state
Memory
DDR3L SDRAM (1600 MHz) On-board Standard 4096MB memory
Networking/Communications
Broadband Wireless (WWAN)
  • HP hs3110 HSPA+ Mobile Broadband Module
  • HP lt4112 LTE/HSPA+ Gobi 4G Module
Wireless LAN (WLAN)
  • Intel Dual Band Wireless-AC 7260 802.11ac (2 x 2) WiFi and Bluetooth 4.0 Combo
  • Intel Dual Band Wireless-N 7260AN 802.11a/b/g/n (2 x 2)
  • WiFi and Bluetooth 4.0 Combo
  • Intel Dual Band Wireless-N 7260BN 802.11b/g/n (2 x 2) WiFi and Bluetooth 4.0 Combo
Audio/Multimedia
Audio
  • HP Beats Audio
  • High Definition Beats Audio speakers (front facing)
  • Integrated Dual array Digital Microphones w/appropriate software - beam forming, echo cancellation, noise suppression
  • Formats: MP3, AAC, AAC+, EAAC+ OGG, MIDI
  • Headphone/Line-out (Beats supported) and Mic-in (combo) - Voice recognition
Integrated HP TrueVision Full HD Webcam:
  • FHD format
  • 1080p
  • 2.0MP
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1920x1080 resolution (1080p) and up to 30 f/s
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Keyboards/pointing devices/buttons & function keys
Keyboard
The 101/102-key island-style keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available.
Backlit keyboard
The standard backlit keyboard for low light environments is toggled on and Off with a function key
Pointing devices
Clickpad w/ multi-touch gesture support image sensor, On/Off button with LED indicator, two-way scroll
Buttons
Power, Volume Up, Volume Down, Windows Start/Home
Sensors
Accelerometer, Gyroscope, Digital Compass, NFC, ALS
Power
Power supply
  • External 45-W HP Smart AC adapter
  • Power cord included is 1.0 m (3.3 ft)
Primary battery (slate)
HP 3-cell Polymer Battery (33 WHr)
Primary battery (base)
HP 2-cell Polymer Battery (18 WHr)
Ports/Slots
Ports - slate
  • Headphone/Line-out (Beats Audio supported) and Mic-in (combo) - Voice recognition – One
  • Docking Connector – One
Ports - base
  • USB 3.0 – Two
  • HDMI v1.4a – One
  • Docking Connector (Power + USB) – One
Digital Media Slots
  • HP Multi-Format Digital Media Reader (Push-Push Insertion/Removal) Support SD/SDHC/SDXC
  • Micro Secure Digital (SD) Media Reader (Push-Push Insertion/Removal) Support both SDHC and SDXC
1: For hard drives and SSD's, GB=1 billion bytes. TB=1 trillion bytes. Actual formatted capacity is less. Up to 36GB (for Windows 8.1) of system disk is reserved for system recovery software.
System unit
Feature
Stand-alone power requirements (AC power)
Max operating power
< 45 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
13.3-inch LED HD (1366 x 768) anti-glare
Feature
Dimensions (W x H)
29.3 x 16.5 cm (11.53 x 6.49 in)
Diagonal size
33.8 cm (13.3 in)
Surface treatment
anti-glare
Contrast ratio
500:1 (typical)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Pitch: 0.215 mm
  • Format: 1366 x 768
  • Configuration: RGB stripe
Backlight
LED
PPI
118 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
13.3-inch LED FHD (1900 x 1080) anti-glare
Feature
Dimensions (W x H)
Diagonal size
33.8 cm (13.3 in)
Surface treatment
anti-glare
Contrast ratio
500:1 (typical)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Pitch: 0.215 mm
Backlight
LED
PPI
118 ppi
Viewing angle
  • ±30° horizontal, ±10° Vertical (minimum)
Storage and drives
Internal storage
128GB 2.5-inch mSATA solid state drive (SSD)
Feature
Drive weight
75 g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 2
Performance
  • Maximum sequential read: 250 MB/s
  • Maximum sequential write: 140 MB/s
Operating temperature
0° to 70°C (32° to 158°F) [case temp]
Features
ATA Security; ATA-7; SATA 2.6; DIPM; TRIM
SATA 6 Gb/s 256GB, mSATA SSD
Feature
Drive weight
Up to 10 g
Capacity
256GB
Height
Up to 4.85 mm (0.191 in)
Width
29.85 mm (1.18 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 490 MB/s
  • Maximum sequential write: Up to 250 MB/s
Logical blocks
500,118,192
Features
HP 3110 HSPA+ Mobile Broadband Module
Feature
Technology/Operating bands
  • CDMA/1xRTT/EvDO: 800MHz (Cell), 1900MHz (PCS)
  • GSM/GPRS/EDGE: 850MHz (Cell), 900MHz (EGSM), 1800MHz (DCS), 1900MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100MHz (UTRA FDD Band I), 1900MHz (UTRA FDD Band II), 900MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • LTE: 700 MHz (Verizon, Band XIII)
Mobile operator
Verizon (US only)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class B, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
  • UMTS/WCDMA: Release 99 and Release 7
  • LTE: Power Class III as per 3GPP TS 36.101
Wireless parametric standards
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
  • EvDO (Revision A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
  • WCDMA (DC-HSPA+) - 42 Mb/s (Download)
  • LTE (Category 3) - 100 Mb/s (Download), 50 Mb/s (Upload)
GPS
Standalone, Assisted, XTRA
GPS bands
1575.42 MHz (± 1.023 MHz)
