    Windows 11 Upgrade Guide
HP LaserJet Pro Printers - A 'Toner Low' Message Displays
This document is for the following printers.
HP LaserJet Pro MFP M125a
HP LaserJet Pro MFP M127fn
HP LaserJet Pro MFP M125nw
HP LaserJet Pro MFP M127fs
HP LaserJet Pro MFP M125r
HP LaserJet Pro MFP M127fw
HP LaserJet Pro MFP M125ra
HP LaserJet Pro MFP M128fn
HP LaserJet Pro MFP M125rnw
HP LaserJet Pro MFP M128fp
HP LaserJet Pro MFP M126a
HP LaserJet Pro MFP M128fw
HP LaserJet Pro MFP M126nw
HP LaserJet Pro MFP M26nw
A Cartridge is Low or Cartridge is Very Low message displays when the amount of toner in the cartridge is below a certain percentage. This message is a reminder to have a replacement toner cartridge available. You do not need to replace the toner cartridge until print quality becomes unacceptable.
You can change when the Cartridge is Low message displays by changing your Supply Settings options in the System Setup menu on the printer control panel.
Once the HP toner cartridge reaches the Very Low status, the HP Premium Protection Warranty ends.
Purchase a replacement toner cartridge
