    Windows 11 Upgrade Guide
HP ZBook 14 Mobile Workstation - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
33.9 (at front) x 23.7 x 2.1 cm (13.35 x 9.33 x .83 in)
  • Starting at 1.59 kg (3.51 lb) without hard drive and with M.2 (NGFF) Solid State Drive (SSD)
  • Starting at 1.79 kg (3.94 lb) with touchscreen, without hard drive and with M.2 (NGFF) SSD
  • Starting at 1.64 kg (3.62 lb) with 128GB SSD
  • Starting at 1.65 kg (3.64 lb) with 180GB SSD
Technical specifications
Specification
Stand-Alone power requirements (AC Power)
Nominal operating voltage
19.5 V dc @ 3.3 A
Average operating power
  • Windows 7 (32-bit): 16.28 W
  • Windows 7 (64-bit): 16.8 W
Max operating power
< 65 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-5.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
14-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
Specification
Outline dimensions (W x H x D)
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active area
30.94 x 17.395 cm (12.18 x 6.85 in)
320 g (0.71 lb) (max)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Format: 1366 x 768 (HD)
  • Configuration: RGB stripe
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
14-inch diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900)
Specification
Active area
30.96 x 17.415 cm (12.19 x 6.86 in)
325 g (0.72 lb) (max)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
  • Format:1600 x 900 (HD+)
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
131 ppi
Viewing angle
14-inch diagonal LED-backlit HD+ anti-glare SVA flat + touch (1600 x 900)
Specification
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active area
Diagonal size
35.6 cm (14.0 in)
Touch enabled
Yes
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
131 ppi
Viewing angle
14-inch diagonal LED-backlit FHD anti-glare UWVA slim (1920 x 1080)
Specification
Active area
30.93 x 17.4 cm (12.18 x 6.85 in)
Diagonal size
35.6 cm (14.0 in)
Touch enabled
Yes
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
  • Format:1920 x 1080 (FHD)
Interface
eDP 1.3+PSR (2 lane)
LCD mode
IPS/FFS/AHVA
PPI
157 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
Storage & drives specifications
1TB 5400 rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum): 300 MB/s (Drive capability)
Seek time
  • Single track: 4 ms
  • Average: 14 ms
  • Maximum: 24 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Operating temperature
0° to 60°C (32° to 140°F)
Features
ATA security
500GB 5400-rpm SATA FIPS hard drive
Specification
Drive weight
95 g (0.25 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Single track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security, TCG Opal SSC 2.0 and FIPS 140-2-level
750GB 7200-rpm SATA hard drive
Specification
Drive weight
95 g (0.2 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Features
ATA security
500 GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
500GB 7200-rpm SMART SATA II Self Encrypting Drive (SED)
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security, TCG Opal SSC 2.0 and FIPS 140-2-level2
Specification
Drive weight
115 g (0.25 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Features
ATA security
Specification
Drive weight
115 g (0.25 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
500GB 7200-rpm SMART SATA II SED
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
Seek time
  • Single track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
320GB 7200-rpm SATA hard drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA security
SATA 6-Gb/s 512GB, 2.5-inch SSD
Specification
Drive weight
73 g (0.16 lb)
Capacity
512GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Transfer rate
  • Maximum sequential read: 460 MB/s
  • Maximum sequential write: 260 MB/s
Logical blocks
1,000,215,216
0° to 70°C (32° to 158°F)
Features
ATA security; ATA-8; SATA 3.0 DIPM; TRIM
SATA 6-Gb/s 256GB, 2.5-inch SATA SED SSD
Specification
Drive weight
73 g (0.16 lb)
Capacity
256GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Transfer rate
Logical blocks
500,118,192
Features
ATA security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
SATA 6-Gb/s 180GB, 2.5-inch SSD
Specification
Drive weight
78 g (0.17 lb)
Capacity
180GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Transfer rate
  • Maximum sequential read: 550 MB/s
  • Maximum sequential write: 520 MB/s
Logical blocks
351,651,888
Features
ATA security; ATA-8, SATA 3.0; DIPM; TRIM
SATA 6-Gb/s 128GB, 2.5-inch SSD
Specification
Drive weight
73 g (0.16 lb)