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • LTE: +23 dBm (+2.7 dBm/-1.7 dBm)
  • 1xRTT/EvDO: +24 dBm (+0.5 dBm/-1.5 dBm)
Maximum power
2700 mA (peak)
Power consumption, sleep mode
10 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 6 band antennae with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
< 10 g
Dimensions (L x W x T)
51 x 30 x 4.5 mm (2.01 x 1.18 x 0.18 in)
Operating voltage
3.3 v +/- 9%
-20° to 65°C (-4° to 149°F)
Non-operating temperature, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
Non-operating humidity
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
HP lt4112 LTE/HSPA+ Gobi 4G module
Feature
Decription
  • LTE FDD all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 2600 MHz (Band VII), 900 MHz (Band VIII), 800 MHz (Band XX, DD800)
  • WCDMA/HSDPA/HSUPA/HSPA+ all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 800 MHz (Band V), 900 MHz (Band VIII)
  • GSM/GPRS/EDGE: 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 900 MHz (Band VIII)
  • 3GPP Release 8 LTE Specification
  • WCDMA R99, 3GPP Release 5, 6 and 7 UMTS Specification
Maximum data rates
  • LTE (Category 3): 100 Mb/s (Download), 50 Mb/s (Upload)
  • DC-HSPA+: 42 Mb/s (Download), 5.76 Mb/s (Upload)
  • HSPA+: 21.6 Mb/s (Download), 5.76 Mb/s (Upload)
  • EDGE: 236.8 kb/s (Download), 236.8 kb/s (Upload)
  • GPRS: 85.6 kb/s(Download), 85.6 kb/s (Upload)
GPS
Standalone
GPS bands
1575.42 MHz (± 1.023 MHz), GLONASS 1596-1607 MHz
  • LTE: +23 dBm (+/- 2 dBm)
  • WCDMA: +23.5 dBm (+/- 1 dBm)
  • GPRS Band II, III: +29.5 dBm (+/- 1 dBm)
  • GPRS Band V, VIII: +32.5 dBm (+/- 1 dBm)
  • EGPRS Band II, III: +26.5 dBM (+/-1.5 dBm)
  • EGPRS Band V, VIII: +27.5 dBM (+/-1.5 dBm)
Maximum power
LTE: 1,200 mA (peak); < 900 mA (average)
3 mA
Power management
USB selective suspend, Integrated notebook wireless button
Antenna type
Dual high efficiency multi-band antennae with spatial diversity
Form factor
M.2, USB 2.0 interface
6 g
42 × 30 × 2.3 mm (1.65 x 1.81 x 0.09 in)
Operating voltage
3.135 to 4.4 V (3.3 +1.1 V/-0.165 V)
-10° to 55°C (14° to 131°F)
LED activity
Intel Dual Band Wireless-N 7260AN 802.11a/b/g/n (2 x 2) WiFi + Bluetooth 4.0 combo adaptor
Specification
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
Frequency band
  • 802.11b/g/n: 2.402 - 2.482 GHz
  • 802.11a/n:
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
Direct Sequence Spread Spectrum CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power
  • 2.4G: +13.5 dBm minimum
  • 5G: +12 dBm minimum
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio Off: 75 mW
Power management
  • ACPI and PCI Express compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 802.11g: -90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11b: -95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mb/s), -88 dBm (11 Mb/s)
  • 802.11n: -69 dBm (150 Mb/s), -66 dBm (300 Mb/s)
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factor
PCI-Express Half-MiniCard
3.1 g
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Voltage, operating
3.3 v +/- 9%
Temperature, operating (from TIA/EIA/IS-98-D)
-10° to 70°C (14° to 158°F)
Temperature, non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
HP Integrated Module with Bluetooth 4.0+EDR wireless technology
Specification
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3.64 kb/s, voice channels
  • Asynchronous Connection Less links 2178.1 kb/s/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep < 1 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology security
Point to Point, Multipoint Pico Nets up to 7 slaves
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Intel Dual Band Wireless-AC 7260 802.11ac (2 x 2) WiFi + BT 4.0 combo adapter
Specification
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
Anteena structure
Data rates
  • 802.11n: MCS 0 ~ MCS 15, (20 MHz, and 40 MHz)
  • 802.11ac: MCS0 ~ MCS9, (1SS, and 2SS) (20 MHz, 40 MHz, and 80 MHz)
Modulation
  • Direct Sequence Spread Spectrum
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
  • AES-CCMP: 128-bit in hardware
  • IEEE 802.11i
  • WAPI
Roaming
IEEE 802.11 compliant roaming between access points
Output power
  • 802.11b: -95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mbps), -88 dBm (11 Mb/s)
  • 802.11n: -69 dBm (72.2 Mb/s), -66 dBm (300 Mb/s)
Anteena connections
Form factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
3.1 g
Operating voltage
3.3 V+/- 9%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 80°C (14° to 176°F)
Humidity
Altitude
LED activity
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep < 17 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
  • Full support of Bluetooth Security Provisions
  • Point to Point, Multipoint Pico Nets up to 7 slaves
Power management
Certifications
  • Generic Access Profile (GAP)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Printing Profile (BPP)
