Document ID: c03935524
Version: 1
Advisory: HP Z220 Workstation - May Not Come Out of Hibernation
Release date : 24-Sep-2013
Last updated : 24-Sep-2013
DESCRIPTION
If Microsoft Windows 7 64-bit using the Unified Extensible Firmware Interface (UEFI) is installed on an HP Z220 workstation, the system may have following Blue Screen of Death (BSOD) after waking up from hibernation.
Windows Resume Loader
Your computer can't come out of hibernation Status: 0xC000000D
Your computer will be rebooted. Any information that was not saved before the computer went into hibernation will be lost.
Enter=Reboot
SCOPE
Systems:
  • HP Z220 Convertible Minitower Workstation
  • HP Z220 Small Form Factor Workstation
Operating Systems:
  • Microsoft Windows 7 Enterprise (64-bit)
  • Microsoft Windows 7 Home Basic (64-bit)
  • Microsoft Windows 7 Home Premium (64-bit)
  • Microsoft Windows 7 Professional (64-bit)
  • Microsoft Windows 7 Ultimate (64-bit)
RESOLUTION
Perform the following procedures to solve this issue.
NOTE
Use the Arrow keys to select various menus, menu items, and to change values (unless otherwise specified).
  1. Start or restart the computer.
  2. Press the F10 key when the F10=Setup message appears on screen.
  3. Select Advanced > Power-On Options > Memory Manager Runtime Allocation > Enabled.
  4. Press the F10 key to accept the change.
  5. Select File > Save Changes and Exit.
  6. Press the Enter key to save the changes and exit the F10 Setup utility.
Hardware platforms affected : HP Z220 Convertible Minitower Workstation, HP Z220 Small Form Factor Workstation
Support Communication Cross Reference ID : IA03935524