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Transfer rate
  • Maximum sequential read: 415 MB/s
  • Maximum sequential write: 175 MB/s
Logical blocks
250,069,680
Features
SATA 6-Gb/s 120GB, 2242 M.2 SSD
Specification
Drive weight
Up to 10 g (0.02 lb)
Capacity
120GB
Height
3.5 mm (0.138 in)
Width
22 mm (0.866 in)
Interface
M.2 SATA Gen 3 (6 Gb/s)
Transfer rate
  • Maximum sequential read: 540 MB/s
  • Maximum sequential write: 480 MB/s
Logical blocks
234,441,648
Features
SATA 6G-b/s 32GB, 2242 M.2 SSD
Specification
Drive weight
Capacity
32GB
Height
3.5 mm (0.138 in)
Width
22 mm (0.866 in)
Interface
Transfer rate
  • Maximum sequential read: 380 MB/s
  • Maximum sequential write: 70 MB/s
Logical blocks
62,533,296
Features
Security
HP fingerprint sensor
Specification
Voltage
3.0 to 3.6 V
-10° to 75°C (14° to 167°F)
Current consumption image
36 mA
Low latency wait for finger
950 uA
Capture rate
3000 lines/s
ESD resistance
IEC 6100-4-2 4B (+/-15 KV)
Detection matrix
200 x 1 (plus another secondary line); 508 dpi, sensor area 12 x 3 m
Networking/Communication
Intel I218-LM Gigabit network connection
Specification
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az Energy Efficient Ethernet (EEE)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power management
  • ACPI compliant - multiple power modes
  • Energy Detect Low Power Mode (Green Ethernet)
Performance features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
  • MACSec Offload (802.3ae)
  • Intel vPro
  • iSCSI Boot
Manageability
Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only) PXE 2.1 Remote Boot Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30)) Comprehensive diagnostic and configuration software suite Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Intel 82579LM/82579V Ethernet Network Connection
HP hs3110 HSPA+ Mobile Broadband module
Specification
Technology/Operating bands
  • CDMA/1xRTT/EvDO: 800MHz (Cell), 1900 MHz (PCS)
  • GSM/GPRS/EDGE: 850MHz (Cell), 900 MHz (EGSM), 1800MHz (DCS), 1900MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), 900 MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • LTE: 700 MHz (Verizon, Band XIII)
Mobile operator
Verizon (US only)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class B, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
  • UMTS/WCDMA: Release 99 and Release 7
  • LTE: Power Class III as per 3GPP TS 36.101
Wireless parametric standards
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
  • EvDO (Revision A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
  • WCDMA (DC-HSPA+) - 42 Mb/s (Download)
  • LTE (Category 3) - 100 Mb/s (Download ), 50 Mb/s (Upload)
GPS
Standalone, Assisted, XTRA
GPS bands
1575.42 MHz (± 1.023 MHz)
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • LTE: +23 dBm (+2.7 dBm/-1.7 dBm)
  • 1xRTT/EvDO: +24 dBm (+0.5 dBm/-1.5 dBm)
Maximum power consumption
2700 mA (peak)
Power consumption, sleep mode
10 mA
Power management
USB selective suspend Integrated notebook wireless button
Antenna type
Dual high efficiency 6 band antennae with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express MiniCard, USB 2.0 interface
< 10 g
Dimensions (L x W x T)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, operating
3.3 v +/- 9%
Temperature, operating (from TIA/EIA/IS-98-D)
-20° to 65°C (-4° to 149°F)
Temperature, non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
Humidity, non-operating
85% relative humidity for 48 hours at 85°C (185°F) (non-condensing)
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
Intel Dual Band Wireless-N 7260AN 802.11a/b/g/n (2 x 2) WiFi + Bluetooth 4.0 combo adaptor
Specification
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
Frequency band
  • 802.11b/g/n: 2.402 - 2.482 GHz
  • 802.11a/n:
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
Direct Sequence Spread Spectrum CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power
  • 2.4G: +13.5 dBm minimum
  • 5G: +12 dBm minimum
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio Off: 75 mW
Power management
  • ACPI and PCI Express compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 802.11g: -90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11b: -95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mb/s), -88 dBm (11 Mb/s)
  • 802.11n: -69 dBm (150 Mb/s), -66 dBm (300 Mb/s)
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factor
PCI-Express Half-MiniCard
3.1 g
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Voltage, operating
3.3 v +/- 9%
-10° to 70°C (14° to 158°F)
