    Apache Log4j Update
HP ProDisplay P231 23-inch LED Backlit Monitor Product Specifications
Product description
Product features
Feature
Model
P231
Type
TN (Twisted Nematic) LED backlit LCD
58,42 cm (23 in) widescreen
Active area (W x H)
50,91 x 28,64 cm (20.05 x 11.28 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Static contrast ratio (typical)
1000:1
Dynamic contrast ratio (typical)
4,000,000:1
Response time (typical)
5 ms (On/Off)
Pixel pitch
0.265 mm
Backlight lamp life (to half brightness)
30,000 hrs min
Color gamut (typical)
72%
Color support
Can display up to 16.7 million colors
Panel specifications
Specification
Type
TN (Twisted Nematic) LED Backlit LCD
58,42 cm (23 in) widescreen, diagonally measured
Active area (W x H)
Aspect ratio
16:9
250 nits (cd/m2)
1000:1
4,000,000:1
5 ms (on/off)
Pixel pitch
0.265 mm
30,000 hours minimum
72%
Color support
Electrical specifications
Specification
Power supply
Internal
Input power
90 - 265 VAC at 45 - 63 Hz
Typical power consumption
25 W
Maximum
31 W
Power saving
0.5 W
Power cable length
1,9 m (6.2 ft)
Video/other input/output specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog), DVI-D (HDCP support on DVI-D)
USB
N/A
Video cables
(1)VGA, (1) DVI-D
Video cable lengths
1,8 m (5.9 ft)
Audio
N/A
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic
1920 x 1080 @ 60 Hz
Modes (non-interlaced)
  • 1680 x 1050 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Physical specifications
Specification
Dimensions (W x D x H)
Unpacked with stand (lowest setting): 54,4 x 16,56 x 39,49 cm (21.42 x 6.52 x 15.55 in)
Unpacked without stand (head only): 54,4 x 5,1 x 32,9 cm (21.42 x 2.01 x 12.95 in)
Packaged: 60,9 x 13,7 x 41,7 cm (23.98 x 5.39 x 16.42 in)
Head Only: 3,25 kg (7.16 lb)
Unpacked:3,85 kg (8.48 lb)
Packaged: 5,29 kg (11.66 lb)
Environmental specifications
Operating
Temperature
5° to 35° C (41° to 95° F)
Humidity
20% to 80% non-condensing
Altitude
0 to 5,000 m (16,404 ft)
Non-operating
Temperature
-20° to 60° C (-4° to 140° F)
Humidity
5% to 95%, 60° C max wet-bulb
Altitude
0 to 12,192 m (0 to 40,000 ft)
Safety certifications
certifications
Certification and compliance
  • CE
  • CB
  • KC
  • KCC
  • NOM
  • PSB
  • ICE
  • TUV-S
  • RCM
  • CCC
  • CECP
  • TCO
  • ISC
  • VCCI
  • FCC
  • Taiwan
  • BMSI
  • ENERGY STAR
  • EPEAT Gold3
  • CEL Grade 1
  • SmartWay Transport Partnership (NA)
  • Microsoft WHQL Certification
List of available documents for the HP ProDisplay P231 23-inch LED Backlit Monitor
List of available documents for the HP ProDisplay P231 23-inch LED Backlit Monitor:
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
