HP Pavilion 23tm Touch Monitor - Product Specifications
The HP Pavilion 23tm is a 58.4 cm (23 inch) Touch Monitor.
Figure : Photo of the HP Pavilion 23tm Touch Monitor
E1L11AA
Features
The 23tm Touch Monitor has the following features:
  • DVI-D and HDMI inputs
  • BrightView Technology enhances clarity and provides brilliant colors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Security lock
Technical specifications
LED feature
Specification
Display size
58.4 cm (23 inch) diagonal
Panel active area (width x height): 50.9 cm x 28.6 cm (20 inches x 11.2 inches)
Display type
Widescreen IPS with LED backlighting
Aspect ratio
16:9
Brightness
220 nits
Inputs
1 DVI-D
1 HDMI
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
7 ms (Grey-to-Grey (GtG) with overdrive)
Pixel pitch
0.265mm
Pixels per inch
96
Color gamut
72% (16.7 M)
BrightView Panel
Cover glass without anti-glare treatment (20 mm consistent border)
HDCP (High-bandwidth Digital Content Protection)
Yes
Audio
Internal speakers and headphone jack
USB
USB connection for touch screen function only
Power and Operating Specs
External power supply
Power consumption: 33 Watts max power consumption (25 Watts typical power consumption) , 0.5 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 90% RH
Dimensions
H x W x D (unpacked):
40.8 x 59.9 x 6.8 cm (16.1 x 23.6 x 2.7 inches)
Unpacked: 6.5 Kg (14.3 lbs)
