    Looking for Site Help?
HP Tablets - Listening to Music, Watching Videos, and Viewing Photos on Your Tablet (Android KitKat, Jelly Bean)
This document applies to HP and Compaq tablets with Android 4.4/KitKat and 4.2/Jelly Bean operating systems.
Your tablet comes with preinstalled media player apps for music, videos, and photos. This document is a guide to the media player apps on your tablet: the Gallery app, for photos and videos; and Google Play apps, for music, movies and TV. To find other media player apps, search the Google Play Store (in English).
Depending on the version of Android installed on your tablet, some of the images in this document may not match your tablet exactly.
Using the Gallery app to play or view media on your HP tablet
You can play videos and photos, and make basic edits to images, in the Gallery app. Use the following sections to learn more about the Gallery app:
Playing videos in the Gallery app on your HP tablet
When you record a video on your tablet, the video is saved in the Gallery app. Use the following steps to play videos in the Gallery app:
  1. On the Home screen, tap the All apps icon, and then tap the Gallery app.
  2. Tap the album where your video is located. Videos recorded using the Camera app are automatically stored in the Camera album.
  3. Tap the video you want to play.
  4. Tap the play button in the center of the screen.
  5. If you have more than one video player app installed on the tablet, a window appears asking you to select an app to complete the action. Select Video player, and then select Always (if you want the Gallery app video player to be the preferred video player), or select Just once (if you want to continue to be prompted to choose an app for playing videos).
  6. While the video is playing, tap anywhere on the screen to briefly display a pause button and progress bar. Tap the pause button to pause playback. Tap and drag the white circle along the progress bar to skip back or forward in the video.
    Figure : Video progress bar
    Video progress bar
Viewing photos in the Gallery app on your HP tablet
When you take a picture on your tablet, the picture is saved in the Gallery app. Use the steps in this section to view photos you have taken, and learn about options for working with individual images in the Gallery app.
  2. Tap the album where your photo is located. Photos taken using the Camera app are automatically stored in the Camera album.
    If you have other camera apps or photo-editing apps, the photos used in those apps might be stored in separate albums within the Gallery.
  3. Tap a thumbnail to open a photo, and do any of the following:
    Desired result
    Action
    Zoom in or out
    Place two fingers on the screen. Spread your fingers apart to zoom in, or pinch your fingers together to zoom out. Alternatively, double-tap the screen to zoom in or out.
    Delete the photo
    Tap the Menu icon, and then tap Delete.
    Print the photo Note: Print option not available on all models
    Tap the Menu icon, and then tap Print. For more information about printing a photo from the Gallery app, refer to one of the following HP support documents: Printing Wirelessly from Your HP Tablet (Android 4.4/KitKat) or Printing Wirelessly from Your HP Tablet (Android 4.2/Jelly Bean).
    View a slideshow of images
    Tap the Menu icon, and then tap Slideshow. The Gallery app plays a slideshow of the images in the currently selected album. To end the slideshow, tap anywhere on the screen.
    Edit the photo
    Tap the Menu icon, and then tap Edit. See Editing photos in the Gallery app on your HP tablet for more information.
    Rotate the photo
    Tap the Menu icon, and then tap Rotate left or Rotate right (repeatedly, if necessary), until the image displays correctly.
    Crop the photo
    Tap the Menu icon, and then tap Crop. Drag the edges or corners of the crop tool to resize. Drag inside the crop box to reposition it over the image. When finished, tap Done.
    Set picture as a contact photo or tablet wallpaper
    Tap the Menu icon, and then tap Set picture as. tap Contact photo or Wallpaper.
    View image details
    Tap the Menu icon, and then tap Details.
Viewing Photo Spheres in the Gallery app on your HP tablet (Android 4.4/KitKat)
On tablets running Android 4.4/KitKat operating system, the Camera app can record Photo Spheres, with multiple images automatically stitched together to capture 360-degree views of your surroundings (refer to the HP support document Using the Camera for Photo Sphere instructions). You can then view the Photo Sphere images in the Gallery app. Use the following steps to view Photo Spheres in the Gallery app:
  2. Tap the album where the Photo Sphere is located. Photo Spheres recorded using the Camera app are automatically stored in the Camera album.