  • Video Distribution Profile (VDP)
  • Audio Video Remote Control Profile (AVRCP)
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency band
  • 802.11a/n:
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data rates
Modulation
Security
  • IEEE 802.11i
  • WAPI
Roaming
Output power
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas > 20 cm from the user and peak gain of +3 dBi at 2.4 GHz and +4 dBi at 5 GHz
  • 802.11a/g: -90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
Anteena type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form factor
Dimensions
3.1 g
Operating voltage
3.3 V+/- 9%
Temperature
Humidity
Altitude
LED activity
Transmit power
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep < 17 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
Power management
Certifications
  • FAX Profile (FAX)
Security
Feature
Standard1
  • Symantec Norton Internet Securities (60 Day Subscription - BNB SMB BBY)
  • Absolute Data Protect (90-day subscription)
  • Intel Experience Center
  • Security Lock Slot
  • TPM 1.2 Embedded Security Chip
Optional2
  • Security lock
  • CompuTrace
1: Absolute Data Protect agent is shipped turned off, and must be activated by customers. 90 day subscription included. Subscription and internet access required for updates after the 90 day period. Service may be limited, check with Absolute for availability outside the U.S. The optional subscription service of Absolute Recovery Guarantee is a limited warranty
2: Computrace agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging from one to five years. Service is limited, check with Absolute for availability outside the U.S.
Audio/Multimedia-DTS sound
Specification
Implementation
IDT92HD99 High Definition CODEC
Function key volume
Controls Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes, dual digital microphone array
Audio output quality
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
> 85 dB
Total harmonic distortion
0.01%
Noise Floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo speakers
Specification
Power rating
2 W
Impedance
4 Ohms
Power specifications
HP 65-W Smart AC adapter
Specification
Dimensions
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
  • 90 to 265 V ac
  • Input efficiency: 87% min at 115 V ac
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.4 A at 90 V ac and maximum load
Output
  • Output power: 45 W
  • DC output: 19.5 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: < 8 A, Over voltage protection - 29-V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 0° to 35°C (32° to 95°F)
  • Non-operating (storage) temperature: -20° to 85°C (-4° to 121°F)
  • Altitude: 0 to 5,000 m (0 to 16,405 ft)
  • Humidity: 0% to 95%
  • Storage humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 2-cell polymer battery (18 WHr)
Specification
Dimensions (H x W x L)
  • 294.0 x 130.8 x 3.43 (not including WTB connector)
  • 294.0 x 148.30 x 3.43 (including WTB connector)
Weight (max)
< 185 g
Cells/Type
2-cell polymer
Energy
Watt-hour capacity: 18 WHr
Temperature
  • Operating (Charging): 0° to 45°C (32° to 113°F)
  • Operating (Discharging): -10° to 60°C (14° to 140°F)
  • Non-operating: -20° to 60°C (-4° to 140°F)
1 year
Specification
  • 268.0 x 119.0 x 4.25 mm (not including screw holes)
  • 284.2 x 134.9 x 4.25 mm (including screw holes)
Weight (max)
< 190 g
Cells/Type
3-cell polymer
Energy
Watt-hour capacity: 33 WHr
Temperature
1 year
Software/OS
Feature
Preinstalled Software with Windows Operating System
Browser and toolbars
Internet Explorer 10
UI enhancements
HP Wallpapers
Productivity
Buy Office
Windows live
  • MovieMaker
  • Photo Gallery
  • SkyDrive
Photos and videos
  • Cyberlink YouCam DE
  • Cyberlink Power DVD
  • Adobe Photoshop Lightroom
  • Adobe Shockwave Player
  • Adobe Flash Player
  • HP Connected Photo powered by Snapfish
Movies
Netflix
Multimedia codecs
  • Dolby
  • MPEG2
Audio post processing
Beats audio
Communication
  • Skype
  • Nuance Dragon Assistant
Cloud storage
  • Box.net
  • HP File Viewer/Connected Drive (US only)
HP Utilities and Support
  • HP Online User Guide
  • Getting Started with Windows 8.1
  • HP Registration for Windows 8.1
  • HP Recovery Manager
  • HP Support Assistant
  • HP CoolSense
  • ENERGY STAR Logo
  • HP Utility Center
  • HP ePrint Driver
Environmental specifications
Feature
Max operating power
< 45 W
Temperature
Operating
Non-operating
Relative humidity
Operating
Non-operating
Shock
Operating
Non-operating
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Operating
Non-operating
Important links
List of available documents for the HP Spectre 13 x2 Pro Notebook PC:
Warranty:
One-year limited warranty. Additional support is available (North America only) seven days a week, 24 hours a day by phone as well as through online support forums.
