HP Color LaserJet Enterprise M855 - Installing the printer software in Mac OS on a Wired (Ethernet) Network
Installation and driver options
Review the following information to decide which installation option to use.
CD
Download
For a new product
CD installation is also a quick and easy method, but might not contain the latest software available, even for a newer product.
Downloading the software is free from the HP Web site and it includes the latest product-specific drivers, installer software, and other administrative tools.
For an older product
CD installation might not work if you are installing the product on a computer running a newer operating system that released after the HP product released.
Downloading the software provides good results for older products and can help avoid installation issues.
About the software
The software on the CD is current only to the date of the product release.
The software available from the HP Web site is the most current software available for your product. HP often updates software and drivers after the product and CD release to the market.
Mac installation for a wired (Ethernet) network connection using the in-box CD
  1. Connect the network cable to the product and to the network, if it is not connected already. Wait a few minutes for the product to acquire a network address.
  2. Verify that a network connection has been established. On the product control panel, touch the Network button. If an IP address is listed, the network connection has been established.
    An IP address like 192.168.0.1, for example, is a numeric code that uniquely identifies a device, like a computer or a printer, on a network.
  3. Insert the printing system software CD into the CD-ROM drive. Click the product icon to start the installer.
    If the installer screen does not open automatically when the CD is inserted into the CD-ROM drive, double-click the product CD image on the desktop to open the installer browser screen, and then double-click the installer icon.
  4. The Introduction screen opens. Click the Continue button to proceed.
  5. In the License screen, select the correct language from the menu, read the license agreement, and then click the Continue button.
  6. In the pop-up that opens, click the Agree button to confirm acceptance of the license agreement.
  7. Select the destination for the software installation, and then click the Continue button.
  8. In the Installation Options screen, select whether to perform a standard installation or a custom installation.
    • For a standard installation, click the Install button now.
    • For a custom installation, click the Customize button. On the screen that opens, select the components to install, and then click the Install button.
  9. In the password popup that opens, enter the user name and password, and then click the OK button.
  10. The installer program shows a progress bar as the installation process starts. This process can take several minutes.
  11. Read the tips for reducing environmental impact, and then click Continue when finished.
  12. The Add Printer screen opens. For all connection types, click the Add Printer button.
  13. For a network connection, the product should be added to the list automatically. Click the IP button at the top of the screen to add the product by entering the IP address. After the product name is in the list of printers, select the product from the list, and then click the Add button. Click the Continue button.
  14. When the installation completes, the Summary screen appears. Click the Close button to close the installer program.
Mac installation for a wired (Ethernet) network connection by downloading the software
  3. Browse to the Drivers & Downloads page: Drivers & Downloads.
  4. If prompted, select the product from the list of similar products on the page.
  5. Select the correct operating system, and then click Next.
  6. Click Driver, and then review the available driver options. The options available vary depending on the product.
    HP recommends the Full Software Solution option to optimize product performance and features.
  7. Click a driver item to select it, review the driver details, and then click Download.
  8. If the File Download Security Warning window displays, click Save, and then browse to a location on the computer to save the file.
  9. Click Save. The software downloads to the computer. Make note of the saved file location.
  10. When the download is complete, click Open Folder, and then click the downloaded file. The file name ends in .exe.
    If the Download Complete screen closed, browse to the saved location for the .exe file, and then click it.
  11. Accept the default place to save the files. Click Next, and then wait while the installer extracts the files to prepare for installation.
  12. The Introduction screen opens. Click the Continue button to proceed.
  13. In the License screen, select the correct language from the menu, read the license agreement, and then click the Continue button.
  14. In the pop-up that opens, click the Agree button to confirm acceptance of the license agreement.
  15. Select the destination for the software installation, and then click the Continue button.
  16. In the Installation Options screen, select whether to perform a standard installation or a custom installation.
  17. In the password popup that opens, enter the user name and password, and then click the OK button.
  18. The installer program shows a progress bar as the installation process starts. This process can take several minutes.
  19. Read the tips for reducing environmental impact, and then click Continue when finished.
  20. The Add Printer screen opens. For all connection types, click the Add Printer button.
  21. For a network connection, the product should be added to the list automatically. Click the IP button at the top of the screen to add the product by entering the IP address. After the product name is in the list of printers, select the product from the list, and then click the Add button. Click the Continue button.
  22. When the installation completes, the Summary screen appears. Click the Close button to close the installer program.
