    Fix HP Printer issue on macOS
HP LaserJet Pro MFP M435nw - Load Tray 3 (accessory)
Optional Tray 3 holds up to 500 sheets of 75 g/m2 paper. If the paper is heavier, the tray does not hold as many sheets. Do not overfill the tray. It supports cut sheet paper weight 60–120 g/m2.
For information about the correct paper orientation for loading paper in this tray, see Tray 3 paper orientation.
Do not print envelopes, labels, or unsupported sizes of paper from Tray 3. Print these types of paper only from Tray 1.
  1. Pull the tray out and lift up slightly to remove it completely from the product.
    Do not open the tray while it is in use.
    Figure : Open the tray
  2. Pinch the release that is located on the left guide and slide the side guides to the correct paper size.
    Figure : Adjust the paper guide
  3. Adjust the paper length to the correct paper size.
  4. Load paper into the tray. Check the paper to make sure the guides lightly touch the stack, but do not bend the paper.
    The way you should orient the paper in the tray varies depending on the paper size. For additional information, see Tray 3 paper orientation.
    To prevent jams, do not overfill the tray. Be sure the top of the stack is below the tray full indicator.
    Figure : Load paper in the tray
    If the tray is not adjusted correctly, an error message might display during printing or the paper might jam.
  5. Slide the tray completely into the product.
    Figure : Close the tray
  6. On the product control panel, configure the paper size and type to match the paper loaded in the tray.
    1. From the Home screen on the product control panel, touch the Setup button.
    2. Open the following menus:
      System Setup
      Paper Setup
      Tray 3
    3. Touch Paper Size and select the correct size.
    4. Touch Paper Type and select the correct type.
Paper type
Paper size
How to load paper
Cut sheet paper
Letter, A4, A5, B5, Executive, 16K, and custom sizes
Long edge along the front of the tray
A3, B4, 11 x 17, Legal, Oficio 8.5 x 13, and custom sizes
Long edge along the side of the tray
Preprinted, prepunched, or letterhead
Face-down
Top edge at the right of the tray
Face-down
Top edge at the front of the tray
