    Fix HP Printer issue on macOS
HP LaserJet Pro MFP M435nw - Load Tray 1 (multipurpose tray)
Tray 1 holds up to 100 sheets of paper, up to 75 transparencies, up to 50 sheets of labels, or up to 10 envelopes. It supports cut sheet paper weight 60–199 g/m2; labels and transparencies 0.10 to 0.14 mm thick; envelopes weight 60 to 90 g/m2; and postcards weight 135 to 176 g/m2.
For information about the correct paper orientation for loading paper in this tray, see Tray 1 paper orientation.
  1. Open Tray 1 by grasping the handles on each side of the tray and pulling down.
    Figure : Open the tray
  2. Slide out the tray extension.
    Figure : Slide out the extension
  3. For long paper, fold out the tray extension to support the paper.
    Figure : Fold out the extension
  4. Open the paper guides.
    Figure : Open the paper guides
  5. Load the paper into the tray. Make sure that the paper fits under the tabs and below the maximum-height indicators.
    The way you should orient the paper in the tray varies depending on the paper size. For additional information, see Tray 1 paper orientation.
    Figure : Load paper in the tray
  6. Adjust the paper guides so that they lightly touch the paper stack but do not bend the paper.
    Figure : Adjust the guides
To avoid jams, do not add paper to Tray 1 while the product is printing. Do not close Tray 1 while the product is printing.
Paper type
Paper size
How to load paper
Cut sheet paper
Letter, A4, A5, B5, Executive, 16K, and custom sizes
Long edge leading into the product
A3, B4, 11 x 17, Legal, Oficio 8.5 x 13, and custom sizes
Short edge leading into the product
Preprinted, prepunched, or letterhead
Face-up
Long edge leading into the product with the top of the page to the right of the tray
Face-up
Top edge leading into the product
Labels
Any compatible label size
Face up
Envelopes
Any compatible envelope size
Face-up
Top edge toward the right of the tray, postage end entering the product last
