    Windows 11 Upgrade Guide
HP PCs - Using Leap Motion (Windows 7 and 8)
This document applies to Leap Motion devices used with HP PCs running Windows 7 or Windows 8.
Leap Motion technology is a different way to provide input and interact with your computer using gestures. The Leap Motion sensor can be used with other computer input devices. The sensor detects hand and finger motions made without touching the computer and interprets the gestures as mouse and keyboard inputs. The Leap Motion sensor tracks motions to within 0.01mm using 2 CCD cameras. A few applications for this technology include:
  • 3D modeling for art, science and robotics
  • Animation for art and games
  • Education for science, music, games, and technology
  • Imaging for music, presentations, and sterile environments
Installing Leap Motion Software
Use this section to install Leap Motion software. Leap Motion comes preinstalled on some HP computers. If you have a computer that came preinstalled with Leap Motion software, skip this section and go to Setting up Leap Motion. Leap Motion must be installed on computers when a Leap Motion device is purchased separately.
Before you install
Before installing be aware of the following issues:
  • Leap Motion software needs up to 400MB of free disk space to install.
  • Update the latest graphics drivers for your computer before installing Leap Motion software.
  • Use Internet Explorer 10 or higher, or another browser to download Leap Motion software.
  • If you have problems downloading the software, temporarily disable any anti-virus software that is running.
Begin installation
Follow these steps to install Leap Motion software on your computer.
  1. Connect your keyboard or sensor to a USB 2.0 port on your computer.
  2. In your Internet browser, go to https://www.leapmotion.com/setup (in English)
  3. Click Windows Download to begin downloading Leap Motion software.
    Figure : Download Leap Motion for Windows
    Download Leap Motion for Windows from the Leap Motion set up web site
  4. The Welcome to Leap Motion window opens. Follow the setup manager directions to install Leap Motion.
    Figure : Setup Welcome window
    Leap Motion setup manager Welcome window
    Figure : Installation Complete window
    Leap Motion setup manager Installation Complete window
  5. After installation is complete, you are prompted to restart your computer. Click Restart Now.
    Figure : Restart Now
    Restart Now to install Leap Motion
You must have a Leap Motion sensor to set up and use Leap Motion. The Leap Motion hardware comes in several configurations. The separate Leap Motion device can be used as an accessory with many HP computers. Select HP notebook computers have embedded Leap Motion sensors. Some HP keyboards come with an embedded Leap Motion sensor. These keyboards are delivered with select HP desktop computers or can be purchased separately.
    Figure : Examples of Leap Motion sensors
  1. The Leap Motion sensor on a notebook
  2. The Leap Motion sensor on a keyboard
  3. The Leap Motion device as an accessory
Follow these steps to set up your Leap Motion device.
  1. Connect your computer to the Internet.
  2. Open Leap Motion Airspace.
    In Windows 8
    In Windows 7
    At the Start screen, type leap to open the Search charm. Select Leap Motion Airspace in the Search results.
    Click on the Airspace icon on the Desktop.
    Figure : Leap Motion Airspace
    Leap Motion Airspace on the  Windows 8 Search screen
    Figure : Airspace icon
    Airspace icon on the Windows 7 desktop
  3. If you have not already activated the Leap Motion sensor, the computer prompts you to activate the sensor by pressing fn and spacebar. When the sensor is activated, you see two red LEDs inside the Leap Motion sensor turn on. A small white or green light next to the Leap Motion sensor also turns on.
    Figure : Activate the Leap Motion sensor
    Press fn and spacebar to activate the Leap Motion sensor
  4. Get started by signing up for a Leap Motion account or sign in to an existing account.
    Figure : Get Started screen
    Get Started or sign in to an existing account screen
For best performance of the Leap Motion sensor:
  • Set up your Leap Motion device away from direct sunlight or other bright infrared (IR) sources.
  • Pull back long sleeves and remove large jewelry or other items from your hands.
  • Be sure the Leap Motion sensor is clean and free of scratches or debris.
  • Keep hands parallel to the sensor and within the sensor range. Spread your fingers to improve sensor detection.
You are now set up to use Leap Motion.
Learning to use Leap Motion
Once you have signed in, the Airspace Home page opens. The Airspace Home page has activities and games that help you get used to interacting with your computer using Leap Motion. It is useful to try these activities and adjust the Leap Motion settings to your preferences. Be sure you have activated the Leap Motion sensor. When the sensor is activated, you see two red LEDs inside the Leap Motion sensor. A small white or green light next to the Leap Motion sensor also turns on. If the lights are not on, press fn and spacebar to turn on the sensor.
Figure : Airspace Home page
Airspace Home page
Interacting with Windows using Leap Motion
You must open Touchless for Windows from the Airspace Home page each time you start your computer to begin interacting with Windows using Leap Motion. Some Leap Motion devices do not come with Touchless for Windows. If your Airspace Home page does not have the Touchless for Windows tile, you can download the free Touchless for Windows app from the Airspace Store (in English). Go to the Leap Motion Airspace Store section in this document and follow the steps to download the app.
Improving your Leap Motion experience
Your computer and the Airspace Store have other Leap Motion apps to improve and adjust your Leap Motion experience.
Troubleshooting Leap Motion
Leap Motion includes many troubleshooting tools. Most of the troubleshooting tools are accessed through the Leap Motion Control Panel.
Frequently Asked Questions about Leap Motion
Get answers to some Leap Motion frequently asked questions.
Do my mouse and keyboard work while I am using Leap Motion?
Can I use Leap Motion with the games I like to play?
Can I use multiple Leap Motion sensors on my computer?
Can I use the Leap Motion sensor across multiple monitors?
Can I set up Touchless for Windows to start when I start my computer?