-40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
HP Integrated Module with Bluetooth 4.0+EDR wireless technology
Specification
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3.64 kb/s, voice channels
  • Asynchronous Connection Less links 2178.1 kb/s/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep < 1 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology security
Point to Point, Multipoint Pico Nets up to 7 slaves
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Intel Dual Band Wireless-AC 7260 802.11ac (2x2) WiFi + BT 4.0 combo adapter
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency band
  • 802.11a/n:
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data rates
  • 802.11n: MCS 0 ~ MCS 15, (20 MHz, and 40 MHz)
  • 802.11ac: MCS0 ~ MCS9, (1SS, and 2SS) (20 MHz, 40 MHz, and 80 MHz)
Modulation
  • Direct Sequence Spread Spectrum
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
  • AES-CCMP: 128-bit in hardware
  • IEEE 802.11i
  • WAPI
Roaming
IEEE 802.11 compliant roaming between access points
Output power
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas > 20 cm from the user and peak gain of +3 dBi at 2.4 GHz and +4 dBi at 5 GHz
  • 802.11b: -95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mbps), -88 dBm (11 Mb/s)
  • 802.11a/g: -90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11n: -69 dBm (72.2 Mb/s), -66 dBm (300 Mb/s)
Anteena type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
3.1 g
Operating voltage
3.3 V+/- 9%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 80°C (14° to 176°F)
Humidity
Altitude
LED activity
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep < 17 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
  • Full support of Bluetooth Security Provisions
  • Point to Point, Multipoint Pico Nets up to 7 slaves
Power management
Certifications
  • Generic Access Profile (GAP)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Printing Profile (BPP)
  • Video Distribution Profile (VDP)
Intel Dual Band Wireless-N 7260NB 802.11a/b/g/n (2 x 2) WiFi adapter
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
Frequency band
  • 802.11a/n:
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
Antenna structure
Data rates
Modulation
  • CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • IEEE 802.11i
  • WAPI
Sub-channels
Roaming
Output power
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Radio Off: 75 mW
Power management
  • 802.11g:-90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
Antenna connections
Form factor
Dimensions
3.1 g
Operating voltage
3.3 V+/- 9%
Temperature
Humidity
Altitude
LED activity
Audio/Multimedia-DTS sound
Specification
Implementation
IDT 92HD91
Function key volume
Controls Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
> 85 dB
Total harmonic distortion
0.01%
Noise Floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo speakers
Specification
Power rating
2 W
Impedance
4 Ohms
Power specifications
HP 65-W Smart AC adapter
Specification
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
  • 100 to 240 V ac
  • Input efficiency: 87% min at 115 V ac
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 V ac, 0.85 A at 180 V ac
Output
  • Output power: 65 W
  • DC output: 18.5 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: < 11A, Over voltage protection - 29-V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 0° to 40°C (32° to 104°F)
  • Non-operating (storage) temperature: -20° to 65°C (-4° to 149°F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage humidity: 10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
Environmental specifications
Energy consumption
115 V ac
230 V ac
100 V ac
Normal operation
5.51 W
5.15 W
5.36 W
Sleep (Energy Star low power mode)
0.85 W
0.88 W
0.85 W
Off
0.36 W
0.36 W
0.35 W
Energy efficiency data listed is for an ENERGY STAR compliant product if offered within the model family. HP computers marked with the ENERGY STAR Logo are compliant with the applicable U.S. Environmental Protection Agency (EPA) ENERGY STAR specifications for computers. If a model family does not offer ENERGY STAR compliant configurations, then energy efficiency data listed is for a typically configured PC featuring a hard disk drive, a high efficiency power supply, and a Microsoft Windows operating system.
Heat dissipation
115 V ac
230 V ac
100 V ac
Normal operation
19 BTU/hr
18 BTU/hr
18 BTU/hr
Sleep
3 BTU/hr
3 BTU/hr
3 BTU/hr
Off
1BTU/hr
1 BTU/hr
1 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