  3. Tap the thumbnail image of the Photo Sphere you want to view. The Photo Sphere opens as a panorama.
    Figure : Photo Sphere in the Gallery app
  4. Tap the Photo Sphere icon to open an immersive 360-degree view of the image.
    Select different views of the Photo Sphere by tapping the icon in the bottom left corner of the screen:
    • Tap the compass icon to directionally align the view with the position you hold the tablet. Tilt and move the tablet to view other angles of the Photo Sphere.
    • Tap the rotating arrows icon, and then briefly tap the screen to start the image spinning on a vertical axis. Tap the screen again to stop the automatic spinning. Drag your finger across the screen in any direction to view other angles of the Photo Sphere image.
The Gallery app features basic editing tools for your photos. For example, you can change the lighting, add a photo filter effect, or crop the image. Other apps for photo editing are available in the Google Play Store (in English). Use the following steps to edit a photo in the Gallery app:
  3. Tap the thumbnail image of the photo you want to edit.
  4. Tap the icon in the bottom left corner of the screen to open the image in the editor.
  5. Use the available tools to edit your photo.
    Figure : Editing tools in the Gallery app
  6. Tap Save () in the upper left corner of the screen to save your edits. The edited photo is saved as a copy.
Using Google Play apps to play media on your HP tablet
Select HP tablets come with preinstalled Google Play apps for playing music and videos. Use the following sections to learn more about the preinstalled Google Play apps:
Listening to music with Google Play Music on your HP tablet
Your tablet comes with the Google Play Music app preinstalled. With this app, you can listen to music saved in local or external storage, or add music to your Google Play music library and purchase songs online. For information about using the app, see New to Google Play Music? Learn the basics (in English) from Google Play support.
Playing videos in the Google Play Movies & TV app on your HP tablet
Your tablet comes with the Google Play Movies & TV app preinstalled. You can use this app to play the videos you record with your tablet, or use it to watch movies and TV programs that you either stream online, or purchase and download for offline viewing. For information about using the app, see New to Google Play Movies & TV? Learn the basics (in English) from Google Play support.
Frequently asked questions about playing media on your HP tablet
Find answers to FAQs about media player apps on your tablet.
How do I change the preferred apps that open my music, videos, or photos on my HP tablet?
You can set your media files to automatically open with a preferred app, rather than selecting your preferred app every time you want to open the file type. You can also clear your app preferences to reset the file associations.
To set a preferred app for opening a media file type, use the following steps:
  1. Tap a media file of a given type (for example, an .mp3 music file) that you want to set a preferred app to open.
  2. Tap to select the preferred app, and then tap Always.
    Figure : Selecting a preferred app
    The selected app is now the preferred app for opening this file type. You can still open this type of file from a different app if you first open that app, and then open the file from within the app.
To reset all of your preferred apps, use the following steps:
In addition to clearing all preferred apps for actions, resetting your app preferences resets all disabled apps, app notifications, and background data restrictions for apps. It does not destroy any app data.
  1. On the Home screen, tap the All apps icon, and then tap the Settings icon.
  2. In the Device section, tap Apps.
    Figure : Apps
    Apps
  3. Tap the menu icon in the top right corner, and then tap Reset app preferences.
    Figure : Reset app preferences
  4. Tap Reset apps.
    Figure : Reset apps
    Reset apps
    Now when you select a media file, you are presented with all available app choices for opening that file, including all media players installed on your tablet that support playback of the given media file type.
Where can I get other media player apps for my HP tablet?
To find other Android media player apps, visit the Google Play Store (in English).
How do I surf the Internet while listening to streaming music on my HP tablet?
To browse the Internet while listening to a streaming music service, use one of the following solutions:
  • Use separate browsers. There are two Web browsers preinstalled on the tablet: Chrome and Browser. Open one browser and start streaming music, and then tap the Home navigation button. Open the other browser and start surfing the Internet.
  • Install a streaming music app. Search for your preferred streaming music service in the Google Play Store (in English). If there is an Android app available for the music service, install it, and use the app to listen to streaming music rather than streaming from a browser.
How do I edit photos on my HP tablet?
You can make basic enhancements and edits to images using the Gallery app. For more detailed edits, find image editing apps in the Google Play Store (in English).
Country: Flag Bulgaria
